Networks icons appears
    cip060
    Posts: 152 from 2010/7/30
    After the 3.18 update, the networks icon appears on the desktop
    Already checked if there is .info of the icon but there is nothing
    if I click it opens an empty folder
    How can I fix and remove this icon that appears in the desktop
    [ Edited by cip060 15.05.2023 - 11:11 ]
  • »15.05.23 - 07:11
    Posts: 1390 from 2010/1/6
    Here you should see all samba-clients with mounted drives/dirs (if there are some in your net).
    To remoove icon from desktop, simlpy click onit with right-mousebutton and select "put away". Now you can only find it in MyMorphOS. If you want it back, just drop it on Ambient.
  • »15.05.23 - 08:09
    Posts: 3336 from 2003/3/5
    You will see nothing in Networks if none of the computers on your local network respond to netbios queries. You might want to give it a few seconds after opening, depending on your local setup, and the list should refresh.
  • »15.05.23 - 14:23
    cip060
    Yes, but this icon appeared as soon as the update was finished on restart after updating
    I have no connection and just appeared
  • »15.05.23 - 15:43
    It will show up because it's ran after the Network stack. Whether you're online or not doesn't matter.
  • »15.05.23 - 16:01
