Best filesystem for MorphOS to use
    Posts: 111 from 2023/12/1
    Before I get too carried away with building up my AmigaOne X5K with software, I wanted to make sure the SFS filesystem I created (50gb) for my MorphOS 3.18 was a good choice.
    I saw tons of options, many foreign to me, so I went with the one on top, SFS.
    Did I choose wisely <que in Indiana Jones movie here... yeh you know the one>
    TJ
  • »13.01.24 - 18:21
    matt3
    Posts: 785 from 2004/2/10
    You chose 'wisely'...
    Some have claimed that the native PFS runs faster, but SFS is the default and I have used it for 20 years without any issues... It is very stable and mature, so who needs drama right?
  • »13.01.24 - 20:53
    Thanks, yeh life has enough drama. haha
    TJ
  • »13.01.24 - 21:17
    zukow
    Posts: 662 from 2005/2/9
    TJ
    SFS from MorphOS is afaik not quite compatible with AmigaOS4 SFS (it is compatible with old OS3 sfs) so do not try to write between MOS/OS4 SFS partitions. Reading should work ok.
    You can also play with Cache settings, it is Morphos implemenetation of Dynamicache tool.
    if something goes wrong with SFS partition, you can use included SFS Doctor.
  • »14.01.24 - 09:29
    vulture
    Posts: 198 from 2008/2/4
    Personally, I never had a single problem on my Peg2 sharing files between SFS0 and SFS2 partitions under both MorphOS and AmigaOS4. MorphOS' sfs doctor worked equally well on partitions formatted by any one OS.
  • »14.01.24 - 10:47
