Moderator
Posts: 2579 from 2003/2/24
Most likely due to something you run at startup crashing before Ambient is fully loaded.
Options:
- boot from 3.18 CD, backup whatever you need (don't forget the keyfile) and do a fresh install
- boot from 3.18 CD, remove anything from WBStartup all 3rd parts screenbar modules and anything else you can think of and try to boot from HD
I also had some USB-drives inserted stall the boot process but never found a clear pattern for it.
