Network problems
    cip060
    Posts: 152 from 2010/7/30
    Network problems
    I have an imacg g5 isight for a few days and it's giving me problems connecting
    wiifii and with the network cable
    today example airport works and connects online radio and amirc work but if I use the owb/wayfarer browser they give host/dns error and I can't navigate
    what could have happened? what should i check?
    I also tried with a mac sorbet leopard system
    if I connect the direct lan cable it gives me no HOST from mac os
    What tests could I do to figure out where the problem lies?
    from the mac os panel the airport and lan network devices have no problem
    Could it be the mac connector?
    I also use my network cable on pc and xbox360 and other consoles and it works and they connect
  • »31.07.23 - 07:48
    cip060
    The problem is that I'm unable to connect to the web. When I use OWB/waifarer,
    I get an error (Error 6: Unable to resolve host name).
    The problem occurs only if I have to navigate with owb/wayfarer
    The rest works the computer is regularly online amirc works and also easy install download and install the programs also amitube works and online radio I listen to music without problems
  • »31.07.23 - 08:32
    cip060
    The problem is LOOPBACK !!!!!!!!!!!!!!
    Not Enabled!!!
    it's WORk
  • »31.07.23 - 09:10
