Network between Pegasos and PC...
    Posts: 14 from 2004/3/28
    How can i make LAN between pegasos and pc and share pc's internet connection?
  • »18.04.04 - 11:24
    Spidey
    Posts: 568 from 2003/2/24
    Hi -nem-,
    This has been discussed in multiple threads :-)
    I'm using:
    - Genesis for TCP/IP-stack
    - Broadband router
    - Samba + Tango
    - SMBFS (from Aminet)
    Install Samba and follow the instructions how to configure your TCP/IP stack.
    If you're using Genesis, you'll also have to fill in the host-names and IP adresses of all computers in your network (in Database->Hosts).
    Tango is a nice program to easily let you connect with the computers in your network without having you to type in commands.
    I also heard of people who only use SMBFS to mount a pc-share on their Peggy's, but with me it didn't work (unless I installed Samba).
    On your pc side turn on file-sharing and so.
    For more info, search the threads for "Samba" and "SMBS" :-)
    Good luck,
    Spidey
  • »18.04.04 - 11:41
