Can't install MorphOS on Sam460LE
    bigfoot
    Posts: 510 from 2003/4/11
    Thanks! I believe that contains everything I need for now. I'll get back to you when there's something new to test.
  • »15.07.23 - 04:46
    bigfoot
    OK, I uploaded a new image a bit sooner than I expected. Same procedure as before, new md5sum is be8aa4943d14665f734ac5153f9880b6.
    Thank you.
  • »15.07.23 - 05:50
    Posts: 42 from 2023/3/27
    It finally boots!!!
    However, my Harddrive isn't listed in IWizard, so I can't install MorphOS...
    U-Boot 2015.b (Dec 23 2022 - 13:11:28)
    CPU: AMCC PowerPC 460EX Rev. B at 1140 MHz (PLB=228 OPB=114 EBC=114)
    No Security/Kasumi support
    Bootstrap Option H - Boot ROM Location I2C (Addr 0x52)
    Internal PCI arbiter enabled
    32 kB I-Cache 32 kB D-Cache
    Board: Sam460, PCIe 4x + PCIe 1x
    I2C: ready
    DRAM: 2 GiB (ECC not enabled, 456 MHz, CL4)
    PCI: Bus Dev VenId DevId Class Int
    01 08 1033 0035 0c03 00
    01 08 1033 00e0 0c03 00
    01 09 1095 3112 0180 00
    00 04 104c ac23 0604 ff
    PCIE0: successfully set as root-complex
    04 00 1412 1724 0401 ff
    03 00 1b21 1080 0604 00
    PCIE1: successfully set as root-complex
    06 00 1002 7280 0300 ff
    Net: ppc_4xx_eth0
    FPGA: Revision 03 (2010-10-07)
    SM502: not found
    PERMD2:not found
    VGA: 1
    VESA: OK
    Model: Sam460cr/le, PCIe 4x + PCIe 1x
    USB: EHCI 1.00
    scanning bus for devices... 4 USB Device(s) found
    scanning usb for storage devices... 1 Storage Device(s) found
    SATA Device 0: OK SATA Device 1: not available
    Model: ST9320325AS Firm: 0010LVM1 Ser#: 6VD2TSKW
    Type: Hard Disk
    Supports 48-bit addressing
    Capacity: 305245.3 MB = 298.0 GB (625142448 x 512)
    not available
    Press SPACE for menu, ESC or Q for prompt, Enter for boot source
    Countdown.. 0
    MorphOS boot loader version 1.11
    Failed to scan partitions on device 1
    Booting from HDIMG0
    Trying to load "bootsam_ppc4x0.img" from "HDIMG0:"...
    Loaded "bootsam_ppc4x0.img" from "HDIMG0:", booting...
    MorphOS args: bootdevice HDIMG0
    Booting...
    Checkpoint A
    Checkpoint B
    Checkpoint C
    Checkpoint D
    Checkpoint E
    26308124683| Checkpoint 1
    26311579008| Checkpoint 2
    26314076282| Checkpoint 3
    26316747824| Checkpoint 4
    26319419978| Checkpoint 5
    26322095089| Checkpoint 6
    25.191| Checkpoint 7
    25.193| Checkpoint 7.1
    25.196| Checkpoint 7.2
    25.198| Checkpoint 7.3
    25.200| Checkpoint 7.4
    25.203| Checkpoint 7.5
    25.205| Checkpoint 7.6
    25.207| Checkpoint 7.6
    25.209| Checkpoint 7.7
    25.212| Checkpoint 7.8
    25.214| Checkpoint 7.9
    25.216| Checkpoint 7.10
    25.219| Checkpoint 7.11
    25.221| Checkpoint 7.12
    25.223| HAL_PCIScanBridgeTagList: Tags 0xfed0
    25.228| HAL_PCIScanBridgeTagList: BridgeID 0
    25.232| HAL_PCIScanBridgeTagList: No ConfigBase
    25.237| HAL_PCIScanBridgeTagList: No BridgeBase
    25.241| HAL_PCIScanBridgeTagList: No BridgeBase Size
    25.247| HAL_PCIScanBridgeTagList: No PMemoryBase
    25.251| HAL_PCIScanBridgeTagList: No PMemoryBaseSize
    25.256| HAL_PCIScanBridgeTagList: BridgeNode 0x9005f0
    25.262| HAL_PCIScanBridgeTagList: BridgeID 0x0
    25.266| HAL_PCIScanBridgeTagList: InterruptID 0x5000020
    25.272| HAL_PCIScanBusTagList: BusID 0
    25.275| HAL_PCIScanBusTagList: StartSlot 1
    25.280| HAL_PCIScanBusTagList: SlotCount 30
    25.284| HAL_PCIScanBusTagList: MemoryBase 0xd0000000 MemoryBaseSize 0x10000000 PMemoryBase 0x0 PMemoryBaseSize 0x0 IOBase 0xf40f0000 IOBaseSize 0x10000
    25.298| HAL_PCIScanBusTagList: BusNode 0x900670
    25.303| PCIScanBus: SlotID 1
    25.306| PCIScanBus: Device is not multifunction, skip additional functions
    25.313| PCIScanBus: Boardlist empty..freeSlot
    25.318| PCIScanBus: SlotID 2
    25.320| PCIScanBus: Device is not multifunction, skip additional functions
    25.328| PCIScanBus: Boardlist empty..freeSlot
    25.332| PCIScanBus: SlotID 3
    25.335| PCIScanBus: Device is not multifunction, skip additional functions
    25.342| PCIScanBus: Boardlist empty..freeSlot
    25.347| PCIScanBus: SlotID 4
    25.350| PCIScanBus: Device is not multifunction, skip additional functions
    25.357| PCIScanBus: Boardlist empty..freeSlot
    25.361| PCIScanBus: SlotID 5
    25.364| PCIScanBus: Device is not multifunction, skip additional functions
    25.371| PCIScanBus: Boardlist empty..freeSlot
    25.376| PCIScanBus: SlotID 6
    25.379| PCIScanBus: Device is not multifunction, skip additional functions
    25.386| PCIScanBus: Boardlist empty..freeSlot
    25.390| PCIScanBus: SlotID 7
    25.393| PCIScanBus: Device is not multifunction, skip additional functions
    25.400| PCIScanBus: Boardlist empty..freeSlot
    25.405| PCIScanBus: SlotID 8
    25.408| PCIScanBus: Device is not multifunction, skip additional functions
    25.415| PCIScanBus: Boardlist empty..freeSlot
    25.420| PCIScanBus: SlotID 9
    25.422| PCIScanBus: Device is not multifunction, skip additional functions
    25.430| PCIScanBus: Boardlist empty..freeSlot
    25.434| PCIScanBus: SlotID 10
    25.437| PCIScanBus: Device is not multifunction, skip additional functions
    25.444| PCIScanBus: Boardlist empty..freeSlot
    25.449| PCIScanBus: SlotID 11
    25.452| PCIScanBus: Device is not multifunction, skip additional functions
    25.459| PCIScanBus: Boardlist empty..freeSlot
    25.464| PCIScanBus: SlotID 12
    25.466| PCIScanBus: Device is not multifunction, skip additional functions
    25.474| PCIScanBus: Boardlist empty..freeSlot
    25.478| PCIScanBus: SlotID 13
    25.481| PCIScanBus: Device is not multifunction, skip additional functions
    25.488| PCIScanBus: Boardlist empty..freeSlot
    25.493| PCIScanBus: SlotID 14
    25.496| PCIScanBus: Device is not multifunction, skip additional functions
    25.503| PCIScanBus: Boardlist empty..freeSlot
    25.508| PCIScanBus: SlotID 15
    25.511| PCIScanBus: Device is not multifunction, skip additional functions
    25.518| PCIScanBus: Boardlist empty..freeSlot
    25.522| PCIScanBus: SlotID 16
    25.525| PCIScanBus: Device is not multifunction, skip additional functions
    25.532| PCIScanBus: Boardlist empty..freeSlot
    25.537| PCIScanBus: SlotID 17
    25.540| PCIScanBus: Device is not multifunction, skip additional functions
    25.547| PCIScanBus: Boardlist empty..freeSlot
    25.552| PCIScanBus: SlotID 18
    25.555| PCIScanBus: Device is not multifunction, skip additional functions
    25.562| PCIScanBus: Boardlist empty..freeSlot
    25.566| PCIScanBus: SlotID 19
    25.569| PCIScanBus: Device is not multifunction, skip additional functions
    25.576| PCIScanBus: Boardlist empty..freeSlot
    25.581| PCIScanBus: SlotID 20
    25.584| PCIScanBus: Device is not multifunction, skip additional functions
    25.591| PCIScanBus: Boardlist empty..freeSlot
    25.596| PCIScanBus: SlotID 21
    25.599| PCIScanBus: Device is not multifunction, skip additional functions
    25.606| PCIScanBus: Boardlist empty..freeSlot
    25.610| PCIScanBus: SlotID 22
    25.613| PCIScanBus: Device is not multifunction, skip additional functions
    25.620| PCIScanBus: Boardlist empty..freeSlot
    25.625| PCIScanBus: SlotID 23
    25.628| PCIScanBus: Device is not multifunction, skip additional functions
    25.635| PCIScanBus: Boardlist empty..freeSlot
    25.640| PCIScanBus: SlotID 24
    25.643| PCIScanBus: Device is not multifunction, skip additional functions
    25.650| PCIScanBus: Boardlist empty..freeSlot
    25.654| PCIScanBus: SlotID 25
    25.657| PCIScanBus: Device is not multifunction, skip additional functions
    25.664| PCIScanBus: Boardlist empty..freeSlot
    25.669| PCIScanBus: SlotID 26
    25.672| PCIScanBus: Device is not multifunction, skip additional functions
    25.679| PCIScanBus: Boardlist empty..freeSlot
    25.684| PCIScanBus: SlotID 27
    25.687| PCIScanBus: Device is not multifunction, skip additional functions
    25.694| PCIScanBus: Boardlist empty..freeSlot
    25.698| PCIScanBus: SlotID 28
    25.701| PCIScanBus: Device is not multifunction, skip additional functions
    25.709| PCIScanBus: Boardlist empty..freeSlot
    25.713| PCIScanBus: SlotID 29
    25.716| PCIScanBus: Device is not multifunction, skip additional functions
    25.723| PCIScanBus: Boardlist empty..freeSlot
    25.728| PCIScanBus: SlotID 30
    25.731| PCIScanBus: Device is not multifunction, skip additional functions
    25.738| PCIScanBus: Boardlist empty..freeSlot
    25.742| HAL_PCIScanBusTagList: MemoryBaseAlignment 0x00000000
    25.748| HAL_PCIScanBusTagList: return BusNode 0x900670
    25.754| HAL_PCIMapBusTagList:
    25.757| HAL_PCIMapBusTagList: Map Memory
    25.761| HAL_PCIMapMemoryTagList: BusNode 0x900670 BusID 0
    25.766| HAL_PCIMapMemoryTagList: Root bus is 0, MemoryBasePtr d0000000
    25.773| HAL_PCIMapBusTagList: Result 1
    25.777| HAL_PCIMapBusTagList: Map Memory64
    25.781| HAL_PCIMapMemory64TagList: BusNode 0x900670 BusID 0
    25.787| HAL_PCIMapBusTagList: Result 1
    25.791| HAL_PCIMapBusTagList: Map Rom
    25.794| HAL_PCIMapRomTagList:
    25.797| HAL_PCIMapRomTagList: done
    25.801| HAL_PCIMapBusTagList: Result 1
    25.804| HAL_PCIMapBusTagList: Map IO
    25.808| HAL_PCIMapIOTagList: BusNode 0x900670 BusID 0 IOBase 0xf40f0000 IOBasePtr 0xf40f1000
    25.817| HAL_PCIMapIOTagList: Root bus is 0, IOBasePtr f40f1000
    25.823| HAL_PCIMapBusTagList: Result 1
    25.827| Bridge 0: Memory 0xd0000000 - 0xdfffffff, IO 0xf40f0000 - 0xf40fffff
    25.834| Bus 0: Memory 0xd0000000 - 0xdfffffff, IO 0xf40f0000 - 0xf40fffff
    25.841| Checkpoint 7.13
    25.844| HAL_PCIScanBridgeTagList: Tags 0xfed0
    25.848| HAL_PCIScanBridgeTagList: BridgeID 1
    25.853| HAL_PCIScanBridgeTagList: No ConfigBase
    25.857| HAL_PCIScanBridgeTagList: No BridgeBase
    25.862| HAL_PCIScanBridgeTagList: No BridgeBase Size
    25.867| HAL_PCIScanBridgeTagList: No PMemoryBase
    25.872| HAL_PCIScanBridgeTagList: No PMemoryBaseSize
    25.877| HAL_PCIScanBridgeTagList: BridgeNode 0x900800
    25.882| HAL_PCIScanBridgeTagList: BridgeID 0x1
    25.887| HAL_PCIScanBridgeTagList: InterruptID 0x5000066
    25.892| HAL_PCIScanBusTagList: BusID 0
    25.896| HAL_PCIScanBusTagList: StartSlot 0
    25.900| HAL_PCIScanBusTagList: SlotCount 31
    25.904| HAL_PCIScanBusTagList: MemoryBase 0xa0000000 MemoryBaseSize 0x20000000 PMemoryBase 0x0 PMemoryBaseSize 0x0 IOBase 0x89000000 IOBaseSize 0x10000
    25.919| HAL_PCIScanBusTagList: BusNode 0x900880
    25.923| PCIScanBus: SlotID 0
    25.926| PCIScanBus: Function 0 VendorID 0x1002 DeviceID 0x7280
    25.932| PCIScanBus: BoardNode 0x900a54
    25.936| PCIScanBus: HeaderType 0x80
    25.940| PCIScanBus: ClassID 0x3 SubClassID 0x0 ProgInfo 0x0
    25.946| PCIScanBus: 1st Function
    25.949| PCIScanBase on BusID 0 SlotID 0 FunctionID 0
    25.954| PCIScanBase@0: --Oldbase = 0xa000000c
    25.959| PCIScanBase@0: Base=0xf000000c
    25.963| PCIScanBase@0: MEM
    25.965| PCIScanBase@0: nocache
    25.969| PCIScanBase@0: MEMORY 32Bit
    25.972| PCIScanBase@0: BaseAddress 0xf000000c Size 0xffffff0
    25.979| PCIScanBase@0: aligned Size 0x10000000
    25.983| PCIScanBase@0: MapNode 0x900ae0
    25.987| PCIScanBase@0: Size 0x0 Type 0x0 CacheMode 0x0
    25.993| PCIScanBase@2: --Oldbase = 0xb0000004
    25.997| PCIScanBase@2: Base=0xffff0004
    26.001| PCIScanBase@2: MEM
    26.004| PCIScanBase@2: nocachesync
    26.008| PCIScanBase@2: MEMORY 32Bit
    26.012| PCIScanBase@2: BaseAddress 0xffff0004 Size 0xfff0
    26.017| PCIScanBase@2: aligned Size 0x10000
    26.022| PCIScanBase@2: MapNode 0x900b10
    26.026| PCIScanBase@2: Size 0x2 Type 0x0 CacheMode 0x0
    26.031| PCIScanBase@4: --Oldbase = 0x2001
    26.036| PCIScanBase@4: Base=0xffffff01
    26.039| PCIScanBase@4: IO
    26.042| PCIScanBase@4: BaseAddress 0xffffff00 Size 0xffffffff00000100
    26.049| PCIScanBase@4: aligned Size 0x1000
    26.054| PCIScanBase@4: MapNode 0x900b40
    26.058| PCIScanBase@4: Size 0x4 Type 0x0 CacheMode 0x0
    26.063| PCIScanBase@5: --Oldbase = 0x0
    26.067| PCIScanBase@5: size == 0
    26.070| PCIScanBase@6: Rom=0x0
    26.074| PCIScanBase@6: RomBaseAddress 0xfffe0000 Size 0x20000
    26.080| PCIScanBase@6: aligned Size 0x20000
    26.084| PCIScanBase@6: MapNode 0x900b70
    26.088| PCIScanBase@6: Index 8 Size 0x0 Type 0x0 CacheMode 0x20000
    26.095| PCIScanBus: BaseScan ok
    26.098| PCIScanBus: AddBoardNode(MySlotNode 0x900a14 MyBoardNode 0x900a54)
    26.106| PCIScanBus: AddSlotNode
    26.109| PCIScanBus: SlotID 1
    26.112| PCIScanBus: Boardlist empty..freeSlot
    26.116| PCIScanBus: SlotID 2
    26.119| PCIScanBus: Boardlist empty..freeSlot
    26.124| PCIScanBus: SlotID 3
    26.127| PCIScanBus: Boardlist empty..freeSlot
    26.131| PCIScanBus: SlotID 4
    26.134| PCIScanBus: Boardlist empty..freeSlot
    26.138| PCIScanBus: SlotID 5
    26.141| PCIScanBus: Boardlist empty..freeSlot
    26.146| PCIScanBus: SlotID 6
    26.149| PCIScanBus: Boardlist empty..freeSlot
    26.153| PCIScanBus: SlotID 7
    26.156| PCIScanBus: Boardlist empty..freeSlot
    26.161| PCIScanBus: SlotID 8
    26.163| PCIScanBus: Boardlist empty..freeSlot
    26.168| PCIScanBus: SlotID 9
    26.171| PCIScanBus: Boardlist empty..freeSlot
    26.175| PCIScanBus: SlotID 10
    26.178| PCIScanBus: Boardlist empty..freeSlot
    26.183| PCIScanBus: SlotID 11
    26.186| PCIScanBus: Boardlist empty..freeSlot
    26.190| PCIScanBus: SlotID 12
    26.193| PCIScanBus: Boardlist empty..freeSlot
    26.198| PCIScanBus: SlotID 13
    26.201| PCIScanBus: Boardlist empty..freeSlot
    26.205| PCIScanBus: SlotID 14
    26.208| PCIScanBus: Boardlist empty..freeSlot
    26.213| PCIScanBus: SlotID 15
    26.216| PCIScanBus: Boardlist empty..freeSlot
    26.220| PCIScanBus: SlotID 16
    26.223| PCIScanBus: Boardlist empty..freeSlot
    26.228| PCIScanBus: SlotID 17
    26.231| PCIScanBus: Boardlist empty..freeSlot
    26.235| PCIScanBus: SlotID 18
    26.238| PCIScanBus: Boardlist empty..freeSlot
    26.243| PCIScanBus: SlotID 19
    26.246| PCIScanBus: Boardlist empty..freeSlot
    26.250| PCIScanBus: SlotID 20
    26.253| PCIScanBus: Boardlist empty..freeSlot
    26.258| PCIScanBus: SlotID 21
    26.261| PCIScanBus: Boardlist empty..freeSlot
    26.265| PCIScanBus: SlotID 22
    26.268| PCIScanBus: Boardlist empty..freeSlot
    26.273| PCIScanBus: SlotID 23
    26.276| PCIScanBus: Boardlist empty..freeSlot
    26.280| PCIScanBus: SlotID 24
    26.283| PCIScanBus: Boardlist empty..freeSlot
    26.288| PCIScanBus: SlotID 25
    26.291| PCIScanBus: Boardlist empty..freeSlot
    26.295| PCIScanBus: SlotID 26
    26.298| PCIScanBus: Boardlist empty..freeSlot
    26.303| PCIScanBus: SlotID 27
    26.305| PCIScanBus: Boardlist empty..freeSlot
    26.310| PCIScanBus: SlotID 28
    26.313| PCIScanBus: Boardlist empty..freeSlot
    26.318| PCIScanBus: SlotID 29
    26.320| PCIScanBus: Boardlist empty..freeSlot
    26.325| PCIScanBus: SlotID 30
    26.328| PCIScanBus: Boardlist empty..freeSlot
    26.332| HAL_PCIScanBusTagList: Bus child device requires alignment 0x10000000
    26.340| HAL_PCIScanBusTagList: MemoryBaseAlignment 0x10000000
    26.346| HAL_PCIScanBusTagList: return BusNode 0x900880
    26.351| HAL_PCIMapBusTagList:
    26.354| HAL_PCIMapBusTagList: Map Memory
    26.358| HAL_PCIMapMemoryTagList: BusNode 0x900880 BusID 0
    26.364| HAL_PCIMapMemoryTagList: Root bus is 0, MemoryBasePtr a0000000
    26.371| HAL_PCIMapMemoryTagList: Bus 0 requires alignment 00000000
    26.377| HAL_PCIMapMemoryTagList: LowerAddress a0000000
    26.382| HAL_PCIMapMemoryTagList: CurrentMapNode 0x900ae0
    26.388| HAL_PCIMapMemoryTagList: Index 0 Size 0x10000000 Type 0x1
    26.394| HAL_PCIMapMemoryTagList: Address 0xa0000000 Size 0x10000000
    26.401| HAL_PCIMapMemoryTagList: CurrentBoardNode(0x900a54) BusID 0 SlotID 0 DeviceID 0, CurrentMapNode at 0x900ae0
    26.412| HAL_PCIMapMemoryTagList: BusNode 0x900880 SlotNode 0x900a14 BoardNode 0x900a54
    26.420| HAL_PCIMapMemoryTagList: map base
    26.424| HAL_PCIMapMemoryTagList: = 0xa000000c
    26.429| HAL_PCIMapMemoryTagList: done
    26.432| HAL_PCIMapMemoryTagList: CurrentMapNode 0x900b70
    26.438| HAL_PCIMapMemoryTagList: Index 8 Size 0x20000 Type 0x1
    26.444| HAL_PCIMapMemoryTagList: Address 0xb0000000 Size 0x20000
    26.450| HAL_PCIMapMemoryTagList: CurrentBoardNode(0x900a54) BusID 0 SlotID 0 DeviceID 0, CurrentMapNode at 0x900b70
    26.461| HAL_PCIMapMemoryTagList: BusNode 0x900880 SlotNode 0x900a14 BoardNode 0x900a54
    26.470| HAL_PCIMapMemoryTagList: map base
    26.474| HAL_PCIMapMemoryTagList: = 0xb0000000
    26.478| HAL_PCIMapMemoryTagList: done
    26.482| HAL_PCIMapMemoryTagList: CurrentMapNode 0x900b10
    26.487| HAL_PCIMapMemoryTagList: Index 2 Size 0x10000 Type 0x1
    26.493| HAL_PCIMapMemoryTagList: Address 0xb0020000 Size 0x10000
    26.500| HAL_PCIMapMemoryTagList: CurrentBoardNode(0x900a54) BusID 0 SlotID 0 DeviceID 0, CurrentMapNode at 0x900b10
    26.511| HAL_PCIMapMemoryTagList: BusNode 0x900880 SlotNode 0x900a14 BoardNode 0x900a54
    26.519| HAL_PCIMapMemoryTagList: map base
    26.523| HAL_PCIMapMemoryTagList: = 0xb0020004
    26.527| HAL_PCIMapMemoryTagList: done
    26.531| HAL_PCIMapBusTagList: Result 1
    26.535| HAL_PCIMapBusTagList: Map Memory64
    26.539| HAL_PCIMapMemory64TagList: BusNode 0x900880 BusID 0
    26.545| HAL_PCIMapBusTagList: Result 1
    26.549| HAL_PCIMapBusTagList: Map Rom
    26.552| HAL_PCIMapRomTagList:
    26.555| HAL_PCIMapRomTagList: SlotNode 0x900a14
    26.560| HAL_PCIMapRomTagList: BoardNode 0x900a54
    26.565| HAL_PCIMapRomTagList: MapNode 0x900ae0 Index 0
    26.570| HAL_PCIMapRomTagList: no MAPTYPE_ROM
    26.574| HAL_PCIMapRomTagList: MapNode 0x900b10 Index 2
    26.580| HAL_PCIMapRomTagList: no MAPTYPE_ROM
    26.584| HAL_PCIMapRomTagList: MapNode 0x900b40 Index 4
    26.589| HAL_PCIMapRomTagList: no MAPTYPE_ROM
    26.594| HAL_PCIMapRomTagList: MapNode 0x900b70 Index 8
    26.599| HAL_PCIMapRomTagList: no MAPTYPE_ROM
    26.603| HAL_PCIMapRomTagList: done
    26.607| HAL_PCIMapBusTagList: Result 1
    26.611| HAL_PCIMapBusTagList: Map IO
    26.614| HAL_PCIMapIOTagList: BusNode 0x900880 BusID 0 IOBase 0x89000000 IOBasePtr 0x89001000
    26.623| HAL_PCIMapIOTagList: Root bus is 0, IOBasePtr 89001000
    26.629| HAL_PCIMapIOTagList: CurrentMapNode 0x900b40
    26.634| HAL_PCIMapIOTagList: Index 4 Size 0x1000 Type 0x0 IOBasePtr 0x89001000
    26.642| HAL_PCIMapIOTagList: Address 0x89001000 Size 0x1000
    26.648| HAL_PCIMapIOTagList: CurrentBoardNode(0x900a54) BusID 0 SlotID 0 DeviceID 0, CurrentMapNode at 0x900b40
    26.658| HAL_PCIMapIOTagList: map base
    26.662| HAL_PCIMapIOTagList: baseaddress entry set to 0x1000
    26.668| HAL_PCIMapIOTagList: = 0x1001
    26.672| HAL_PCIMapIOTagList: done
    26.675| HAL_PCIMapBusTagList: Result 1
    26.679| Bridge 1: Memory 0xa0000000 - 0xbfffffff, IO 0x89000000 - 0x8900ffff
    26.686| Bus 0: Memory 0xa0000000 - 0xbfffffff, IO 0x89000000 - 0x8900ffff
    26.693| Slot 0:
    26.696| Board 0: Vendor 0x1002, Device 0x7280, Command 0x0007
    26.702| Map 0: Type 1, Size 0x10000000, Address 0xa0000000
    26.709| Map 1: Type 1, Size 0x00010000, Address 0xb0020000
    26.716| Map 2: Type 0, Size 0x00001000, Address 0x89001000
    26.723| Map 3: Type 1, Size 0x00020000, Address 0xb0000000
    26.730| Checkpoint 7.14
    26.732| HAL_PCIScanBridgeTagList: Tags 0xfed0
    26.736| HAL_PCIScanBridgeTagList: BridgeID 2
    26.741| HAL_PCIScanBridgeTagList: No ConfigBase
    26.745| HAL_PCIScanBridgeTagList: No BridgeBase
    26.750| HAL_PCIScanBridgeTagList: No BridgeBase Size
    26.755| HAL_PCIScanBridgeTagList: No PMemoryBase
    26.760| HAL_PCIScanBridgeTagList: No PMemoryBaseSize
    26.765| HAL_PCIScanBridgeTagList: BridgeNode 0x900ba0
    26.770| HAL_PCIScanBridgeTagList: BridgeID 0x2
    26.775| HAL_PCIScanBridgeTagList: InterruptID 0x5000060
    26.780| HAL_PCIScanBusTagList: BusID 0
    26.784| HAL_PCIScanBusTagList: StartSlot 0
    26.788| HAL_PCIScanBusTagList: SlotCount 31
    26.792| HAL_PCIScanBusTagList: MemoryBase 0xc0000000 MemoryBaseSize 0x10000000 PMemoryBase 0x0 PMemoryBaseSize 0x0 IOBase 0x89000000 IOBaseSize 0x10000
    26.807| HAL_PCIScanBusTagList: BusNode 0x900c20
    26.812| PCIScanBus: SlotID 0
    26.814| PCIScanBus: Function 0 VendorID 0x1b21 DeviceID 0x1080
    26.820| PCIScanBus: BoardNode 0x900df4
    26.824| PCIScanBus: HeaderType 0x1
    26.828| PCIScanBus: ClassID 0x6 SubClassID 0x4 ProgInfo 0x0
    26.834| PCIScanBus: Bridge
    26.837| PCIScanBus: 1st Function
    26.840| PCIScanBus: PCI/PCI Bridge
    26.844| PCIScanBus: SubBusID 0x1
    26.847| HAL_PCIScanBusTagList: BusID 1
    26.851| HAL_PCIScanBusTagList: StartSlot 0
    26.855| HAL_PCIScanBusTagList: SlotCount 31
    26.859| HAL_PCIScanBusTagList: MemoryBase 0xc0000000 MemoryBaseSize 0x0 PMemoryBase 0x0 PMemoryBaseSize 0x0 IOBase 0x89000000 IOBaseSize 0x0
    26.873| HAL_PCIScanBusTagList: BusNode 0x900e80
    26.877| PCIScanBus: SlotID 0
    26.880| PCIScanBus: Device is not multifunction, skip additional functions
    26.887| PCIScanBus: Boardlist empty..freeSlot
    26.892| PCIScanBus: SlotID 1
    26.895| PCIScanBus: Device is not multifunction, skip additional functions
    26.902| PCIScanBus: Boardlist empty..freeSlot
    26.907| PCIScanBus: SlotID 2
    26.909| PCIScanBus: Device is not multifunction, skip additional functions
    26.917| PCIScanBus: Boardlist empty..freeSlot
    26.921| PCIScanBus: SlotID 3
    26.924| PCIScanBus: Device is not multifunction, skip additional functions
    26.931| PCIScanBus: Boardlist empty..freeSlot
    26.936| PCIScanBus: SlotID 4
    26.939| PCIScanBus: Device is not multifunction, skip additional functions
    26.946| PCIScanBus: Boardlist empty..freeSlot
    26.950| PCIScanBus: SlotID 5
    26.953| PCIScanBus: Device is not multifunction, skip additional functions
    26.960| PCIScanBus: Boardlist empty..freeSlot
    26.965| PCIScanBus: SlotID 6
    26.968| PCIScanBus: Device is not multifunction, skip additional functions
    26.975| PCIScanBus: Boardlist empty..freeSlot
    26.979| PCIScanBus: SlotID 7
    26.982| PCIScanBus: Device is not multifunction, skip additional functions
    26.989| PCIScanBus: Boardlist empty..freeSlot
    26.994| PCIScanBus: SlotID 8
    26.997| PCIScanBus: Device is not multifunction, skip additional functions
    27.004| PCIScanBus: Boardlist empty..freeSlot
    27.009| PCIScanBus: SlotID 9
    27.011| PCIScanBus: Device is not multifunction, skip additional functions
    27.019| PCIScanBus: Boardlist empty..freeSlot
    27.023| PCIScanBus: SlotID 10
    27.026| PCIScanBus: Device is not multifunction, skip additional functions
    27.033| PCIScanBus: Boardlist empty..freeSlot
    27.038| PCIScanBus: SlotID 11
    27.041| PCIScanBus: Device is not multifunction, skip additional functions
    27.048| PCIScanBus: Boardlist empty..freeSlot
    27.053| PCIScanBus: SlotID 12
    27.055| PCIScanBus: Device is not multifunction, skip additional functions
    27.063| PCIScanBus: Boardlist empty..freeSlot
    27.067| PCIScanBus: SlotID 13
    27.070| PCIScanBus: Device is not multifunction, skip additional functions
    27.077| PCIScanBus: Boardlist empty..freeSlot
    27.082| PCIScanBus: SlotID 14
    27.085| PCIScanBus: Device is not multifunction, skip additional functions
    27.092| PCIScanBus: Boardlist empty..freeSlot
    27.097| PCIScanBus: SlotID 15
    27.100| PCIScanBus: Device is not multifunction, skip additional functions
    27.107| PCIScanBus: Boardlist empty..freeSlot
    27.111| PCIScanBus: SlotID 16
    27.114| PCIScanBus: Device is not multifunction, skip additional functions
    27.121| PCIScanBus: Boardlist empty..freeSlot
    27.126| PCIScanBus: SlotID 17
    27.129| PCIScanBus: Device is not multifunction, skip additional functions
    27.136| PCIScanBus: Boardlist empty..freeSlot
    27.141| PCIScanBus: SlotID 18
    27.144| PCIScanBus: Device is not multifunction, skip additional functions
    27.151| PCIScanBus: Boardlist empty..freeSlot
    27.155| PCIScanBus: SlotID 19
    27.158| PCIScanBus: Device is not multifunction, skip additional functions
    27.165| PCIScanBus: Boardlist empty..freeSlot
    27.170| PCIScanBus: SlotID 20
    27.173| PCIScanBus: Device is not multifunction, skip additional functions
    27.180| PCIScanBus: Boardlist empty..freeSlot
    27.185| PCIScanBus: SlotID 21
    27.188| PCIScanBus: Device is not multifunction, skip additional functions
    27.195| PCIScanBus: Boardlist empty..freeSlot
    27.199| PCIScanBus: SlotID 22
    27.202| PCIScanBus: Device is not multifunction, skip additional functions
    27.209| PCIScanBus: Boardlist empty..freeSlot
    27.214| PCIScanBus: SlotID 23
    27.217| PCIScanBus: Device is not multifunction, skip additional functions
    27.224| PCIScanBus: Boardlist empty..freeSlot
    27.229| PCIScanBus: SlotID 24
    27.232| PCIScanBus: Device is not multifunction, skip additional functions
    27.239| PCIScanBus: Boardlist empty..freeSlot
    27.243| PCIScanBus: SlotID 25
    27.246| PCIScanBus: Device is not multifunction, skip additional functions
    27.254| PCIScanBus: Boardlist empty..freeSlot
    27.258| PCIScanBus: SlotID 26
    27.261| PCIScanBus: Device is not multifunction, skip additional functions
    27.268| PCIScanBus: Boardlist empty..freeSlot
    27.273| PCIScanBus: SlotID 27
    27.276| PCIScanBus: Device is not multifunction, skip additional functions
    27.283| PCIScanBus: Boardlist empty..freeSlot
    27.287| PCIScanBus: SlotID 28
    27.290| PCIScanBus: Device is not multifunction, skip additional functions
    27.298| PCIScanBus: Boardlist empty..freeSlot
    27.302| PCIScanBus: SlotID 29
    27.305| PCIScanBus: Device is not multifunction, skip additional functions
    27.312| PCIScanBus: Boardlist empty..freeSlot
    27.317| PCIScanBus: SlotID 30
    27.320| PCIScanBus: Device is not multifunction, skip additional functions
    27.327| PCIScanBus: Boardlist empty..freeSlot
    27.331| HAL_PCIScanBusTagList: MemoryBaseAlignment 0x00000000
    27.337| HAL_PCIScanBusTagList: return BusNode 0x900e80
    27.343| PCIScanBus: SubBusNode 0x900e80 0x1
    27.347| PCIScanBus: HighestBusID 0x1
    27.351| PCIScanBus: AddBoardNode(MySlotNode 0x900db4 MyBoardNode 0x900df4)
    27.358| PCIScanBus: Device is not multifunction, skip additional functions
    27.366| PCIScanBus: AddSlotNode
    27.369| PCIScanBus: SlotID 1
    27.372| PCIScanBus: Device is not multifunction, skip additional functions
    27.379| PCIScanBus: Boardlist empty..freeSlot
    27.383| PCIScanBus: SlotID 2
    27.386| PCIScanBus: Device is not multifunction, skip additional functions
    27.393| PCIScanBus: Boardlist empty..freeSlot
    27.398| PCIScanBus: SlotID 3
    27.401| PCIScanBus: Device is not multifunction, skip additional functions
    27.408| PCIScanBus: Boardlist empty..freeSlot
    27.413| PCIScanBus: SlotID 4
    27.415| PCIScanBus: Device is not multifunction, skip additional functions
    27.423| PCIScanBus: Boardlist empty..freeSlot
    27.427| PCIScanBus: SlotID 5
    27.430| PCIScanBus: Device is not multifunction, skip additional functions
    27.437| PCIScanBus: Boardlist empty..freeSlot
    27.442| PCIScanBus: SlotID 6
    27.445| PCIScanBus: Device is not multifunction, skip additional functions
    27.452| PCIScanBus: Boardlist empty..freeSlot
    27.456| PCIScanBus: SlotID 7
    27.459| PCIScanBus: Device is not multifunction, skip additional functions
    27.466| PCIScanBus: Boardlist empty..freeSlot
    27.471| PCIScanBus: SlotID 8
    27.474| PCIScanBus: Device is not multifunction, skip additional functions
    27.481| PCIScanBus: Boardlist empty..freeSlot
    27.485| PCIScanBus: SlotID 9
    27.488| PCIScanBus: Device is not multifunction, skip additional functions
    27.495| PCIScanBus: Boardlist empty..freeSlot
    27.500| PCIScanBus: SlotID 10
    27.503| PCIScanBus: Device is not multifunction, skip additional functions
    27.510| PCIScanBus: Boardlist empty..freeSlot
    27.515| PCIScanBus: SlotID 11
    27.518| PCIScanBus: Device is not multifunction, skip additional functions
    27.525| PCIScanBus: Boardlist empty..freeSlot
    27.529| PCIScanBus: SlotID 12
    27.532| PCIScanBus: Device is not multifunction, skip additional functions
    27.539| PCIScanBus: Boardlist empty..freeSlot
    27.544| PCIScanBus: SlotID 13
    27.547| PCIScanBus: Device is not multifunction, skip additional functions
    27.554| PCIScanBus: Boardlist empty..freeSlot
    27.559| PCIScanBus: SlotID 14
    27.562| PCIScanBus: Device is not multifunction, skip additional functions
    27.569| PCIScanBus: Boardlist empty..freeSlot
    27.573| PCIScanBus: SlotID 15
    27.576| PCIScanBus: Device is not multifunction, skip additional functions
    27.584| PCIScanBus: Boardlist empty..freeSlot
    27.588| PCIScanBus: SlotID 16
    27.591| PCIScanBus: Device is not multifunction, skip additional functions
    27.598| PCIScanBus: Boardlist empty..freeSlot
    27.603| PCIScanBus: SlotID 17
    27.606| PCIScanBus: Device is not multifunction, skip additional functions
    27.613| PCIScanBus: Boardlist empty..freeSlot
    27.617| PCIScanBus: SlotID 18
    27.620| PCIScanBus: Device is not multifunction, skip additional functions
    27.628| PCIScanBus: Boardlist empty..freeSlot
    27.632| PCIScanBus: SlotID 19
    27.635| PCIScanBus: Device is not multifunction, skip additional functions
    27.642| PCIScanBus: Boardlist empty..freeSlot
    27.647| PCIScanBus: SlotID 20
    27.650| PCIScanBus: Device is not multifunction, skip additional functions
    27.657| PCIScanBus: Boardlist empty..freeSlot
    27.661| PCIScanBus: SlotID 21
    27.664| PCIScanBus: Device is not multifunction, skip additional functions
    27.672| PCIScanBus: Boardlist empty..freeSlot
    27.676| PCIScanBus: SlotID 22
    27.679| PCIScanBus: Device is not multifunction, skip additional functions
    27.686| PCIScanBus: Boardlist empty..freeSlot
    27.691| PCIScanBus: SlotID 23
    27.694| PCIScanBus: Device is not multifunction, skip additional functions
    27.701| PCIScanBus: Boardlist empty..freeSlot
    27.705| PCIScanBus: SlotID 24
    27.708| PCIScanBus: Device is not multifunction, skip additional functions
    27.716| PCIScanBus: Boardlist empty..freeSlot
    27.720| PCIScanBus: SlotID 25
    27.723| PCIScanBus: Device is not multifunction, skip additional functions
    27.730| PCIScanBus: Boardlist empty..freeSlot
    27.735| PCIScanBus: SlotID 26
    27.738| PCIScanBus: Device is not multifunction, skip additional functions
    27.745| PCIScanBus: Boardlist empty..freeSlot
    27.750| PCIScanBus: SlotID 27
    27.752| PCIScanBus: Device is not multifunction, skip additional functions
    27.760| PCIScanBus: Boardlist empty..freeSlot
    27.764| PCIScanBus: SlotID 28
    27.767| PCIScanBus: Device is not multifunction, skip additional functions
    27.774| PCIScanBus: Boardlist empty..freeSlot
    27.779| PCIScanBus: SlotID 29
    27.782| PCIScanBus: Device is not multifunction, skip additional functions
    27.789| PCIScanBus: Boardlist empty..freeSlot
    27.794| PCIScanBus: SlotID 30
    27.797| PCIScanBus: Device is not multifunction, skip additional functions
    27.804| PCIScanBus: Boardlist empty..freeSlot
    27.808| HAL_PCIScanBusTagList: MemoryBaseAlignment 0x00000000
    27.814| HAL_PCIScanBusTagList: return BusNode 0x900c20
    27.820| HAL_PCIMapBusTagList:
    27.822| HAL_PCIFindLargestUnmappedChildBusNode: Bus child bus requires alignment 0x00000000
    27.831| HAL_PCIMapBusTagList: Mapping child bus node 1
    27.837| HAL_PCIMapBusTagList:
    27.839| HAL_PCIMapBusTagList: Setting up PCI bases for subbus 1 (0.0.0) BoardNode 00900df4 IOBase 89000000 IOBaseSize 00000000
    27.852| HAL_PCIMapBusTagList: Map Memory
    27.856| HAL_PCIMapMemoryTagList: BusNode 0x900e80 BusID 1
    27.861| HAL_PCIMapMemoryTagList: Root bus is 0, MemoryBasePtr c0000000
    27.868| HAL_PCIMapMemoryTagList: BusID 1 (0.0.0) has no memory mappings and no sub bridges that do. Disabling memory requests for this bridge.
    27.882| HAL_PCIMapBusTagList: Result 1
    27.885| HAL_PCIMapBusTagList: Map Memory64
    27.890| HAL_PCIMapMemory64TagList: BusNode 0x900e80 BusID 1
    27.895| HAL_PCIMapBusTagList: Result 1
    27.899| HAL_PCIMapBusTagList: Map Rom
    27.903| HAL_PCIMapRomTagList:
    27.906| HAL_PCIMapRomTagList: done
    27.909| HAL_PCIMapBusTagList: Result 1
    27.913| HAL_PCIMapBusTagList: Map IO
    27.917| HAL_PCIMapIOTagList: BusNode 0x900e80 BusID 1 IOBase 0x89000000 IOBasePtr 0x89000000
    27.925| HAL_PCIMapIOTagList: Root bus is 0, IOBasePtr 89001000
    27.932| HAL_PCIMapIOTagList: Setting up IO space for subbus 1 (0.0.0) BoardNode 00900df4 IOBase 89000000 IOBaseSize 00000000
    27.943| HAL_PCIMapIOTagList: BusID 1 (0.0.0) has no IO mappings and no sub bridges that do. Disabling memory requests for this bridge.
    27.956| HAL_PCIMapBusTagList: Result 1
    27.960| HAL_PCIMapBusTagList: Map Memory
    27.964| HAL_PCIMapMemoryTagList: BusNode 0x900c20 BusID 0
    27.970| HAL_PCIMapMemoryTagList: Root bus is 0, MemoryBasePtr c0000000
    27.977| HAL_PCIMapBusTagList: Result 1
    27.980| HAL_PCIMapBusTagList: Map Memory64
    27.984| HAL_PCIMapMemory64TagList: BusNode 0x900c20 BusID 0
    27.990| HAL_PCIMapBusTagList: Result 1
    27.994| HAL_PCIMapBusTagList: Map Rom
    27.998| HAL_PCIMapRomTagList:
    28.001| HAL_PCIMapRomTagList: SlotNode 0x900db4
    28.005| HAL_PCIMapRomTagList: BoardNode 0x900df4
    28.010| HAL_PCIMapRomTagList: done
    28.013| HAL_PCIMapBusTagList: Result 1
    28.017| HAL_PCIMapBusTagList: Map IO
    28.021| HAL_PCIMapIOTagList: BusNode 0x900c20 BusID 0 IOBase 0x89000000 IOBasePtr 0x89001000
    28.030| HAL_PCIMapIOTagList: Root bus is 0, IOBasePtr 89001000
    28.036| HAL_PCIMapBusTagList: Result 1
    28.040| Bridge 2: Memory 0xc0000000 - 0xcfffffff, IO 0x89000000 - 0x8900ffff
    28.047| Bus 0: Memory 0xc0000000 - 0xcfffffff, IO 0x89000000 - 0x8900ffff
    28.054| Slot 0:
    28.057| Board 0: Vendor 0x1b21, Device 0x1080, Command 0x0007
    28.063| Bus 1: Memory 0xc0000000 - 0xbfffffff, IO 0x89000000 - 0x88ffffff
    28.072| Checkpoint 7.15
    28.074| Checkpoint 8
    28.076| Checkpoint 9
    28.079| Checkpoint 10
    28.089|
    28.090|
    28.091| ABox 1.30 (2.7.2018) ▒ 1999-2022 by Ralph Schmidt, Emmanuel Lesueur, Teemu Suikki, Harry Sintonen
    29.988| usbscsi.device@0: Mount <HDIMG0>
    29.992| usbscsi.device@0: Partition <HDIMG0> DosType 0x444f5307 BootPri 15
    32.479| Radeon: Don't know how to initialise the memory controller of this Radeon
    32.487| Radeon: Memory size adjusted to 256MB
  • »15.07.23 - 16:47
    And here's the same output with morphosargs, part 1:
    ] setenv morphosargs qdebugflags init edebugflags init
    ] boota
    Booting from HDIMG0
    MorphOS args: qdebugflags init edebugflags init bootdevice HDIMG0
    Booting...
    Checkpoint A
    Checkpoint B
    Checkpoint C
    Checkpoint D
    Checkpoint E
    61797670893| Checkpoint 1
    61801125088| Checkpoint 2
    61803622142| Checkpoint 3
    61806293774| Checkpoint 4
    61808965993| Checkpoint 5
    61811641034| Checkpoint 6
    59.152| Checkpoint 7
    59.155| Checkpoint 7.1
    59.157| Checkpoint 7.2
    59.159| Checkpoint 7.3
    59.162| Checkpoint 7.4
    59.164| Checkpoint 7.5
    59.166| Checkpoint 7.6
    59.168| Checkpoint 7.6
    59.171| Checkpoint 7.7
    59.173| Checkpoint 7.8
    59.175| Checkpoint 7.9
    59.178| Checkpoint 7.10
    59.180| Checkpoint 7.11
    59.182| Checkpoint 7.12
    59.185| HAL_PCIScanBridgeTagList: Tags 0xfed0
    59.189| HAL_PCIScanBridgeTagList: BridgeID 0
    59.193| HAL_PCIScanBridgeTagList: No ConfigBase
    59.198| HAL_PCIScanBridgeTagList: No BridgeBase
    59.203| HAL_PCIScanBridgeTagList: No BridgeBase Size
    59.208| HAL_PCIScanBridgeTagList: No PMemoryBase
    59.213| HAL_PCIScanBridgeTagList: No PMemoryBaseSize
    59.218| HAL_PCIScanBridgeTagList: BridgeNode 0x9005f0
    59.223| HAL_PCIScanBridgeTagList: BridgeID 0x0
    59.227| HAL_PCIScanBridgeTagList: InterruptID 0x5000020
    59.233| HAL_PCIScanBusTagList: BusID 0
    59.237| HAL_PCIScanBusTagList: StartSlot 1
    59.241| HAL_PCIScanBusTagList: SlotCount 30
    59.245| HAL_PCIScanBusTagList: MemoryBase 0xd0000000 MemoryBaseSize 0x10000000 PMemoryBase 0x0 PMemoryBaseSize 0x0 IOBase 0xf40f0000 IOBaseSize 0x10000
    59.260| HAL_PCIScanBusTagList: BusNode 0x900670
    59.264| PCIScanBus: SlotID 1
    59.267| PCIScanBus: Device is not multifunction, skip additional functions
    59.274| PCIScanBus: Boardlist empty..freeSlot
    59.279| PCIScanBus: SlotID 2
    59.282| PCIScanBus: Device is not multifunction, skip additional functions
    59.289| PCIScanBus: Boardlist empty..freeSlot
    59.293| PCIScanBus: SlotID 3
    59.296| PCIScanBus: Device is not multifunction, skip additional functions
    59.303| PCIScanBus: Boardlist empty..freeSlot
    59.308| PCIScanBus: SlotID 4
    59.311| PCIScanBus: Device is not multifunction, skip additional functions
    59.318| PCIScanBus: Boardlist empty..freeSlot
    59.323| PCIScanBus: SlotID 5
    59.325| PCIScanBus: Device is not multifunction, skip additional functions
    59.333| PCIScanBus: Boardlist empty..freeSlot
    59.337| PCIScanBus: SlotID 6
    59.340| PCIScanBus: Device is not multifunction, skip additional functions
    59.347| PCIScanBus: Boardlist empty..freeSlot
    59.352| PCIScanBus: SlotID 7
    59.355| PCIScanBus: Device is not multifunction, skip additional functions
    59.362| PCIScanBus: Boardlist empty..freeSlot
    59.366| PCIScanBus: SlotID 8
    59.369| PCIScanBus: Device is not multifunction, skip additional functions
    59.376| PCIScanBus: Boardlist empty..freeSlot
    59.381| PCIScanBus: SlotID 9
    59.384| PCIScanBus: Device is not multifunction, skip additional functions
    59.391| PCIScanBus: Boardlist empty..freeSlot
    59.395| PCIScanBus: SlotID 10
    59.398| PCIScanBus: Device is not multifunction, skip additional functions
    59.406| PCIScanBus: Boardlist empty..freeSlot
    59.410| PCIScanBus: SlotID 11
    59.413| PCIScanBus: Device is not multifunction, skip additional functions
    59.420| PCIScanBus: Boardlist empty..freeSlot
    59.425| PCIScanBus: SlotID 12
    59.428| PCIScanBus: Device is not multifunction, skip additional functions
    59.435| PCIScanBus: Boardlist empty..freeSlot
    59.440| PCIScanBus: SlotID 13
    59.442| PCIScanBus: Device is not multifunction, skip additional functions
    59.450| PCIScanBus: Boardlist empty..freeSlot
    59.454| PCIScanBus: SlotID 14
    59.457| PCIScanBus: Device is not multifunction, skip additional functions
    59.464| PCIScanBus: Boardlist empty..freeSlot
    59.469| PCIScanBus: SlotID 15
    59.472| PCIScanBus: Device is not multifunction, skip additional functions
    59.479| PCIScanBus: Boardlist empty..freeSlot
    59.484| PCIScanBus: SlotID 16
    59.486| PCIScanBus: Device is not multifunction, skip additional functions
    59.494| PCIScanBus: Boardlist empty..freeSlot
    59.498| PCIScanBus: SlotID 17
    59.501| PCIScanBus: Device is not multifunction, skip additional functions
    59.508| PCIScanBus: Boardlist empty..freeSlot
    59.513| PCIScanBus: SlotID 18
    59.516| PCIScanBus: Device is not multifunction, skip additional functions
    59.523| PCIScanBus: Boardlist empty..freeSlot
    59.528| PCIScanBus: SlotID 19
    59.531| PCIScanBus: Device is not multifunction, skip additional functions
    59.538| PCIScanBus: Boardlist empty..freeSlot
    59.542| PCIScanBus: SlotID 20
    59.545| PCIScanBus: Device is not multifunction, skip additional functions
    59.552| PCIScanBus: Boardlist empty..freeSlot
    59.557| PCIScanBus: SlotID 21
    59.560| PCIScanBus: Device is not multifunction, skip additional functions
    59.567| PCIScanBus: Boardlist empty..freeSlot
    59.572| PCIScanBus: SlotID 22
    59.575| PCIScanBus: Device is not multifunction, skip additional functions
    59.582| PCIScanBus: Boardlist empty..freeSlot
    59.586| PCIScanBus: SlotID 23
    59.589| PCIScanBus: Device is not multifunction, skip additional functions
    59.596| PCIScanBus: Boardlist empty..freeSlot
    59.601| PCIScanBus: SlotID 24
    59.604| PCIScanBus: Device is not multifunction, skip additional functions
    59.611| PCIScanBus: Boardlist empty..freeSlot
    59.616| PCIScanBus: SlotID 25
    59.619| PCIScanBus: Device is not multifunction, skip additional functions
    59.626| PCIScanBus: Boardlist empty..freeSlot
    59.630| PCIScanBus: SlotID 26
    59.633| PCIScanBus: Device is not multifunction, skip additional functions
    59.640| PCIScanBus: Boardlist empty..freeSlot
    59.645| PCIScanBus: SlotID 27
    59.648| PCIScanBus: Device is not multifunction, skip additional functions
    59.655| PCIScanBus: Boardlist empty..freeSlot
    59.660| PCIScanBus: SlotID 28
    59.663| PCIScanBus: Device is not multifunction, skip additional functions
    59.670| PCIScanBus: Boardlist empty..freeSlot
    59.674| PCIScanBus: SlotID 29
    59.677| PCIScanBus: Device is not multifunction, skip additional functions
    59.684| PCIScanBus: Boardlist empty..freeSlot
    59.689| PCIScanBus: SlotID 30
    59.692| PCIScanBus: Device is not multifunction, skip additional functions
    59.699| PCIScanBus: Boardlist empty..freeSlot
    59.704| HAL_PCIScanBusTagList: MemoryBaseAlignment 0x00000000
    59.710| HAL_PCIScanBusTagList: return BusNode 0x900670
    59.715| HAL_PCIMapBusTagList:
    59.718| HAL_PCIMapBusTagList: Map Memory
    59.722| HAL_PCIMapMemoryTagList: BusNode 0x900670 BusID 0
    59.727| HAL_PCIMapMemoryTagList: Root bus is 0, MemoryBasePtr d0000000
    59.734| HAL_PCIMapBusTagList: Result 1
    59.738| HAL_PCIMapBusTagList: Map Memory64
    59.742| HAL_PCIMapMemory64TagList: BusNode 0x900670 BusID 0
    59.748| HAL_PCIMapBusTagList: Result 1
    59.752| HAL_PCIMapBusTagList: Map Rom
    59.756| HAL_PCIMapRomTagList:
    59.758| HAL_PCIMapRomTagList: done
    59.762| HAL_PCIMapBusTagList: Result 1
    59.766| HAL_PCIMapBusTagList: Map IO
    59.769| HAL_PCIMapIOTagList: BusNode 0x900670 BusID 0 IOBase 0xf40f0000 IOBasePtr 0xf40f1000
    59.778| HAL_PCIMapIOTagList: Root bus is 0, IOBasePtr f40f1000
    59.784| HAL_PCIMapBusTagList: Result 1
    59.788| Bridge 0: Memory 0xd0000000 - 0xdfffffff, IO 0xf40f0000 - 0xf40fffff
    59.795| Bus 0: Memory 0xd0000000 - 0xdfffffff, IO 0xf40f0000 - 0xf40fffff
    59.803| Checkpoint 7.13
    59.805| HAL_PCIScanBridgeTagList: Tags 0xfed0
    59.810| HAL_PCIScanBridgeTagList: BridgeID 1
    59.814| HAL_PCIScanBridgeTagList: No ConfigBase
    59.819| HAL_PCIScanBridgeTagList: No BridgeBase
    59.823| HAL_PCIScanBridgeTagList: No BridgeBase Size
    59.828| HAL_PCIScanBridgeTagList: No PMemoryBase
    59.833| HAL_PCIScanBridgeTagList: No PMemoryBaseSize
    59.838| HAL_PCIScanBridgeTagList: BridgeNode 0x900800
    59.843| HAL_PCIScanBridgeTagList: BridgeID 0x1
    59.848| HAL_PCIScanBridgeTagList: InterruptID 0x5000066
    59.853| HAL_PCIScanBusTagList: BusID 0
    59.857| HAL_PCIScanBusTagList: StartSlot 0
    59.861| HAL_PCIScanBusTagList: SlotCount 31
    59.866| HAL_PCIScanBusTagList: MemoryBase 0xa0000000 MemoryBaseSize 0x20000000 PMemoryBase 0x0 PMemoryBaseSize 0x0 IOBase 0x89000000 IOBaseSize 0x10000
    59.880| HAL_PCIScanBusTagList: BusNode 0x900880
    59.885| PCIScanBus: SlotID 0
    59.888| PCIScanBus: Function 0 VendorID 0x1002 DeviceID 0x7280
    59.894| PCIScanBus: BoardNode 0x900a54
    59.897| PCIScanBus: HeaderType 0x80
    59.901| PCIScanBus: ClassID 0x3 SubClassID 0x0 ProgInfo 0x0
    59.907| PCIScanBus: 1st Function
    59.910| PCIScanBase on BusID 0 SlotID 0 FunctionID 0
    59.915| PCIScanBase@0: --Oldbase = 0xa000000c
    59.920| PCIScanBase@0: Base=0xf000000c
    59.924| PCIScanBase@0: MEM
    59.927| PCIScanBase@0: nocache
    59.930| PCIScanBase@0: MEMORY 32Bit
    59.934| PCIScanBase@0: BaseAddress 0xf000000c Size 0xffffff0
    59.940| PCIScanBase@0: aligned Size 0x10000000
    59.945| PCIScanBase@0: MapNode 0x900ae0
    59.949| PCIScanBase@0: Size 0x0 Type 0x0 CacheMode 0x0
    59.954| PCIScanBase@2: --Oldbase = 0xb0000004
    59.959| PCIScanBase@2: Base=0xffff0004
    59.963| PCIScanBase@2: MEM
    59.965| PCIScanBase@2: nocachesync
    59.969| PCIScanBase@2: MEMORY 32Bit
    59.973| PCIScanBase@2: BaseAddress 0xffff0004 Size 0xfff0
    59.979| PCIScanBase@2: aligned Size 0x10000
    59.983| PCIScanBase@2: MapNode 0x900b10
    59.987| PCIScanBase@2: Size 0x2 Type 0x0 CacheMode 0x0
    59.993| PCIScanBase@4: --Oldbase = 0x2001
    59.997| PCIScanBase@4: Base=0xffffff01
    60.001| PCIScanBase@4: IO
    60.004| PCIScanBase@4: BaseAddress 0xffffff00 Size 0xffffffff00000100
    60.010| PCIScanBase@4: aligned Size 0x1000
    60.015| PCIScanBase@4: MapNode 0x900b40
    60.019| PCIScanBase@4: Size 0x4 Type 0x0 CacheMode 0x0
    60.024| PCIScanBase@5: --Oldbase = 0x0
    60.028| PCIScanBase@5: size == 0
    60.032| PCIScanBase@6: Rom=0x0
    60.035| PCIScanBase@6: RomBaseAddress 0xfffe0000 Size 0x20000
    60.041| PCIScanBase@6: aligned Size 0x20000
    60.045| PCIScanBase@6: MapNode 0x900b70
    60.050| PCIScanBase@6: Index 8 Size 0x0 Type 0x0 CacheMode 0x20000
    60.056| PCIScanBus: BaseScan ok
    60.060| PCIScanBus: AddBoardNode(MySlotNode 0x900a14 MyBoardNode 0x900a54)
    60.067| PCIScanBus: AddSlotNode
    60.070| PCIScanBus: SlotID 1
    60.073| PCIScanBus: Boardlist empty..freeSlot
    60.078| PCIScanBus: SlotID 2
    60.080| PCIScanBus: Boardlist empty..freeSlot
    60.085| PCIScanBus: SlotID 3
    60.088| PCIScanBus: Boardlist empty..freeSlot
    60.092| PCIScanBus: SlotID 4
    60.095| PCIScanBus: Boardlist empty..freeSlot
    60.100| PCIScanBus: SlotID 5
    60.103| PCIScanBus: Boardlist empty..freeSlot
    60.107| PCIScanBus: SlotID 6
    60.110| PCIScanBus: Boardlist empty..freeSlot
    60.115| PCIScanBus: SlotID 7
    60.117| PCIScanBus: Boardlist empty..freeSlot
    60.122| PCIScanBus: SlotID 8
    60.125| PCIScanBus: Boardlist empty..freeSlot
    60.129| PCIScanBus: SlotID 9
    60.132| PCIScanBus: Boardlist empty..freeSlot
    60.137| PCIScanBus: SlotID 10
    60.140| PCIScanBus: Boardlist empty..freeSlot
    60.144| PCIScanBus: SlotID 11
    60.147| PCIScanBus: Boardlist empty..freeSlot
    60.152| PCIScanBus: SlotID 12
    60.155| PCIScanBus: Boardlist empty..freeSlot
    60.159| PCIScanBus: SlotID 13
    60.162| PCIScanBus: Boardlist empty..freeSlot
    60.167| PCIScanBus: SlotID 14
    60.170| PCIScanBus: Boardlist empty..freeSlot
    60.174| PCIScanBus: SlotID 15
    60.177| PCIScanBus: Boardlist empty..freeSlot
    60.182| PCIScanBus: SlotID 16
    60.184| PCIScanBus: Boardlist empty..freeSlot
    60.189| PCIScanBus: SlotID 17
    60.192| PCIScanBus: Boardlist empty..freeSlot
    60.197| PCIScanBus: SlotID 18
    60.199| PCIScanBus: Boardlist empty..freeSlot
    60.204| PCIScanBus: SlotID 19
    60.207| PCIScanBus: Boardlist empty..freeSlot
    60.211| PCIScanBus: SlotID 20
    60.214| PCIScanBus: Boardlist empty..freeSlot
    60.219| PCIScanBus: SlotID 21
    60.222| PCIScanBus: Boardlist empty..freeSlot
    60.226| PCIScanBus: SlotID 22
    60.229| PCIScanBus: Boardlist empty..freeSlot
    60.234| PCIScanBus: SlotID 23
    60.237| PCIScanBus: Boardlist empty..freeSlot
    60.241| PCIScanBus: SlotID 24
    60.244| PCIScanBus: Boardlist empty..freeSlot
    60.249| PCIScanBus: SlotID 25
    60.252| PCIScanBus: Boardlist empty..freeSlot
    60.256| PCIScanBus: SlotID 26
    60.259| PCIScanBus: Boardlist empty..freeSlot
    60.264| PCIScanBus: SlotID 27
    60.267| PCIScanBus: Boardlist empty..freeSlot
    60.271| PCIScanBus: SlotID 28
    60.274| PCIScanBus: Boardlist empty..freeSlot
    60.279| PCIScanBus: SlotID 29
    60.282| PCIScanBus: Boardlist empty..freeSlot
    60.286| PCIScanBus: SlotID 30
    60.289| PCIScanBus: Boardlist empty..freeSlot
    60.294| HAL_PCIScanBusTagList: Bus child device requires alignment 0x10000000
    60.301| HAL_PCIScanBusTagList: MemoryBaseAlignment 0x10000000
    60.307| HAL_PCIScanBusTagList: return BusNode 0x900880
    60.313| HAL_PCIMapBusTagList:
    60.315| HAL_PCIMapBusTagList: Map Memory
    60.319| HAL_PCIMapMemoryTagList: BusNode 0x900880 BusID 0
    60.325| HAL_PCIMapMemoryTagList: Root bus is 0, MemoryBasePtr a0000000
    60.332| HAL_PCIMapMemoryTagList: Bus 0 requires alignment 00000000
    60.338| HAL_PCIMapMemoryTagList: LowerAddress a0000000
    60.344| HAL_PCIMapMemoryTagList: CurrentMapNode 0x900ae0
    60.349| HAL_PCIMapMemoryTagList: Index 0 Size 0x10000000 Type 0x1
    60.355| HAL_PCIMapMemoryTagList: Address 0xa0000000 Size 0x10000000
    60.362| HAL_PCIMapMemoryTagList: CurrentBoardNode(0x900a54) BusID 0 SlotID 0 DeviceID 0, CurrentMapNode at 0x900ae0
    60.373| HAL_PCIMapMemoryTagList: BusNode 0x900880 SlotNode 0x900a14 BoardNode 0x900a54
    60.381| HAL_PCIMapMemoryTagList: map base
    60.385| HAL_PCIMapMemoryTagList: = 0xa000000c
    60.390| HAL_PCIMapMemoryTagList: done
    60.394| HAL_PCIMapMemoryTagList: CurrentMapNode 0x900b70
    60.399| HAL_PCIMapMemoryTagList: Index 8 Size 0x20000 Type 0x1
    60.405| HAL_PCIMapMemoryTagList: Address 0xb0000000 Size 0x20000
    60.411| HAL_PCIMapMemoryTagList: CurrentBoardNode(0x900a54) BusID 0 SlotID 0 DeviceID 0, CurrentMapNode at 0x900b70
    60.422| HAL_PCIMapMemoryTagList: BusNode 0x900880 SlotNode 0x900a14 BoardNode 0x900a54
    60.431| HAL_PCIMapMemoryTagList: map base
    60.435| HAL_PCIMapMemoryTagList: = 0xb0000000
    60.439| HAL_PCIMapMemoryTagList: done
    60.443| HAL_PCIMapMemoryTagList: CurrentMapNode 0x900b10
    60.449| HAL_PCIMapMemoryTagList: Index 2 Size 0x10000 Type 0x1
    60.455| HAL_PCIMapMemoryTagList: Address 0xb0020000 Size 0x10000
    60.461| HAL_PCIMapMemoryTagList: CurrentBoardNode(0x900a54) BusID 0 SlotID 0 DeviceID 0, CurrentMapNode at 0x900b10
    60.472| HAL_PCIMapMemoryTagList: BusNode 0x900880 SlotNode 0x900a14 BoardNode 0x900a54
    60.480| HAL_PCIMapMemoryTagList: map base
    60.484| HAL_PCIMapMemoryTagList: = 0xb0020004
    60.489| HAL_PCIMapMemoryTagList: done
    60.492| HAL_PCIMapBusTagList: Result 1
    60.496| HAL_PCIMapBusTagList: Map Memory64
    60.500| HAL_PCIMapMemory64TagList: BusNode 0x900880 BusID 0
    60.506| HAL_PCIMapBusTagList: Result 1
    60.510| HAL_PCIMapBusTagList: Map Rom
    60.514| HAL_PCIMapRomTagList:
    60.517| HAL_PCIMapRomTagList: SlotNode 0x900a14
    60.521| HAL_PCIMapRomTagList: BoardNode 0x900a54
    60.526| HAL_PCIMapRomTagList: MapNode 0x900ae0 Index 0
    60.531| HAL_PCIMapRomTagList: no MAPTYPE_ROM
    60.536| HAL_PCIMapRomTagList: MapNode 0x900b10 Index 2
    60.541| HAL_PCIMapRomTagList: no MAPTYPE_ROM
    60.545| HAL_PCIMapRomTagList: MapNode 0x900b40 Index 4
    60.551| HAL_PCIMapRomTagList: no MAPTYPE_ROM
    60.555| HAL_PCIMapRomTagList: MapNode 0x900b70 Index 8
    60.560| HAL_PCIMapRomTagList: no MAPTYPE_ROM
    60.565| HAL_PCIMapRomTagList: done
    60.568| HAL_PCIMapBusTagList: Result 1
    60.572| HAL_PCIMapBusTagList: Map IO
    60.575| HAL_PCIMapIOTagList: BusNode 0x900880 BusID 0 IOBase 0x89000000 IOBasePtr 0x89001000
    60.584| HAL_PCIMapIOTagList: Root bus is 0, IOBasePtr 89001000
    60.590| HAL_PCIMapIOTagList: CurrentMapNode 0x900b40
    60.595| HAL_PCIMapIOTagList: Index 4 Size 0x1000 Type 0x0 IOBasePtr 0x89001000
    60.603| HAL_PCIMapIOTagList: Address 0x89001000 Size 0x1000
    60.609| HAL_PCIMapIOTagList: CurrentBoardNode(0x900a54) BusID 0 SlotID 0 DeviceID 0, CurrentMapNode at 0x900b40
    60.620| HAL_PCIMapIOTagList: map base
    60.623| HAL_PCIMapIOTagList: baseaddress entry set to 0x1000
    60.629| HAL_PCIMapIOTagList: = 0x1001
    60.633| HAL_PCIMapIOTagList: done
    60.636| HAL_PCIMapBusTagList: Result 1
    60.640| Bridge 1: Memory 0xa0000000 - 0xbfffffff, IO 0x89000000 - 0x8900ffff
    60.647| Bus 0: Memory 0xa0000000 - 0xbfffffff, IO 0x89000000 - 0x8900ffff
    60.655| Slot 0:
    60.657| Board 0: Vendor 0x1002, Device 0x7280, Command 0x0007
    60.664| Map 0: Type 1, Size 0x10000000, Address 0xa0000000
    60.670| Map 1: Type 1, Size 0x00010000, Address 0xb0020000
    60.677| Map 2: Type 0, Size 0x00001000, Address 0x89001000
    60.684| Map 3: Type 1, Size 0x00020000, Address 0xb0000000
    60.691| Checkpoint 7.14
    60.693| HAL_PCIScanBridgeTagList: Tags 0xfed0
    60.698| HAL_PCIScanBridgeTagList: BridgeID 2
    60.702| HAL_PCIScanBridgeTagList: No ConfigBase
    60.707| HAL_PCIScanBridgeTagList: No BridgeBase
    60.711| HAL_PCIScanBridgeTagList: No BridgeBase Size
    60.717| HAL_PCIScanBridgeTagList: No PMemoryBase
    60.721| HAL_PCIScanBridgeTagList: No PMemoryBaseSize
    60.726| HAL_PCIScanBridgeTagList: BridgeNode 0x900ba0
    60.732| HAL_PCIScanBridgeTagList: BridgeID 0x2
    60.736| HAL_PCIScanBridgeTagList: InterruptID 0x5000060
    60.742| HAL_PCIScanBusTagList: BusID 0
    60.745| HAL_PCIScanBusTagList: StartSlot 0
    60.749| HAL_PCIScanBusTagList: SlotCount 31
    60.754| HAL_PCIScanBusTagList: MemoryBase 0xc0000000 MemoryBaseSize 0x10000000 PMemoryBase 0x0 PMemoryBaseSize 0x0 IOBase 0x89000000 IOBaseSize 0x10000
    60.768| HAL_PCIScanBusTagList: BusNode 0x900c20
    60.773| PCIScanBus: SlotID 0
    60.776| PCIScanBus: Function 0 VendorID 0x1b21 DeviceID 0x1080
    60.782| PCIScanBus: BoardNode 0x900df4
    60.786| PCIScanBus: HeaderType 0x1
    60.789| PCIScanBus: ClassID 0x6 SubClassID 0x4 ProgInfo 0x0
    60.795| PCIScanBus: Bridge
    60.798| PCIScanBus: 1st Function
    60.801| PCIScanBus: PCI/PCI Bridge
    60.805| PCIScanBus: SubBusID 0x1
    60.808| HAL_PCIScanBusTagList: BusID 1
    60.812| HAL_PCIScanBusTagList: StartSlot 0
    60.816| HAL_PCIScanBusTagList: SlotCount 31
    60.821| HAL_PCIScanBusTagList: MemoryBase 0xc0000000 MemoryBaseSize 0x0 PMemoryBase 0x0 PMemoryBaseSize 0x0 IOBase 0x89000000 IOBaseSize 0x0
    60.834| HAL_PCIScanBusTagList: BusNode 0x900e80
    60.839| PCIScanBus: SlotID 0
    60.842| PCIScanBus: Device is not multifunction, skip additional functions
    60.849| PCIScanBus: Boardlist empty..freeSlot
    60.853| PCIScanBus: SlotID 1
    60.856| PCIScanBus: Device is not multifunction, skip additional functions
    60.863| PCIScanBus: Boardlist empty..freeSlot
    60.868| PCIScanBus: SlotID 2
    60.871| PCIScanBus: Device is not multifunction, skip additional functions
    60.878| PCIScanBus: Boardlist empty..freeSlot
    60.882| PCIScanBus: SlotID 3
    60.885| PCIScanBus: Device is not multifunction, skip additional functions
    60.892| PCIScanBus: Boardlist empty..freeSlot
    60.897| PCIScanBus: SlotID 4
    60.900| PCIScanBus: Device is not multifunction, skip additional functions
    60.907| PCIScanBus: Boardlist empty..freeSlot
    60.912| PCIScanBus: SlotID 5
    60.914| PCIScanBus: Device is not multifunction, skip additional functions
    60.922| PCIScanBus: Boardlist empty..freeSlot
    60.926| PCIScanBus: SlotID 6
    60.929| PCIScanBus: Device is not multifunction, skip additional functions
    60.936| PCIScanBus: Boardlist empty..freeSlot
    60.941| PCIScanBus: SlotID 7
    60.944| PCIScanBus: Device is not multifunction, skip additional functions
    60.951| PCIScanBus: Boardlist empty..freeSlot
    60.955| PCIScanBus: SlotID 8
    60.958| PCIScanBus: Device is not multifunction, skip additional functions
    60.965| PCIScanBus: Boardlist empty..freeSlot
    60.970| PCIScanBus: SlotID 9
    60.973| PCIScanBus: Device is not multifunction, skip additional functions
    60.980| PCIScanBus: Boardlist empty..freeSlot
    60.984| PCIScanBus: SlotID 10
    60.987| PCIScanBus: Device is not multifunction, skip additional functions
    60.995| PCIScanBus: Boardlist empty..freeSlot
    60.999| PCIScanBus: SlotID 11
    61.002| PCIScanBus: Device is not multifunction, skip additional functions
    61.009| PCIScanBus: Boardlist empty..freeSlot
    61.014| PCIScanBus: SlotID 12
    61.017| PCIScanBus: Device is not multifunction, skip additional functions
    61.024| PCIScanBus: Boardlist empty..freeSlot
    61.029| PCIScanBus: SlotID 13
    61.031| PCIScanBus: Device is not multifunction, skip additional functions
    61.039| PCIScanBus: Boardlist empty..freeSlot
    61.043| PCIScanBus: SlotID 14
    61.046| PCIScanBus: Device is not multifunction, skip additional functions
    61.053| PCIScanBus: Boardlist empty..freeSlot
    61.058| PCIScanBus: SlotID 15
    61.061| PCIScanBus: Device is not multifunction, skip additional functions
    61.068| PCIScanBus: Boardlist empty..freeSlot
    61.073| PCIScanBus: SlotID 16
    61.075| PCIScanBus: Device is not multifunction, skip additional functions
    61.083| PCIScanBus: Boardlist empty..freeSlot
    61.087| PCIScanBus: SlotID 17
    61.090| PCIScanBus: Device is not multifunction, skip additional functions
    61.097| PCIScanBus: Boardlist empty..freeSlot
    61.102| PCIScanBus: SlotID 18
    61.105| PCIScanBus: Device is not multifunction, skip additional functions
    61.112| PCIScanBus: Boardlist empty..freeSlot
    61.117| PCIScanBus: SlotID 19
    61.120| PCIScanBus: Device is not multifunction, skip additional functions
    61.127| PCIScanBus: Boardlist empty..freeSlot
    61.131| PCIScanBus: SlotID 20
    61.134| PCIScanBus: Device is not multifunction, skip additional functions
    61.141| PCIScanBus: Boardlist empty..freeSlot
    61.146| PCIScanBus: SlotID 21
    61.149| PCIScanBus: Device is not multifunction, skip additional functions
    61.156| PCIScanBus: Boardlist empty..freeSlot
    61.161| PCIScanBus: SlotID 22
    61.164| PCIScanBus: Device is not multifunction, skip additional functions
    61.171| PCIScanBus: Boardlist empty..freeSlot
    61.175| PCIScanBus: SlotID 23
    61.178| PCIScanBus: Device is not multifunction, skip additional functions
    61.185| PCIScanBus: Boardlist empty..freeSlot
    61.190| PCIScanBus: SlotID 24
    61.193| PCIScanBus: Device is not multifunction, skip additional functions
    61.200| PCIScanBus: Boardlist empty..freeSlot
    61.205| PCIScanBus: SlotID 25
    61.208| PCIScanBus: Device is not multifunction, skip additional functions
    61.215| PCIScanBus: Boardlist empty..freeSlot
    61.219| PCIScanBus: SlotID 26
    61.222| PCIScanBus: Device is not multifunction, skip additional functions
    61.229| PCIScanBus: Boardlist empty..freeSlot
    61.234| PCIScanBus: SlotID 27
    61.237| PCIScanBus: Device is not multifunction, skip additional functions
    61.244| PCIScanBus: Boardlist empty..freeSlot
    61.249| PCIScanBus: SlotID 28
    61.252| PCIScanBus: Device is not multifunction, skip additional functions
    61.259| PCIScanBus: Boardlist empty..freeSlot
    61.263| PCIScanBus: SlotID 29
    61.266| PCIScanBus: Device is not multifunction, skip additional functions
    61.274| PCIScanBus: Boardlist empty..freeSlot
    61.278| PCIScanBus: SlotID 30
    61.281| PCIScanBus: Device is not multifunction, skip additional functions
    61.288| PCIScanBus: Boardlist empty..freeSlot
    61.293| HAL_PCIScanBusTagList: MemoryBaseAlignment 0x00000000
    61.299| HAL_PCIScanBusTagList: return BusNode 0x900e80
    61.304| PCIScanBus: SubBusNode 0x900e80 0x1
    61.308| PCIScanBus: HighestBusID 0x1
    61.312| PCIScanBus: AddBoardNode(MySlotNode 0x900db4 MyBoardNode 0x900df4)
    61.320| PCIScanBus: Device is not multifunction, skip additional functions
    61.327| PCIScanBus: AddSlotNode
    61.330| PCIScanBus: SlotID 1
    61.333| PCIScanBus: Device is not multifunction, skip additional functions
    61.340| PCIScanBus: Boardlist empty..freeSlot
    61.345| PCIScanBus: SlotID 2
    61.347| PCIScanBus: Device is not multifunction, skip additional functions
    61.355| PCIScanBus: Boardlist empty..freeSlot
    61.359| PCIScanBus: SlotID 3
    61.362| PCIScanBus: Device is not multifunction, skip additional functions
    61.369| PCIScanBus: Boardlist empty..freeSlot
    61.374| PCIScanBus: SlotID 4
    61.377| PCIScanBus: Device is not multifunction, skip additional functions
    61.384| PCIScanBus: Boardlist empty..freeSlot
    61.388| PCIScanBus: SlotID 5
    61.391| PCIScanBus: Device is not multifunction, skip additional functions
    61.398| PCIScanBus: Boardlist empty..freeSlot
    61.403| PCIScanBus: SlotID 6
    61.406| PCIScanBus: Device is not multifunction, skip additional functions
    61.413| PCIScanBus: Boardlist empty..freeSlot
    61.418| PCIScanBus: SlotID 7
    61.420| PCIScanBus: Device is not multifunction, skip additional functions
    61.428| PCIScanBus: Boardlist empty..freeSlot
    61.432| PCIScanBus: SlotID 8
    61.435| PCIScanBus: Device is not multifunction, skip additional functions
    61.442| PCIScanBus: Boardlist empty..freeSlot
    61.447| PCIScanBus: SlotID 9
    61.450| PCIScanBus: Device is not multifunction, skip additional functions
    61.457| PCIScanBus: Boardlist empty..freeSlot
    61.461| PCIScanBus: SlotID 10
    61.464| PCIScanBus: Device is not multifunction, skip additional functions
    61.471| PCIScanBus: Boardlist empty..freeSlot
    61.476| PCIScanBus: SlotID 11
    61.479| PCIScanBus: Device is not multifunction, skip additional functions
    61.486| PCIScanBus: Boardlist empty..freeSlot
    61.491| PCIScanBus: SlotID 12
    61.494| PCIScanBus: Device is not multifunction, skip additional functions
    61.501| PCIScanBus: Boardlist empty..freeSlot
    61.505| PCIScanBus: SlotID 13
    61.508| PCIScanBus: Device is not multifunction, skip additional functions
    61.515| PCIScanBus: Boardlist empty..freeSlot
    61.520| PCIScanBus: SlotID 14
    61.523| PCIScanBus: Device is not multifunction, skip additional functions
    61.530| PCIScanBus: Boardlist empty..freeSlot
    61.535| PCIScanBus: SlotID 15
    61.538| PCIScanBus: Device is not multifunction, skip additional functions
    61.545| PCIScanBus: Boardlist empty..freeSlot
    61.549| PCIScanBus: SlotID 16
    61.552| PCIScanBus: Device is not multifunction, skip additional functions
    61.559| PCIScanBus: Boardlist empty..freeSlot
    61.564| PCIScanBus: SlotID 17
    61.567| PCIScanBus: Device is not multifunction, skip additional functions
    61.574| PCIScanBus: Boardlist empty..freeSlot
    61.579| PCIScanBus: SlotID 18
    61.582| PCIScanBus: Device is not multifunction, skip additional functions
    61.589| PCIScanBus: Boardlist empty..freeSlot
    61.593| PCIScanBus: SlotID 19
    61.596| PCIScanBus: Device is not multifunction, skip additional functions
    61.604| PCIScanBus: Boardlist empty..freeSlot
    61.608| PCIScanBus: SlotID 20
    61.611| PCIScanBus: Device is not multifunction, skip additional functions
    61.618| PCIScanBus: Boardlist empty..freeSlot
    61.623| PCIScanBus: SlotID 21
    61.626| PCIScanBus: Device is not multifunction, skip additional functions
    61.633| PCIScanBus: Boardlist empty..freeSlot
    61.637| PCIScanBus: SlotID 22
    61.640| PCIScanBus: Device is not multifunction, skip additional functions
    61.648| PCIScanBus: Boardlist empty..freeSlot
    61.652| PCIScanBus: SlotID 23
    61.655| PCIScanBus: Device is not multifunction, skip additional functions
    61.662| PCIScanBus: Boardlist empty..freeSlot
    61.667| PCIScanBus: SlotID 24
    61.670| PCIScanBus: Device is not multifunction, skip additional functions
    61.677| PCIScanBus: Boardlist empty..freeSlot
    61.681| PCIScanBus: SlotID 25
    61.684| PCIScanBus: Device is not multifunction, skip additional functions
    61.692| PCIScanBus: Boardlist empty..freeSlot
    61.696| PCIScanBus: SlotID 26
    61.699| PCIScanBus: Device is not multifunction, skip additional functions
    61.706| PCIScanBus: Boardlist empty..freeSlot
    61.711| PCIScanBus: SlotID 27
    61.714| PCIScanBus: Device is not multifunction, skip additional functions
    61.721| PCIScanBus: Boardlist empty..freeSlot
    61.725| PCIScanBus: SlotID 28
    61.728| PCIScanBus: Device is not multifunction, skip additional functions
    61.736| PCIScanBus: Boardlist empty..freeSlot
    61.740| PCIScanBus: SlotID 29
    61.743| PCIScanBus: Device is not multifunction, skip additional functions
    61.750| PCIScanBus: Boardlist empty..freeSlot
    61.755| PCIScanBus: SlotID 30
    61.758| PCIScanBus: Device is not multifunction, skip additional functions
    61.765| PCIScanBus: Boardlist empty..freeSlot
    61.770| HAL_PCIScanBusTagList: MemoryBaseAlignment 0x00000000
    61.775| HAL_PCIScanBusTagList: return BusNode 0x900c20
    61.781| HAL_PCIMapBusTagList:
    61.784| HAL_PCIFindLargestUnmappedChildBusNode: Bus child bus requires alignment 0x00000000
    61.793| HAL_PCIMapBusTagList: Mapping child bus node 1
    61.798| HAL_PCIMapBusTagList:
    61.801| HAL_PCIMapBusTagList: Setting up PCI bases for subbus 1 (0.0.0) BoardNode 00900df4 IOBase 89000000 IOBaseSize 00000000
    61.813| HAL_PCIMapBusTagList: Map Memory
    61.817| HAL_PCIMapMemoryTagList: BusNode 0x900e80 BusID 1
    61.822| HAL_PCIMapMemoryTagList: Root bus is 0, MemoryBasePtr c0000000
    61.829| HAL_PCIMapMemoryTagList: BusID 1 (0.0.0) has no memory mappings and no sub bridges that do. Disabling memory requests for this bridge.
    61.843| HAL_PCIMapBusTagList: Result 1
    61.847| HAL_PCIMapBusTagList: Map Memory64
    61.851| HAL_PCIMapMemory64TagList: BusNode 0x900e80 BusID 1
    61.857| HAL_PCIMapBusTagList: Result 1
    61.860| HAL_PCIMapBusTagList: Map Rom
    61.864| HAL_PCIMapRomTagList:
    61.867| HAL_PCIMapRomTagList: done
    61.870| HAL_PCIMapBusTagList: Result 1
    61.874| HAL_PCIMapBusTagList: Map IO
    61.878| HAL_PCIMapIOTagList: BusNode 0x900e80 BusID 1 IOBase 0x89000000 IOBasePtr 0x89000000
    61.887| HAL_PCIMapIOTagList: Root bus is 0, IOBasePtr 89001000
    61.893| HAL_PCIMapIOTagList: Setting up IO space for subbus 1 (0.0.0) BoardNode 00900df4 IOBase 89000000 IOBaseSize 00000000
    61.905| HAL_PCIMapIOTagList: BusID 1 (0.0.0) has no IO mappings and no sub bridges that do. Disabling memory requests for this bridge.
    61.918| HAL_PCIMapBusTagList: Result 1
    61.921| HAL_PCIMapBusTagList: Map Memory
    61.925| HAL_PCIMapMemoryTagList: BusNode 0x900c20 BusID 0
    61.931| HAL_PCIMapMemoryTagList: Root bus is 0, MemoryBasePtr c0000000
    61.938| HAL_PCIMapBusTagList: Result 1
    61.942| HAL_PCIMapBusTagList: Map Memory64
    61.946| HAL_PCIMapMemory64TagList: BusNode 0x900c20 BusID 0
    61.952| HAL_PCIMapBusTagList: Result 1
    61.955| HAL_PCIMapBusTagList: Map Rom
    61.959| HAL_PCIMapRomTagList:
    61.962| HAL_PCIMapRomTagList: SlotNode 0x900db4
    61.967| HAL_PCIMapRomTagList: BoardNode 0x900df4
    61.971| HAL_PCIMapRomTagList: done
    61.975| HAL_PCIMapBusTagList: Result 1
    61.979| HAL_PCIMapBusTagList: Map IO
    61.982| HAL_PCIMapIOTagList: BusNode 0x900c20 BusID 0 IOBase 0x89000000 IOBasePtr 0x89001000
    61.991| HAL_PCIMapIOTagList: Root bus is 0, IOBasePtr 89001000
    61.997| HAL_PCIMapBusTagList: Result 1
    62.001| Bridge 2: Memory 0xc0000000 - 0xcfffffff, IO 0x89000000 - 0x8900ffff
    62.008| Bus 0: Memory 0xc0000000 - 0xcfffffff, IO 0x89000000 - 0x8900ffff
    62.016| Slot 0:
    62.018| Board 0: Vendor 0x1b21, Device 0x1080, Command 0x0007
    62.025| Bus 1: Memory 0xc0000000 - 0xbfffffff, IO 0x89000000 - 0x88ffffff
    62.033| Checkpoint 7.15
    62.035| Checkpoint 8
    62.037| Checkpoint 9
    62.040| Checkpoint 10
    62.042| THREAD_SystemInit: HalConfig 0x8193b0
    62.046| THREAD_SystemInit: Init AddressServer
    62.051| AddressServer: Create Address Server Thread
    62.056| AddressServer: AddressServer TID 0x10000012
    62.062| THREAD_SystemInit: done
    62.065| THREAD_SystemInit: Init RTASServer
    62.069| RTASServer: Create RTAS Server Thread
    62.073| RTASServer: RTASServer TID 0x10000014
    62.078| THREAD_SystemInit: done
    62.081| THREAD_SystemInit: Init TimeServer
    62.085| TimeServer: Create Time Server Thread
    62.089| TimeServer: TimeServer TID 0x10000015
    62.094| THREAD_SystemInit: TimeServer init done
    62.098| THREAD_SystemInit: done
    62.102| THREAD_SystemInit: Create ABox Task
    62.106| THREAD_SystemInit: ABoxTID 0x0
    62.116| THREAD_SystemInit: Start ABox Main Thread
    62.122|
    62.123|
    62.124| ABox 1.30 (2.7.2018) ▒ 1999-2022 by Ralph Schmidt, Emmanuel Lesueur, Teemu Suikki, Harry Sintonen
    62.134| ABox_Init: Create Exception Thread
    62.138| ABox_Init: EmulHandle 0x10000000 SuperHandle 0x10001000
    62.144| ABox_Init: Module Start 0x10100000
    62.148| ABox_Exception:
    62.151| ABox_Exception: RegFrameBuffer 0x1000db60 MyRegFrame 0x1000db60
    62.158| ExecInit: DebugFlags 0xc0010000
    62.162| ExecInit: Can't get /local/system/config/emul/amigamem
    62.168| ExecInit: Can't get /local/system/config/emul/chipmem
    62.174| ExecInit: Can't get /local/system/config/emul/kickstart
    62.180| ExecInit: Can't get /local/system/config/emul/extmodule
    62.186| ExecInit: LocalMem 0x14000000 LocalMemSize 0x6c000000
    62.192| ExecInit: AmigaMem 0x0 AmigaMemSize 0x0
    62.196| ExecInit: ChipMem 0x0 ChipMemSize 0x0
    62.201| ExecInit: Module 0x10100000 ModuleSize 0x3ec000
    62.206| ExecInit: KickStart 0x0 KickStartSize 0x0
    62.211| ExecInit: ExtModule 0x0 ExtModuleSize 0x0
    62.216| ExecInit: EDebugFlags 0xc0010000
    62.220| ExecInit: OldSysBase 0x1 Alert 0x0
    62.224| ExecInit: OldSysBase odd
    62.227| ExecInit: LocalMemHeader 0x14000000 LocalMemHeader2 0x0
    62.233| ExecInit: MyMemHeader 0x14000000
    62.237| ExecInit: CountNewFunctions
    62.241| ExecInit: BaseSize 0x6b0 LibFuncTableSize 0x538
    62.246| ExecInit: OldEntries 0x1 NewEntries 0xb8 FuncArraySize 0xd00
    62.253| ExecInit: MyLibraryBlock 0x14000cb0
    62.257| ExecInit: SysBase 0x140019b0
    62.261| ExecInit: EmulHandleType 4 EmulHandleSize 240
    62.266| ExecInit: Scheduler thread = 0x10020012
    62.271| ExecInit: Create <Int: Scheduler> thread
    62.275| ExecInit: done
    62.278| ExecInit: AddLibrary
    62.281| ExecInit: done
    62.283| ExecInit: Fake ChipMemHeader 0x14002068
    62.287| ExecInit: Set up ex_TBClockFrequency
    62.292| ExecInit: ex_TBClockFrequency set to 1045000000
    62.297| ExecInit: Allocate SSP Stack...
    62.301| ExecInit: SSP Lower 0x14002098 Upper 0x14003898
    62.306| ExecInit: Init ZeroPage
    62.310| ExecInit: Create Resident Table
    62.339| ExecInit: ResModules 0x14003fe0
    62.343| ExecInit: InitCode
    62.346| LIB_ScanConfig: ExpansionBase 0x14003aa4
    62.350| LIB_ScanConfig: 0x10000013
    62.354| Bus Name local Type 0x0 DataType 0x0 Length/Count 0x1 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment
    62.365| Bus Name pci0 Type 0x0 DataType 0x0 Length/Count 0x4 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment
    62.376| Bus Name pci1 Type 0x0 DataType 0x0 Length/Count 0x4 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment
    62.387| Bus Name pci2 Type 0x0 DataType 0x0 Length/Count 0x5 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment
    62.398| LIB_ScanConfig: No more Buses
    62.401| LibInit: Start with SysBase 0x140019b0 [4] 0x140019b0
    62.407| LibInit: SumLibrary
    62.410| LibInit: Create IntServer Table
    62.414| LibInit: Update SysBase checksum
    62.418| ColdStart: Store ChkSum 0xac4c
    62.422| LibInit: Activate Interrupts
    62.425| EnableInt: Can't get BusController
    62.430| LibInit: MyTask 0x14003cb8
    62.433| LibInit: SPLower 0x140040d8 SPUpper 0x140060d8 SPReg 0x140060d8
    62.440| LibInit: AddTask
    62.442| LibInit: Task 0x14003cb8 created
    62.446| ExecStartUpTask: Started..SysBase 0x140019b0
    62.452| CyberGuardPPC_Init:
    62.454| CyberGuardPPC_Init: EnforcerPort 0x14003d78
    62.459| CyberGuardPPC_Init: New VBR 0x1400e680
    62.464| CyberGuardPPC_done:
    62.467| DiagInit:
    62.468| DiagInit: ExpansionBase 0x14003aa4
    62.473| DiagInit: done
    62.475| DEV_Init: LibBase 0x1400eb28 SegList 0x0 SBase 0x140019b0
    62.481| DEV_Init: Root 0x7fffffb8 Magic 0x52525254 Self 0x7fffffb8 Sum 1
    62.488| DEV_Init: recovered root
    62.491| LibInit: LibBase 0x1400ef4c SegList 0x0
    62.496| LibInit: RootName 0x1400ef9c
    62.500| Query_Init: QueryBase 0x1400f254
    62.504| ObjData_Init: ObjDataBase 0x1400f3d8
    62.508| ObjDataSub_Init: ObjDataSubBase 0x1400f57c
    62.513| ObjDataSub_Init: done
    62.516| ObjData_Init: done
    62.518| PCIX_Init: PCIXBase 0x14010330
    62.522| PCIX_Init: get configserver TID
    62.526| PCIX_Init: ConfigServer TID 0x10000013
    62.531| PCIX_Init: RTASServerTID 0x10000014
    62.535| PCIX_Init: ScanBusTags
    62.538| Bridge Name <local> Type 0x0 DataType 0x0 Length/Count 0x1 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.550| Bridge Name <pci0> Type 0x0 DataType 0x0 Length/Count 0x4 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.562| Bus Name <bridgeid> Type 0x1 DataType 0x1 Length/Count 0x0 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.574| LIB_PCIXScanBusTagList: skip entry, not a number
    62.579| Bus Name <interruptid> Type 0x1 DataType 0x1 Length/Count 0x0 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.591| LIB_PCIXScanBusTagList: skip entry, not a number
    62.597| Bus Name <iobase> Type 0x0 DataType 0x0 Length/Count 0x5 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.608| LIB_PCIXScanBusTagList: skip entry, not a number
    62.614| Bus Name <0> Type 0x0 DataType 0x0 Length/Count 0x0 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.625| LIB_PCIXScanBusTagList: BusID String <0>
    62.630| LIB_PCIXScanBusTagList: BusID 0
    62.634| LIB_PCIXScanBusTagList: BusName </local/hardware/bridge/pci0/0/>
    62.641| Bridge Name <pci1> Type 0x0 DataType 0x0 Length/Count 0x4 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.653| Bus Name <bridgeid> Type 0x1 DataType 0x1 Length/Count 0x0 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.664| LIB_PCIXScanBusTagList: skip entry, not a number
    62.670| Bus Name <interruptid> Type 0x1 DataType 0x1 Length/Count 0x0 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.682| LIB_PCIXScanBusTagList: skip entry, not a number
    62.687| Bus Name <iobase> Type 0x0 DataType 0x0 Length/Count 0x5 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.699| LIB_PCIXScanBusTagList: skip entry, not a number
    62.705| Bus Name <0> Type 0x0 DataType 0x0 Length/Count 0x1 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.716| LIB_PCIXScanBusTagList: BusID String <0>
    62.720| LIB_PCIXScanBusTagList: BusID 0
    62.724| LIB_PCIXScanBusTagList: BusName </local/hardware/bridge/pci1/0/>
    62.731| LIB_PCIXScanBusTagList: Slot Name <0> DevID 0x0 Type 0x0 DataType 0x0 Length/Count 0x1 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.746| LIB_PCIXScanBusTagList: SlotName </local/hardware/bridge/pci1/0/0/>
    62.753| LIB_PCIXScanBusTagList: Board Name <0> Type 0x0 DataType 0x0 Length/Count 0x1b Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.767| LIB_PCIXScanBusTagList: Obtained
    62.771| LIB_PCIXScanBusTagList: PCIConfig 0x0
    62.777| Bridge Name <pci2> Type 0x0 DataType 0x0 Length/Count 0x5 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.789| Bus Name <bridgeid> Type 0x1 DataType 0x1 Length/Count 0x0 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.801| LIB_PCIXScanBusTagList: skip entry, not a number
    62.806| Bus Name <interruptid> Type 0x1 DataType 0x1 Length/Count 0x0 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.818| LIB_PCIXScanBusTagList: skip entry, not a number
    62.824| Bus Name <iobase> Type 0x0 DataType 0x0 Length/Count 0x5 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.835| LIB_PCIXScanBusTagList: skip entry, not a number
    62.841| Bus Name <0> Type 0x0 DataType 0x0 Length/Count 0x1 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.852| LIB_PCIXScanBusTagList: BusID String <0>
    62.857| LIB_PCIXScanBusTagList: BusID 0
    62.860| LIB_PCIXScanBusTagList: BusName </local/hardware/bridge/pci2/0/>
    62.867| LIB_PCIXScanBusTagList: Slot Name <0> DevID 0x0 Type 0x0 DataType 0x0 Length/Count 0x1 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.882| LIB_PCIXScanBusTagList: SlotName </local/hardware/bridge/pci2/0/0/>
    62.889| LIB_PCIXScanBusTagList: Board Name <0> Type 0x0 DataType 0x0 Length/Count 0xb Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.903| LIB_PCIXScanBusTagList: Obtained
    62.907| LIB_PCIXScanBusTagList: PCIConfig 0x0
    62.912| Bus Name <1> Type 0x0 DataType 0x0 Length/Count 0x0 Creator 0x10000012 CreateDate 0x0 Notify 0x0 Comment <>
    62.923| LIB_PCIXScanBusTagList: BusID String <1>
    62.928| LIB_PCIXScanBusTagList: BusID 1
    62.932| LIB_PCIXScanBusTagList: BusName </local/hardware/bridge/pci2/1/>
    62.939| PCIX_Init: done
    62.941| CybPCI_Init: CybPCIBase 0x14010e84
    62.945| CybPCI_Init: done
    62.948| TimePPC_Init: DevBase 0x14010fd4 SegList 0x0 SBase 0x140019b0
    62.955| TimePPC_Init: ConfigServer 0x10000013
    62.959| TimePPC_Init: TimeServer 0x10000015
    62.963| TimePPC_Init: CPUClock 1045000000
    62.968| TimePPC_Init: CPUBusClock 1045000000
    62.972| TimePPC_Init: CPUBusTicks 1
    62.975| TimePPC_Init: Can't find keylargo timer base !
    62.981| TimePPC_Init: Secs 1436986085 Micros 0
    62.985| TimePPC_Init: TBBase 0xf52e3ea9b
    62.989| TimePPC_Init: ABoxTickTID 0x10020014
    62.994| TimePPC_Init: done
    62.996| DosInit: Entry
    62.999| DosInit: DebugFlags 0x00000000
  • »15.07.23 - 16:51
    Posts: 42 from 2023/3/27
    Part 2:
    63.003| ScanFilesystems: Filesystem Scan
    63.006| ScanFilesystems: MyQueryInfo 0x1401451c
    63.011| ScanFilesystems: Name <CDRive>
    63.015| ScanFilesystems: Version 51
    63.018| ScanFilesystems: Revision 34
    63.022| ScanFilesystems: SegList 0x10258a1c
    63.027| ScanFilesystems: QueryDosTypeMatch 0x10258af0
    63.032| ScanFilesystems: DosType 0x43444653 Mask 0xffffffff
    63.038| ScanFilesystems: Process DosType 0x43444653
    63.043| ScanFilesystems: FileSysRes 0x1401075c created
    63.048| ScanFilesystems: MyQueryInfo 0x1401451c
    63.053| ScanFilesystems: Name <MorhpOS SFS>
    63.057| ScanFilesystems: Version 1
    63.061| ScanFilesystems: Revision 229
    63.064| ScanFilesystems: SegList 0x102762f4
    63.069| ScanFilesystems: StackSize 8192
    63.073| ScanFilesystems: QueryDosTypeMatch 0x102762cc
    63.078| ScanFilesystems: DosType 0x53465300 Mask 0xffffffff
    63.084| ScanFilesystems: Process DosType 0x53465300
    63.089| ScanFilesystems: FileSysRes 0x1401075c created
    63.094| ScanFilesystems: MyQueryInfo 0x1401451c
    63.099| ScanFilesystems: Name <FAT>
    63.103| ScanFilesystems: Version 0
    63.106| ScanFilesystems: Revision 46
    63.110| ScanFilesystems: SegList 0x104c85b4
    63.114| ScanFilesystems: StackSize 8192
    63.118| ScanFilesystems: QueryDosTypeMatch 0x104c85f0
    63.123| ScanFilesystems: DosType 0x4d534400 Mask 0xffffffff
    63.129| ScanFilesystems: Process DosType 0x4d534400
    63.134| ScanFilesystems: FileSysRes 0x1401075c created
    63.140| ScanFilesystems: MyQueryInfo 0x1401451c
    63.144| ScanFilesystems: Name <PFS>
    63.148| ScanFilesystems: Version 18
    63.152| ScanFilesystems: Revision 12
    63.155| ScanFilesystems: SegList 0x104e4d4c
    63.160| ScanFilesystems: StackSize 10240
    63.164| ScanFilesystems: QueryDosTypeMatch 0x104e4d00
    63.169| ScanFilesystems: DosType 0x41465301 Mask 0xffffffff
    63.175| ScanFilesystems: Process DosType 0x41465301
    63.180| ScanFilesystems: FileSysRes 0x1401075c created
    63.185| ScanFilesystems: DosType 0x50465302 Mask 0xffffffff
    63.191| ScanFilesystems: Process DosType 0x50465302
    63.196| ScanFilesystems: FileSysRes 0x1401075c created
    63.202| ScanFilesystems: DosType 0x50445302 Mask 0xffffffff
    63.208| ScanFilesystems: Process DosType 0x50445302
    63.213| ScanFilesystems: FileSysRes 0x1401075c created
    63.218| ScanFilesystems: DosType 0x50465303 Mask 0xffffffff
    63.224| ScanFilesystems: Process DosType 0x50465303
    63.229| ScanFilesystems: FileSysRes 0x1401075c created
    63.234| ScanFilesystems: DosType 0x50445303 Mask 0xffffffff
    63.240| ScanFilesystems: Process DosType 0x50445303
    63.245| ScanFilesystems: FileSysRes 0x1401075c created
    63.251| ScanFilesystems: MyQueryInfo 0x1401451c
    63.255| ScanFilesystems: Name <FastFileSystem2>
    63.260| ScanFilesystems: Version 51
    63.264| ScanFilesystems: Revision 34
    63.267| ScanFilesystems: SegList 0x10324070
    63.272| ScanFilesystems: StackSize 8192
    63.276| ScanFilesystems: QueryDosTypeMatch 0x1032419c
    63.281| ScanFilesystems: DosType 0x444f5300 Mask 0xffffffff
    63.287| ScanFilesystems: Process DosType 0x444f5300
    63.292| ScanFilesystems: FileSysRes 0x1401075c created
    63.297| ScanFilesystems: DosType 0x444f5301 Mask 0xffffffff
    63.303| ScanFilesystems: Process DosType 0x444f5301
    63.308| ScanFilesystems: FileSysRes 0x1401075c created
    63.314| ScanFilesystems: DosType 0x444f5302 Mask 0xffffffff
    63.320| ScanFilesystems: Process DosType 0x444f5302
    63.325| ScanFilesystems: FileSysRes 0x1401075c created
    63.330| ScanFilesystems: DosType 0x444f5303 Mask 0xffffffff
    63.336| ScanFilesystems: Process DosType 0x444f5303
    63.341| ScanFilesystems: FileSysRes 0x1401075c created
    63.347| ScanFilesystems: DosType 0x444f5304 Mask 0xffffffff
    63.352| ScanFilesystems: Process DosType 0x444f5304
    63.358| ScanFilesystems: FileSysRes 0x1401075c created
    63.363| ScanFilesystems: DosType 0x444f5305 Mask 0xffffffff
    63.369| ScanFilesystems: Process DosType 0x444f5305
    63.374| ScanFilesystems: FileSysRes 0x1401075c created
    63.379| ScanFilesystems: DosType 0x444f5306 Mask 0xffffffff
    63.385| ScanFilesystems: Process DosType 0x444f5306
    63.390| ScanFilesystems: FileSysRes 0x1401075c created
    63.396| ScanFilesystems: DosType 0x444f5307 Mask 0xffffffff
    63.402| ScanFilesystems: Process DosType 0x444f5307
    63.407| ScanFilesystems: FileSysRes 0x1401075c created
    63.412| ScanFilesystems: Filesystem Scan done
    63.417| Mount.lib: 14014d9c, starting cleanup task
    63.422| mount.lib child: entry
    63.425| mount.lib child: waiting for messages
    63.429| Mount.lib: cleanup child = 0x14014f58
    63.433| graphics.library LibInit: SysBase 0x140019b0
    63.439| get_pal(chipID 35)
    63.441| graphics.library LibInit: SysBase 0x140019b0 -> done
    63.454| MountImage:
    63.456| MountImage: Can't get /local/system/config/emul/bootimage
    63.463| SetPrefs: Buffer 0x14077e9c Size 0xe8 Inform 0
    63.468| SetPrefs: DoubleClick 0.500000
    63.472| SetPrefs: KeyRptDelay 0 secs micros 500000
    63.477| SetPrefs: KeyRptSpeed secs 0 micros 50000
    63.482| Log_Init: LogBase 0x140abbe0
    63.486| Log_Init: Emulation 0x11000000 Size 0x3cb000
    63.491| Log_Init: Module 0x10100000 Size 0x3ec000
    63.496| Log_Init: Process 0x140ac380
    63.499| *********************************************************************
    63.524| *********************************************************************
    63.531| *********************************************************************
    63.539| FSInit:
    63.540| *********************************************************************
    63.548| *********************************************************************
    63.556| *********************************************************************
    63.563| *********************************************************************
    63.570| *********************************************************************
    63.578| *********************************************************************
    63.585| *********************************************************************
    63.593| Driver_Init:
    63.595| Driver_Init: process std sata boards
    63.599| Driver_Init: process custom sata boards
    63.604| Driver_Init: Entry 0 VendorID 0x1095 DeviceID 0x3512
    63.610| Driver_Init: Entry 1 VendorID 0x1095 DeviceID 0x3112
    63.616| Driver_Init: Entry 2 VendorID 0x1095 DeviceID 0x3114
    63.622| Driver_Init: Entry 3 VendorID 0x1095 DeviceID 0x3132
    63.627| Driver_Init: Entry 4 VendorID 0x1022 DeviceID 0x7801
    63.633| Driver_Init: process custom ide boards...done
    63.639| THREAD_SystemInit: done
    63.642| THREAD_SystemInit: Wait *forever*
    65.316| LibMountMountTagList: NotifyUnit 0x14166614
    65.321| LibMountMountTagList: tag 81010011 val 14166570
    65.327| LibMountMountTagList: tag 81010013 val 00000064
    65.332| Mount_CreateDiskPort: NotifyUnit 0x14166614
    65.337| Mount_CreateDiskPort: Device 0x14035264 <usbscsi.device> Unit 0x1416608c
    65.345| Mount_CreateDiskPort: MyUnitNum 0
    65.349| Mount_CreateDiskPort: Mask 0xffffffff
    65.353| Mount_CreateDiskPort: MaxTransfer 0xffffffff
    65.358| Mount_CreateDiskPort: Diskport 0x1417bd44
    65.363| Mount_CreateDiskPort: Aligned Diskport 0x1417bd60
    65.369| Mount_CreateDiskPort: DataBuffer 0x1417bd60
    65.374| Mount_CreateDiskPort: FshBuffer 0x1417c560
    65.379| Mount_CreateDiskPort: LSegBuffer 0x1417cd60
    65.384| Mount_CreateDiskPort: MyLunID 0
    65.388| Mount_CreateDiskPort: done
    65.391| LibMountMountTagList: MyDiskPort 0x1417bd60
    65.396| LibMountMountTagList@usbscsi.device-0: DeviceType 0 MountMode 0
    65.403| LibMountMountTagList@usbscsi.device-0: mountable devicetype
    65.410| LibMountMountTagList@usbscsi.device-0: Mount HD
    65.415| LibMountMountTagList@usbscsi.device-0: Drive
    65.420| LibMountMountTagList@usbscsi.device-0: Scan RDB
    65.425| Mount_RDB@usbscsi.device-0: MyDiskPort 0x1417bd60
    65.431| Mount_RDB@usbscsi.device-0: Device 0x14035264 <usbscsi.device> Unit 0x1416608c UnitNum 0
    65.440| Mount_RDB@usbscsi.device-0: Scan RDB
    65.445| Mount_ReadBlock@usbscsi.device-0: Offset 0x0 Length 512 IORequest.Data 0x1417bd60
    65.454| Mount_RDB@usbscsi.device-0: IDError ID=0x45520200 SummedLongs=0x000cf220 ChkSum=0x00000000
    65.463| Mount_ReadBlock@usbscsi.device-0: Offset 0x200 Length 512 IORequest.Data 0x1417bd60
    65.473| Mount_RDB@usbscsi.device-0: IDError ID=0x504d0000 SummedLongs=0x00000002 ChkSum=0x00000001
    65.483| Mount_ReadBlock@usbscsi.device-0: Offset 0x400 Length 512 IORequest.Data 0x1417bd60
    65.492| Mount_RDB@usbscsi.device-0: IDError ID=0x504d0000 SummedLongs=0x00000002 ChkSum=0x00000040
    65.501| Mount_ReadBlock@usbscsi.device-0: Offset 0x600 Length 512 IORequest.Data 0x1417bd60
    65.511| Mount_RDB@usbscsi.device-0: IDError ID=0x00000000 SummedLongs=0x00000000 ChkSum=0x00000000
    65.520| Mount_ReadBlock@usbscsi.device-0: Offset 0x800 Length 512 IORequest.Data 0x1417bd60
    65.530| Mount_RDB@usbscsi.device-0: IDError ID=0x00000000 SummedLongs=0x00000000 ChkSum=0x00000000
    65.539| Mount_ReadBlock@usbscsi.device-0: Offset 0xa00 Length 512 IORequest.Data 0x1417bd60
    65.549| Mount_RDB@usbscsi.device-0: IDError ID=0x00000000 SummedLongs=0x00000000 ChkSum=0x00000000
    65.558| Mount_ReadBlock@usbscsi.device-0: Offset 0xc00 Length 512 IORequest.Data 0x1417bd60
    65.567| Mount_RDB@usbscsi.device-0: IDError ID=0x00000000 SummedLongs=0x00000000 ChkSum=0x00000000
    65.577| Mount_ReadBlock@usbscsi.device-0: Offset 0xe00 Length 512 IORequest.Data 0x1417bd60
    65.586| Mount_RDB@usbscsi.device-0: IDError ID=0x00000000 SummedLongs=0x00000000 ChkSum=0x00000000
    65.596| Mount_ReadBlock@usbscsi.device-0: Offset 0x1000 Length 512 IORequest.Data 0x1417bd60
    65.605| Mount_RDB@usbscsi.device-0: ID=0x5244534b SummedLongs=0x00000040 ChkSum=0xada1c628
    65.614| Mount_RDB@usbscsi.device-0: chksum ok
    65.618| Mount_LoadFilesystems@usbscsi.device-0: FileSysBlock -1
    65.624| Mount_RDB@usbscsi.device-0: Filesystem Status 1
    65.630| Mount_Part@usbscsi.device-0: DiskPort 0x1417bd60
    65.635| Mount_Part@usbscsi.device-0: Device 0x14035264 <usbscsi.device> Unit 0x1416608c UnitNum 0
    65.644| Mount_ReadBlock@usbscsi.device-0: Offset 0x1200 Length 512 IORequest.Data 0x1417bd60
    65.654| Mount_Part@usbscsi.device-0: ID=0x50415254 SummedLongs=0x00000040 ChkSum=0x97d2d28d
    65.663| Mount_Part@usbscsi.device-0: chksum ok
    65.667| Mount_Part@usbscsi.device-0: TableSize 0x10
    65.673| Mount_Part@usbscsi.device-0: SizeBlock 128
    65.678| Mount_Part@usbscsi.device-0: SecOrg 0
    65.683| Mount_Part@usbscsi.device-0: NumHeads 1
    65.688| Mount_Part@usbscsi.device-0: SecsPerBlk 8
    65.693| Mount_Part@usbscsi.device-0: BlkPerTrack 1
    65.698| Mount_Part@usbscsi.device-0: ReservedBlks 2
    65.703| Mount_Part@usbscsi.device-0: Prefac 0
    65.708| Mount_Part@usbscsi.device-0: Interleave 0
    65.713| Mount_Part@usbscsi.device-0: LowCyl 8256
    65.718| Mount_Part@usbscsi.device-0: UpperCyl 848415
    65.724| Mount_Part@usbscsi.device-0: NumBuffers 128
    65.729| Mount_Part@usbscsi.device-0: BufMemType 0x0
    65.734| Mount_Part@usbscsi.device-0: MaxTransfer 0x7fffffff
    65.740| Mount_Part@usbscsi.device-0: Mask 0xffffffff
    65.746| Mount_Part@usbscsi.device-0: BootPri 15
    65.751| Mount_Part@usbscsi.device-0: DosType 0x444f5307
    65.757| Mount_Part@usbscsi.device-0: Baud 0x0
    65.762| Mount_Part@usbscsi.device-0: Control 0x0
    65.767| Mount_Part@usbscsi.device-0: BootBlocks 0
    65.772| Mount_Part@usbscsi.device-0: FileSysEntry 0x14014c04 PatchFlags 0x190
    65.780| Mount_Part@usbscsi.device-0: Partition Name <HDIMG0>
    65.786| Mount_CreateUniquePartitionName@usbscsi.device-0: Name <HDIMG0>
    65.792| Mount_FindPartitionName@usbscsi.device-0: RemovableTask check <HDIMG0>
    65.800| Mount_FindPartitionName@usbscsi.device-0: No DeviceList Head
    65.807| Mount_FindPartitionName@usbscsi.device-0: no DosBase/DeviceList, scan ExpansionBase's Mountlist
    65.817| Mount_FindPartitionName@usbscsi.device-0: ExpansionBase 0x14003aa4 MountList 1
    65.825| Mount_FindPartitionName@usbscsi.device-0: not found
    65.831| Mount_CreateUniquePartitionName@usbscsi.device-0: Unique Name <HDIMG0>
    65.838| Mount_Part@usbscsi.device-0: Unique Partition Name <HDIMG0>
    65.845| Mount_PartMount@usbscsi.device-0: DiskPort 0x1417bd60 Flags 0x1
    65.852| Mount_PartMount@usbscsi.device-0: Device 0x14035264 <usbscsi.device> Unit 0x1416608c UnitNum 0
    65.862| Mount_PartMount@usbscsi.device-0: Name <HDIMG0>
    65.867| Mount_PartMount@usbscsi.device-0: MyDeviceNode 0x1417d7dc
    65.873| Mount_PartMount@usbscsi.device-0: Removable Task special handling
    65.880| Mount_CheckDeviceNode@usbscsi.device-0: MyDeviceNode 0x1417d7dc
    65.887| Mount_CheckDeviceNode@usbscsi.device-0: no DeviceNode Head
    65.894| Mount_CheckDeviceNode@usbscsi.device-0: Result 0x1
    65.899| Mount_PartMount@usbscsi.device-0: FileSystemTask 0x1
    65.905| Mount_PartMount@usbscsi.device-0: No Volume with the parameter exists..so mount it
    65.914| usbscsi.device@0: Mount <HDIMG0>
    65.918| Mount_PartMount@usbscsi.device-0: save DeviceNode 1417d8e4 to 0x14166690 in 14166614 for future unmount support
    65.930| Mount_PartMount@usbscsi.device-0: The partition is BOOTABLE, so set the Bootpri
    65.938| usbscsi.device@0: Partition <HDIMG0> DosType 0x444f5307 BootPri 15
    65.945| Mount_PartMount@usbscsi.device-0: BootPri 15 DeviceNode 0x1417d7dc ConfigDev 0x14014e30
    65.955| Mount_PartMount@usbscsi.device-0: AddBootNode succeeded
    65.961| Mount_Part@usbscsi.device-0: Mount_PartMount()=1
    65.966| Mount_Part@usbscsi.device-0: free PartionName
    65.971| Mount_RDB@usbscsi.device-0: Partition Status 1
    65.977| Mount_DeleteDiskPort: MyDiskPort 0x1417bd60
    67.304| launching Permedia2 driver
    67.307| Permedia2_startup: cgxsystem.library already found
    67.313| Permedia2_startup: Trying to open Permedia2 driver
    67.319| Permedia2_startup: Creating new driver Permedia2
    67.397| launching SiS300 driver
    67.400| SiS300_startup: cgxsystem.library already found
    67.405| SiS300_startup: Trying to open SiS300 driver
    67.425| SiS300_startup: Creating new driver SiS300
    67.430| LibInit_SiS300
    67.432| Trying to find cybergraphics.library
    67.436| Trying to open dos.library
    67.440| Trying to open utility.library
    67.443| Trying to open intuition.library
    67.447| Trying to open graphics.library
    67.451| Trying to open pcix.library
    67.455| Trying to find SiS Board
    67.458| LibInit_SiS300: No SiS device found
    67.462| LibInit_SiS300 done, returning NULL
    67.467| SiS300 driver startup done
    67.484| launching SiS6326 driver
    67.487| SiS6326_startup: cgxsystem.library already found
    67.493| SiS6326_startup: Trying to open SiS6326 driver
    67.510| SiS6326_startup: Creating new driver SiS6326
    67.515| LibInit_SiS6326
    67.517| Trying to find cybergraphics.library
    67.521| Trying to open dos.library
    67.525| Trying to open utility.library
    67.529| Trying to open intuition.library
    67.533| Trying to open graphics.library
    67.536| Trying to open pcix.library
    67.540| Trying to find SiS Board
    67.543| LibInit_SiS6326: No SiS device found
    67.548| LibInit_SiS6326 done, returning NULL
    67.552| SiS6326 driver startup done
    67.570| launching SiSXabre driver
    67.574| SiSXabre_startup: cgxsystem.library already found
    67.579| SiSXabre_startup: Trying to open SiSXabre driver
    67.598| SiSXabre_startup: Creating new driver SiSXabre
    67.603| LibInit_SiSXabre
    67.605| Trying to find cybergraphics.library
    67.610| Trying to open dos.library
    67.613| Trying to open utility.library
    67.617| Trying to open intuition.library
    67.621| Trying to open graphics.library
    67.625| Trying to open pcix.library
    67.628| Trying to find SiS Board
    67.632| LibInit_SiSXabre: No SiS device found
    67.636| LibInit_SiSXabre done, returning NULL
    67.640| SiSXabre driver startup done
    67.660| launching Rage128 driver
    67.663| Rage128_startup: cgxsystem.library already found
    67.668| Rage128_startup: Trying to open Rage128 driver
    67.674| Rage128_startup: Creating new driver Rage128
    67.679| LibInit_Rage128
    67.681| Trying to find cybergraphics.library
    67.685| Trying to open dos.library
    67.689| Trying to open utility.library
    67.693| Trying to open intuition.library
    67.697| Trying to open graphics.library
    67.701| Trying to open pcix.library
    67.704| Rage128: Trying to find ATI Rage128 Board
    67.709| Rage128: No compatible ATI device found
    67.714| Rage128 driver startup done
    67.731| launching Voodoo4 driver
    67.735| Voodoo4_startup: cgxsystem.library already found
    67.740| Voodoo4_startup: Trying to open Voodoo4 driver
    67.745| Voodoo4_startup: Creating new driver Voodoo4
    67.750| LibInit_Voodoo4
    67.753| Trying to find cybergraphics.library
    67.757| Trying to open dos.library
    67.761| Trying to open utility.library
    67.764| Trying to open intuition.library
    67.768| Trying to open graphics.library
    67.772| Trying to open pcix.library
    67.776| Trying to find 3dfx Voodoo Board
    67.780| Voodoo4: No compatible 3dfx device found
    67.784| Voodoo4 driver startup done
    67.803| launching SiS315 driver
    67.806| SiS315_startup: cgxsystem.library already found
    67.811| SiS315_startup: Trying to open SiS315 driver
    67.830| SiS315_startup: Creating new driver SiS315
    67.835| LibInit_SiS315
    67.837| Trying to find cybergraphics.library
    67.842| Trying to open dos.library
    67.845| Trying to open utility.library
    67.849| Trying to open intuition.library
    67.853| Trying to open graphics.library
    67.857| Trying to open pcix.library
    67.860| Trying to find SiS Board
    67.864| LibInit_SiS315: No SiS device found
    67.868| LibInit_SiS315 done, returning NULL
    67.872| SiS315 driver startup done
    67.894| LibInit_SM502
    67.896| Trying to find cybergraphics.library
    67.901| Trying to open dos.library
    67.904| Trying to open utility.library
    67.908| Trying to open intuition.library
    67.912| Trying to open graphics.library
    67.916| Trying to open pcix.library
    67.919| SM502 BoardNode found at 0x0
    67.923| LibInit_SM502 done, returning NULL
    67.941| launching Voodoo3 driver
    67.945| Voodoo3_startup: cgxsystem.library already found
    67.950| Voodoo3_startup: Trying to open Voodoo3 driver
    67.955| Voodoo3_startup: Creating new driver Voodoo3
    67.960| LibInit_Voodoo3
    67.963| Trying to find cybergraphics.library
    67.967| Trying to open dos.library
    67.971| Trying to open utility.library
    67.974| Trying to open intuition.library
    67.978| Trying to open graphics.library
    67.982| Trying to open pcix.library
    67.986| Trying to find 3dfx Voodoo Board
    67.990| Voodoo3: No compatible 3dfx device found
    67.994| Voodoo3 driver startup done
    68.031| launching Radeon driver
    68.034| Radeon_startup: cgxsystem.library already found
    68.040| Radeon_startup: Trying to open Radeon driver
    68.045| Radeon_startup: Creating new driver Radeon
    68.050| LibInit_Radeon
    68.052| Trying to find cybergraphics.library
    68.056| Trying to open dos.library
    68.060| Trying to open utility.library
    68.063| Trying to open intuition.library
    68.067| Trying to open graphics.library
    68.071| Trying to open pcix.library
    68.075| Radeon: Trying to find ATI Radeon Board
    68.079| Radeon: Found ATI Radeon Board Vendor 0x1002 Device 0x7280 Flags 0x0001
    68.087| db->drvr_CardCnt at 0
    68.090| DRVR Modetable at 1425213c
    68.097| BoardObject at 0x1401081c
    68.100| Reading DeviceID ...
    68.270| Do DDC magic
    68.272| DDCSetup()
    68.274| Calling DDCGetMonInfo (DRVRBase = 14250e78)
    68.279| RADEON: DRVRGetDDCStatus monport 0
    68.286| DRVRGetDDCStatus: probe failed for reg 0x7e60
    68.294| DRVRGetDDCStatus: probe failed for reg 0x7e50
    68.301| DRVRGetDDCStatus: read succeeded for reg 0x7e40
    68.306| RADEON: Found DDC from 0x7e40 port
    68.311| DRVRGetDDCStatus: returning status 3
    68.315| DRVRReadEDID: monport 0 blocknum 0 data 0x1428fe30
    68.349| DRVRReadEDID: monport 0 blocknum 0 returned len 128
    68.355| Got EDID data...
    68.357| DDCGetMonInfo returned success
    68.361| Monitor: 27G2G4 Ratio: 16:9
    68.365| Max pixel clock: 180 MHz
    68.368| Min HFreq: 30 KHz Max HFreq: 160 KHz
    68.372| Min VFreq: 48 Hz Max VFreq: 144 Hz
    68.379| "sys:Prefs/Presets/Monitors/27G2G4" doesn't exist, generate
    68.386| Couldn't open file, trying alternate path "ram:Prefs/Presets/Monitors/27G2G4"
    68.395| "CyberGraphX/RadeonMonitor" set to "ram:Prefs/Presets/Monitors/27G2G4"
    68.411| Radeon: Don't know how to initialise the memory controller of this Radeon
    68.418| Radeon: Memory size adjusted to 256MB
    68.424| PCI CFG offset 0x4 = 10100007
    68.427| PCI CFG offset 0x10 = a000000c
    68.431| PCI CFG offset 0x14 = 00000000
    68.435| PCI CFG offset 0x18 = b0020004
    68.439| Adding Int Server 0x14290080 is_Code = 0x142432b4
    68.444| Creating Int Object for BoardObject 0x1401081c Code = 0x142432b4
    68.451| Showing boot logo
    68.465| Radeon/AtomBIOS: ATOMBIOS func 76 not available
    68.470| clearing memory !
    68.500| clear memory done!
    69.295| InitCode done
    69.297| Attempting to initialise Radeon DMA
    69.302| Radeon DMA initialised
    69.305| Calling CCE_Init
    69.308| CCE_Init done
    69.310| LibInit: memoryclock is 695250000
    69.314| LibInit: engineclock is 594000000
    69.318| LibInit: ddc1port 0 (reg 0x7e40) ddc2port 0
    69.324| LibInit: failed to update ModeSpecs in LibInit (primaryLVDS=0),
    69.331| returning driver base at 0x14250e78
    69.335| Adding/Updating GraphDev structure to cgxsystem
    69.342| NotifyProc ptr is at 0 DosBase at 0x1401412c
    69.347| NotifyProc created at 14c3e008
    69.351| found GDA_ROOTMAP_BASE tag at 0x0x14257e2c
    69.356| getting rootmap for pixfmt 0x0
    69.360| rootmap for pixfmt 0x0 allocated at 0x0x1430f28c!
    69.365| rootmap tag for pixfmt 0x0 (bm 0x0x1430f28c vn 0x0x142412bc) at 0x0x14257e2c!
    69.374| getting rootmap for pixfmt 0x3
    69.377| rootmap for pixfmt 0x3 allocated at 0x0x14a42eec!
    69.383| rootmap tag for pixfmt 0x3 (bm 0x0x14a42eec vn 0x0x14c57204) at 0x0x14257e34!
    69.391| getting rootmap for pixfmt 0x7
    69.395| rootmap for pixfmt 0x7 allocated at 0x0x14a42f24!
    69.401| rootmap tag for pixfmt 0x7 (bm 0x0x14a42f24 vn 0x0x14313f1c) at 0x0x14257e3c!
    69.409| getting rootmap for pixfmt 0xc
    69.413| rootmap for pixfmt 0xc allocated at 0x0x14313f64!
    69.419| rootmap tag for pixfmt 0xc (bm 0x0x14313f64 vn 0x0x14a446d4) at 0x0x14257e44!
    69.428| NotifyProc ptr is at 14c3e008 DosBase at 0x1401412c
    69.433| driver opened!
    69.436| setting cli 0x14274434 cli_Module = 0x5096565 to NULL
    69.442| Radeon driver startup done
    69.460| launching Voodoo5 driver
    69.463| Voodoo5_startup: cgxsystem.library already found
    69.469| Voodoo5_startup: Trying to open Voodoo5 driver
    69.474| Voodoo5_startup: Creating new driver Voodoo5
    69.479| LibInit_Voodoo5
    69.482| Trying to find cybergraphics.library
    69.486| Trying to open dos.library
    69.489| Trying to open utility.library
    69.493| Trying to open intuition.library
    69.497| Trying to open graphics.library
    69.501| Trying to open pcix.library
    69.504| Trying to find 3dfx Voodoo Board
    69.508| Voodoo5: No compatible 3dfx device found
    69.513| Voodoo5 driver startup done
    69.533| launching XGIVolari driver
    69.536| XGIVolari_startup: cgxsystem.library already found
    69.542| XGIVolari_startup: Trying to open XGIVolari driver
    69.562| XGIVolari_startup: Creating new driver XGIVolari
    69.567| LibInit_XGIVolari
    69.570| Trying to find cybergraphics.library
    69.574| Trying to open dos.library
    69.578| Trying to open utility.library
    69.582| Trying to open intuition.library
    69.586| Trying to open graphics.library
    69.589| Trying to open pcix.library
    69.593| Trying to find XGI Volari XG40 Board
    69.597| LibInit_XGIVolari: No Volari XG40 device found
    69.603| LibInit_XGIVolari done, returning NULL
    69.607| XGIVolari driver startup done
    69.718| Strap_Init:
    69.720| Strap_Init: ExpansionBase 0x14003aa4
    69.724| ProcessMountList:
    69.727| ProcessMountList: BootNode 0x1417d910
    69.731| ProcessMountList: DeviceNode 0x1417d7dc
    69.736| ProcessMountList: Handler 0x0
    69.739| ProcessMountList: dn_Name <HDIMG0>
    69.744| ProcessMountList: done
    69.747| BootMountList:
    69.749| BootMountList: boot device = <HDIMG0>
    69.753| BootMountList: BootNode 0x1417d910
    69.757| BootMountList: <HDIMG0>
    69.761| BootMountList: found device
    69.764| BootMountList: BootNode 0x1417d910
    69.768| BootCard:
    69.770| BootCard: done
    69.772| BootMountList: BootNode->bn_Node.ln_Type 0x10
    69.778| BootMountList: BootNode->bn_Node.ln_Pri 15
    69.782| BootMountList: BootNode->bn_Node.ln_Name=ConfigDev 0x14014e30
    69.789| BootMountList: BootNode->bn_Flags 0x1
    69.794| BootMountList: BootNode->bn_DeviceNode 0x1417d7dc DeviceNodeName <HDIMG0>
    69.802| BootMountList: Boot
    69.804| BootDevice: BootNode 0x1417d910
    69.808| BootDevice: FileSysStartup 0x1417d82c
    69.813| BootDevice: Env 0x1417d84c
    69.816| BootDevice: TableSize 0x13
    69.820| BootDevice: SizeBlock 128
    69.823| BootDevice: SecOrg 0
    69.827| BootDevice: NumHeads 1
    69.830| BootDevice: SecsPerBlk 8
    69.834| BootDevice: BlkPerTrack 1
    69.837| BootDevice: ReservedBlks 2
    69.840| BootDevice: PreAlloc 0
    69.844| BootDevice: Interleave 0
    69.847| BootDevice: LowCyl 8256
    69.851| BootDevice: HighCyl 848415
    69.855| BootDevice: NumBuffers 128
    69.858| BootDevice: BufMemType 0x0
    69.862| BootDevice: MaxTransfer 0xffffffff
    69.866| BootDevice: Mask 0xffffffff
    69.870| BootDevice: BootPri 15
    69.874| BootDevice: DosType 0x444f5307
    69.878| BootDevice: Baud 0x0
    69.882| BootDevice: Control 0x0
    69.885| BootDevice: BootBlocks 0
    69.889| BootDevice: BootPoint Boot
    69.892| BootConfigDev: BootNode 0x1417d910
    69.896| BootConfigDev: MyConfigDev 0x14014e30
    69.901| BootConfigDev: ConfigDev->cd_Node.ln_Type 0x0
    69.906| BootConfigDev: ConfigDev->cd_Node.ln_Pri 0x0
    69.911| BootConfigDev: ConfigDev->cd_Node.ln_Name 0x0
    69.916| BootConfigDev: ConfigDev->cd_Flags 0x0
    69.921| BootConfigDev: ConfigDev->cd_Pad 0x0
    69.925| BootConfigDev: ConfigDev->cd_Rom.er_Type 0x10
    69.931| BootConfigDev: ConfigDev->cd_Rom.er_Product 0x0
    69.936| BootConfigDev: ConfigDev->cd_Rom.er_Flags 0x0
    69.941| BootConfigDev: ConfigDev->cd_Rom.er_Manufacturer 0x0
    69.947| BootConfigDev: ConfigDev->cd_Rom.er_SerialNumber 0x0
    69.953| BootConfigDev: ConfigDev->cd_Rom.er_InitDiagVec 0x0
    69.959| BootConfigDev: ConfigDev->cd_Rom.er_Reserved0c-0f 0x14014e74
    69.965| BootConfigDev: ConfigDev->cd_BoardAddr 0x0
    69.970| BootConfigDev: ConfigDev->cd_BoardSize 0x0
    69.975| BootConfigDev: ConfigDev->cd_SlotAddr 0x0
    69.980| BootConfigDev: ConfigDev->cd_SlotSize 0x0
    69.985| BootConfigDev: ConfigDev->cd_Driver 0x14014d9c
    69.990| BootConfigDev: ConfigDev->cd_NextCD 0x0
    69.995| BootConfigDev: ConfigDev->cd_UnUsed 0x0 0x0 0x0 0x0
    70.000| BootConfigDev: Diag 0x14014e74 da_flags 0x0
    70.005| BootConfigDev: MorphOS BootNode
    70.009| BootConfigDev: PrevNode 0x14003aee
    70.014| Boot <HDIMG0>
    70.016| DosInit: device node cleanup process = 0x14236f28
    70.033| SetPrefs: Buffer 0x14490a58 Size 0x0 Inform 1
    70.263| launching Permedia2 driver
    70.266| Permedia2_startup: cgxsystem.library already found
    70.272| Permedia2_startup: Trying to open Permedia2 driver
    70.278| Permedia2_startup: Creating new driver Permedia2
    70.303| launching SiS300 driver
    70.306| SiS300_startup: cgxsystem.library already found
    70.311| SiS300_startup: Trying to open SiS300 driver
    70.334| SiS300_startup: Creating new driver SiS300
    70.339| LibInit_SiS300
    70.341| Trying to find cybergraphics.library
    70.346| Trying to open dos.library
    70.349| Trying to open utility.library
    70.353| Trying to open intuition.library
    70.357| Trying to open graphics.library
    70.361| Trying to open pcix.library
    70.364| Trying to find SiS Board
    70.367| LibInit_SiS300: No SiS device found
    70.372| LibInit_SiS300 done, returning NULL
    70.376| SiS300 driver startup done
    70.393| launching SiS6326 driver
    70.396| SiS6326_startup: cgxsystem.library already found
    70.402| SiS6326_startup: Trying to open SiS6326 driver
    70.419| SiS6326_startup: Creating new driver SiS6326
    70.424| LibInit_SiS6326
    70.426| Trying to find cybergraphics.library
    70.431| Trying to open dos.library
    70.434| Trying to open utility.library
    70.438| Trying to open intuition.library
    70.442| Trying to open graphics.library
    70.446| Trying to open pcix.library
    70.449| Trying to find SiS Board
    70.453| LibInit_SiS6326: No SiS device found
    70.457| LibInit_SiS6326 done, returning NULL
    70.461| SiS6326 driver startup done
    70.480| launching SiSXabre driver
    70.483| SiSXabre_startup: cgxsystem.library already found
    70.489| SiSXabre_startup: Trying to open SiSXabre driver
    70.508| SiSXabre_startup: Creating new driver SiSXabre
    70.513| LibInit_SiSXabre
    70.515| Trying to find cybergraphics.library
    70.520| Trying to open dos.library
    70.523| Trying to open utility.library
    70.527| Trying to open intuition.library
    70.531| Trying to open graphics.library
    70.535| Trying to open pcix.library
    70.538| Trying to find SiS Board
    70.541| LibInit_SiSXabre: No SiS device found
    70.546| LibInit_SiSXabre done, returning NULL
    70.550| SiSXabre driver startup done
    70.570| launching Rage128 driver
    70.573| Rage128_startup: cgxsystem.library already found
    70.579| Rage128_startup: Trying to open Rage128 driver
    70.584| Rage128_startup: Creating new driver Rage128
    70.589| LibInit_Rage128
    70.591| Trying to find cybergraphics.library
    70.596| Trying to open dos.library
    70.599| Trying to open utility.library
    70.603| Trying to open intuition.library
    70.607| Trying to open graphics.library
    70.611| Trying to open pcix.library
    70.614| Rage128: Trying to find ATI Rage128 Board
    70.619| Rage128: No compatible ATI device found
    70.624| Rage128 driver startup done
    70.642| launching Voodoo4 driver
    70.645| Voodoo4_startup: cgxsystem.library already found
    70.650| Voodoo4_startup: Trying to open Voodoo4 driver
    70.656| Voodoo4_startup: Creating new driver Voodoo4
    70.661| LibInit_Voodoo4
    70.663| Trying to find cybergraphics.library
    70.667| Trying to open dos.library
    70.671| Trying to open utility.library
    70.675| Trying to open intuition.library
    70.679| Trying to open graphics.library
    70.683| Trying to open pcix.library
    70.686| Trying to find 3dfx Voodoo Board
    70.690| Voodoo4: No compatible 3dfx device found
    70.695| Voodoo4 driver startup done
    70.714| launching SiS315 driver
    70.716| SiS315_startup: cgxsystem.library already found
    70.722| SiS315_startup: Trying to open SiS315 driver
    70.741| SiS315_startup: Creating new driver SiS315
    70.746| LibInit_SiS315
    70.748| Trying to find cybergraphics.library
    70.753| Trying to open dos.library
    70.756| Trying to open utility.library
    70.760| Trying to open intuition.library
    70.764| Trying to open graphics.library
    70.768| Trying to open pcix.library
    70.771| Trying to find SiS Board
    70.775| LibInit_SiS315: No SiS device found
    70.779| LibInit_SiS315 done, returning NULL
    70.783| SiS315 driver startup done
    70.806| LibInit_SM502
    70.808| Trying to find cybergraphics.library
    70.812| Trying to open dos.library
    70.816| Trying to open utility.library
    70.819| Trying to open intuition.library
    70.823| Trying to open graphics.library
    70.827| Trying to open pcix.library
    70.831| SM502 BoardNode found at 0x0
    70.834| LibInit_SM502 done, returning NULL
    70.853| launching Voodoo3 driver
    70.856| Voodoo3_startup: cgxsystem.library already found
    70.862| Voodoo3_startup: Trying to open Voodoo3 driver
    70.867| Voodoo3_startup: Creating new driver Voodoo3
    70.872| LibInit_Voodoo3
    70.874| Trying to find cybergraphics.library
    70.879| Trying to open dos.library
    70.882| Trying to open utility.library
    70.886| Trying to open intuition.library
    70.890| Trying to open graphics.library
    70.894| Trying to open pcix.library
    70.897| Trying to find 3dfx Voodoo Board
    70.901| Voodoo3: No compatible 3dfx device found
    70.906| Voodoo3 driver startup done
    70.943| launching Radeon driver
    70.946| Radeon_startup: cgxsystem.library already found
    70.952| Radeon_startup: Trying to open Radeon driver
    70.957| NotifyProc ptr is at 14c3e008 DosBase at 0x1401412c
    70.962| Adding/Updating GraphDev structure to cgxsystem
    70.968| Using resident driver module DrvrBase 0x14250e78
    70.973| Radeon driver startup done
    70.992| launching Voodoo5 driver
    70.995| Voodoo5_startup: cgxsystem.library already found
    71.000| Voodoo5_startup: Trying to open Voodoo5 driver
    71.005| Voodoo5_startup: Creating new driver Voodoo5
    71.011| LibInit_Voodoo5
    71.013| Trying to find cybergraphics.library
    71.017| Trying to open dos.library
    71.021| Trying to open utility.library
    71.024| Trying to open intuition.library
    71.028| Trying to open graphics.library
    71.032| Trying to open pcix.library
    71.036| Trying to find 3dfx Voodoo Board
    71.040| Voodoo5: No compatible 3dfx device found
    71.045| Voodoo5 driver startup done
    71.064| launching XGIVolari driver
    71.067| XGIVolari_startup: cgxsystem.library already found
    71.073| XGIVolari_startup: Trying to open XGIVolari driver
    71.093| XGIVolari_startup: Creating new driver XGIVolari
    71.098| LibInit_XGIVolari
    71.100| Trying to find cybergraphics.library
    71.105| Trying to open dos.library
    71.108| Trying to open utility.library
    71.112| Trying to open intuition.library
    71.116| Trying to open graphics.library
    71.120| Trying to open pcix.library
    71.123| Trying to find XGI Volari XG40 Board
    71.128| LibInit_XGIVolari: No Volari XG40 device found
    71.133| LibInit_XGIVolari done, returning NULL
    71.138| XGIVolari driver startup done
    71.282| Mount_ScanDiskFilesystems: can't open prefs file
    71.292| Mount_ScanDiskFilesystems: Processing entry DosType 0x45585404 Filesystem "L:Ext2FileSystem" Name "Linux Ext4" PatchFlags 0x00000118 Stack 8192
    71.307| Mount_ScanDiskFilesystems: FileSysEntry 0x1400ce04 created
    71.313| Mount_ScanDiskFilesystems: Processing entry DosType 0x45585403 Filesystem "L:Ext2FileSystem" Name "Linux Ext3" PatchFlags 0x00000118 Stack 8192
    71.328| Mount_ScanDiskFilesystems: FileSysEntry 0x14c569fc created
    71.334| Mount_ScanDiskFilesystems: Processing entry DosType 0x45585402 Filesystem "L:Ext2FileSystem" Name "Linux Ext2" PatchFlags 0x00000118 Stack 8192
    71.349| Mount_ScanDiskFilesystems: FileSysEntry 0x1449d8cc created
    71.356| Mount_ScanDiskFilesystems: Skipping entry DosType 0x4d534400 Filesystem "L:FATFileSystem" - no handler found
    71.367| Mount_ScanDiskFilesystems: Skipping entry DosType 0x45584641 Filesystem "L:exFATFileSystem" - no handler found
    71.379| Mount_ScanDiskFilesystems: Processing entry DosType 0x4e544653 Filesystem "L:NTFileSystem" Name "NTFS" PatchFlags 0x00000118 Stack 8192
    71.393| Mount_ScanDiskFilesystems: FileSysEntry 0x1449da1c created
    71.401| Mount_ScanDiskFilesystems: Processing entry DosType 0x58465300 Filesystem "L:SGIXFileSystem" Name "SGI XFS" PatchFlags 0x00000118 Stack 8192
    71.415| Mount_ScanDiskFilesystems: FileSysEntry 0x1449daf4 created
    71.423| Mount_ScanDiskFilesystems: Processing entry DosType 0x4846532b Filesystem "L:HierarchicalFileSystem" Name "Apple HFS+" PatchFlags 0x00000118 Stack 8192
    71.438| Mount_ScanDiskFilesystems: FileSysEntry 0x1449dc34 created
    71.445| Mount_ScanDiskFilesystems: Processing entry DosType 0x4d414300 Filesystem "L:MacFileSystem" Name "Apple HFS" PatchFlags 0x00000118 Stack 8192
    71.460| Mount_ScanDiskFilesystems: FileSysEntry 0x1449dd64 created
    71.466| Mount_ScanDiskFilesystems: Skipping entry DosType 0x49434502 Filesystem "L:IceFileSystem" - no handler found
    71.478| Mount_ScanDiskFilesystems: End IoErr 118
    71.501| SetIPrefs: data 0x14544400 length 64 type 28
    71.506| SetIPrefs: IP_INPUTMOUSE
    71.511| SetIPrefs: Result 0x1
    71.871| SetIPrefs: data 0x14544430 length 46 type 2
    71.876| SetIPrefs: IP_FONT
    71.879| SetIPrefs: Type 0 Name <Noto Mono.font> Size 16 Font 0x146749c6
    71.886| SetIPrefs: Result 0x1
    72.216| SetIPrefs: data 0x14544430 length 46 type 2
    72.221| SetIPrefs: IP_FONT
    72.223| SetIPrefs: Type 1 Name <Noto Sans UI.font> Size 16 Font 0x146aad46
    72.231| SetIPrefs: Result 0x1
    72.970| NetConfig_Init: NetConfigBase 0x1482d7c0
    72.975| LibNetConfigReset:
    72.978| LibNetConfigReset: done
    73.364| Radeon/AtomBIOS: ATOMBIOS func 76 not available
    73.379| Radeon/AtomBIOS: ATOMBIOS func 76 not available
  • »15.07.23 - 16:51
    Posts: 2732 from 2003/2/24
    I think this is interesting, and also a sign of commitment! :-)
  • »15.07.23 - 21:51
    bigfoot
    Posts: 510 from 2003/4/11
    OK, one more upload, new md5sum is 255fcbe6db0b67a362f5550568f70468. Thanks.
  • »16.07.23 - 02:08
    Thank you very much for your help bigfoot :)
    With the new image, the hdd was found and I was able to install MorphOS and boot from hdd!
    Now a few words about the issue and what you changed in the images would be nice :)
    Will these changes be included in future releases?
  • »16.07.23 - 04:24
    bigfoot
    The Sam460le - apparently - has an extra PCI USB controller on-board compared to the Sam460ex. On the Sam460ex, the physical PCI slot is hooked up directly to the PCI controller of the CPU, where as on the Sam460le, both the physical PCI slot and the on-board USB controller are connected to a PCI-to-PCI bridge that's then connected to the CPU.
    To probe and set up devices on a PCI bus, the system software directs the PCI controller to generate configuration transactions on the PCI bus. These transactions are used to access the PCI configuration space of connected devices, which is the part of the PCI device that contains information such as the device's vendor and device IDs, as well as information about what memory and I/O are present on the device, and so on.
    There are two types of PCI configuration transactions: Type 0 and type 1. Type 0 is used to address a device on the current PCI bus segment, and type 1 is used to forward a transaction to a different PCI bus segment, ie, to a device that's behind one or more PCI-to-PCI bridges.
    Now the PCI controller in the CPU on the Sam460 is a bit special compared to other PCI controllers in that it's up to the system software to instruct the controller whether to generate type 0 or type 1 configuration transactions. MorphOS did have the code to do this, but as it turns out, the logic was faulty. Since the Sam460ex didn't have the PCI-to-PCI bridge that the Sam460le has, and PCI plug in boards that contain a PCI-to-PCI bridge are not very common, this faulty logic was never triggered before.
    In your case, this means that when MorphOS tried to probe the devices behind the PCI-to-PCI bridge, it'd use a type 0 configuration transaction instead of a type 1 configuration transaction, which in turn caused the request to be answered by devices on the PCI bus segment local to the PCI controller, ie, the one with the PCI-to-PCI bridge on it. This meant that MorphOS would think that you had an infinite number of PCI-to-PCI bridges stacked behind each other, and thus would never manage to finish probing the PCI bus.
  • »16.07.23 - 05:38
    bigfoot
    Yes.
  • »16.07.23 - 05:40
    bigfoot
    I uploaded a new image, this time with all the extra debug output disabled so it won't slow down your boot. New md5sum is 7a3eae0da2a80ff3262c7fc79cd98e52.
  • »16.07.23 - 08:23
    Posts: 12565 from 2003/5/22
    Thanks for finding out, telling about and fixing MorphOS to cope with this design change from Sam460ex (and I guess Sam460cr) to Sam460LE. As of the next MorphOS release, this fix should enlarge the list of supported mainboards by one.
  • »16.07.23 - 08:45
    Posts: 81 from 2020/5/1
    Cool and good that the "fault" was found.
  • »19.07.23 - 17:34
    > Yes.
    Now released with MorphOS 3.19:
    "When accessing the regular PCI bus, do a type 1 configuration transaction (Sam460LE)"
    https://www.morphos-team.net/releasenotes/3.19
  • »19.01.25 - 12:17
