Games Controllers - x360.class vs hid.class
    Zetec-s
    Posts: 198 from 2008/7/10
    Right now I'm really confused about game controllers under MorphOS.
    I bought a wired X-Box compatible controller at Christmas which works great with games like Tower 57 but I can't for the life of me get it to work on E-UAE or anything that appears to need the lowlevel library for control.
    I have now bought a wireless X-Box controller from the MorphOS Store (excellent service by the way!) which Papiosaur has confirmed will work with the E-UAE and other lowlevel usages and I can't get it to work on either my G5 or MacMini.
    I believe the issue is that both controllers are showing up as using the X360.class within Poseidon rather than hid.class but I have no idea on how to change this. When I try to force the binding it doesn't work.
    Therefore any help would be much appreciated.
  • »09.08.21 - 11:44
    Posts: 3326 from 2003/3/5
    They're not supposed to work as hid. x360.class (sensors API) based gamepads should work just fine with lowlevel.library... Are you sure you didn't replace lowlevel.library that came with MorphOS with some 3rd party hacked/patched lib?
    On a side note, someone should really update E-UAE to use sensors/gamepadlib instead of lowlevel :(
  • »09.08.21 - 12:52
    Zetec-s
    Thanks Jaca
    I've checked and the lowlevel.library is dated 30 December 2020, so it looks like the latest version to me.
    I know its something I'm doing wrong but I don't know what, apart from its on both my MacMini and G5.
    What I cannot do is get into the lowlevel settings on either device, which I thought was because I was using the xbox360.class rather than the hid.class.
  • »10.08.21 - 07:10
    Zetec-s
    Update - It's fixed!
    Papiosaur got in touch and it turns out the controller has a PC Mode and an XBox mode and when I switch to PC Mode it appears as a hid.class device and is recognised by EUAE.
    So pleased to now have a controller I can use with things like SWOS Total Pack.
    Also a big thanks for Papiosaur and his MorphOS Store, as the work he does in checking compatibility really helps take the leg work out of buying and trying stuff out for yourself. Delivery was really quick to the UK as well.
  • »10.08.21 - 09:12
    It should still work in XBox mode. Did you try it with Tower 57?
  • »10.08.21 - 13:36
    Zetec-s
    It works with Tower 57 but only when in XBox mode. If I set it up to use the hid.class by setting it as a PC device it doesn't work.
  • »10.08.21 - 14:03
    AKiLL
    Posts: 93 from 2006/3/6
    Unsuccessfully tried with my wired X-Box compatible controller.
    I've plugged it in and playing SWOS (Real Amiga SWOS Total Pack edition) it works just fine with directional pad (but game is not playable) while the sticks don't work.
    The stick of the other generic HID controller I have (Color Rumble Pad) works regularly..
    What am I doing wrong?
  • »26.11.21 - 19:57
    Someone really needs to add sensors.library support to EUAE...
  • »29.11.21 - 11:40
  • man
    man
    Posts: 136 from 2019/11/11
    someone use usb hub
    that detect some usb hardisk not recognize
    i have a xbox 360 joystick but not recognize
    perhaps it work with usb hub?
    thanks
  • »06.08.23 - 14:50
