Posts: 728 from 2006/5/28
Youtube has recently made some changes under the hood which resulted in OWB showing an empty site, when you try to load the mobile version.
You can bypass this with an alternative YouTube frontend called "Invidious" ->
click hereThere is already an amiga related hoster of the frontend at
Aiostreams Amiga ProjectsYou can also setup your own invidious server on your local network using docker.
The main benefit of Invidious is the absence of all the stuff running in the background (javascript, ads, tracker, etc) which results in a very swifty and comfortable YouTube experience even on the slower machines (pegasos, efika, etc).
The Amiga hoster also has an frontend for Twitch, but due to the lack of streaming capabilities of current media players on MorphOS, theres no way to watch Twitch streams.
[ Edited by Cego 27.08.2024 - 13:46 ]Pegasos II G4 @1.0GHz, 1GB DDR Ram, Radeon 9200Pro, 240GB SSD+160GB HD, MorphOS 3.18, AmigaOS4.1 FE, Debian 8
