Wrong colors on password login / Ambient
    Cego
    Posts: 738 from 2006/5/27
    I have activated a password login for my MorphOS system and unfortunately I get wrong colors. Is there a way to fix this?
    I am using the standard FlatPapillon MUI settings for ambient. The wrong colors only appear on the login prompt.
  • »17.12.23 - 09:18
    Posts: 3275 from 2003/3/5
    Edit your MUI settings to tweak the text/background colors of string inputs and save them as AUTHSCREEN.1.prefs in ENVARC:MUI
  • »18.12.23 - 13:16
    Cego
    Thanks! That did the trick :)
  • »22.12.23 - 13:52
