Posts: 1609 from 2012/11/9
I know there is an
eject context menu option for removable media, SD, CF, etc. but I've never seen the icon actually be taken off screen by the OS, as MorphOS doesn't work like Windows and MacOSX in that regard, to my knowledge, as you can just remove a removable device at will - ideally *
Caution* should be exercised so you don't remove it when you are writing to it though.
