DAW on MorphOS, succes !
    Posts: 13 from 2023/4/16
    See this video:
    https://youtu.be/DOfoEdnwJGo
    I do not capture in realtime with HD-REC, this is just for demo purposes. The exact workflow is:
    1. Make a midi track with the sublime Horny Sequencer driving the Akai MPC One.
    2. Record the finished song with HD-REC
    3. Master the track on HD-REC (Stereo image procrssing, multiband compression, Check the EQ curve, add little saturation and maximizing at 0db.
    Making all this with an amiga is incredible!
    You can run Horny and HD-REC on an Apollo Vampire card too!
    Tell me If you want to ear the original master.
  • »13.05.23 - 10:37
