Mac Mini G4 and boot from USB Stick
    Posts: 649 from 2004/4/15
    I followed these steps https://www.morphos-team.net/guide/usb-boot
    to create and boot from USB Stick.
    But after booting nothing happens (see of log):
    Apple PowerMac 18,2 4.9.4f1 BootROM built on 07/12/05 at 16:57:27
    Copyright 1994-2005 Apple Computer, Inc.
    All Rights Reserved.
    Welcome to Open Firmuare, the system time and date is: 12/24/2024 14:58:21
    To continue booting, type "mac-boot" and press return.
    To shut down, type
    "shut-doun" and press return.
    Reducing system power...
    Release keys to continue!
    ok.
    0 › boot ud:,boot. ing bi umsdu: morphos. iso load-size=1b2bf0 adler32=e2b5e2ad
    Loading ELF
    DO-QUIESCE finished_
    Do you have any idea whats going wrong?
    EDIT:
    more details in german forum: https://www.a1k.org/forum/index.php?threads/93280
    [ Edited by eliot 25.12.2024 - 08:23 ]
  • »25.12.24 - 06:36
    AKiLL
    Posts: 93 from 2006/3/6
    Be sure you used the correct boot image and that the ISO file is named morphos.iso) without spaces.
    Also, your stick could be too big and OpenFirmware cannot recognize it.
    Try with a smaller usb stick or with a smaller partition.
    eliot wrote:
    To shut down, type
    ok.
    Loading ELF
    EDIT:
  • »25.12.24 - 08:05
    Ah, thanks, now it works.
    I copied the contents of the iso instead of the iso itself.
    It was my fault.
  • »25.12.24 - 09:31
