Norway proxy / Help advance Wayfarer!
    Posts: 3336 from 2003/3/5
    I'm looking for someone to share his network connection out of Norway. This is to enable testing of a geo-locked website I'm trying to make work in Wayfarer.
    If you're in Norway and feel like helping out, I need either:
    - SSH credentials to log in to a box on a Norwegian network
    - SOCKS5 proxy credentials/address if you can run that
    The website in question is nrk.no and quite aggressively filters out VPNs and such, unfortunately.
  • »17.06.22 - 16:05
    Intuition
    Posts: 1116 from 2013/5/24
    I’m not in Norway, but I just checked it using a Norwegian endpoint with ProtonVPN and it rendered the homepage on Safari iOS.
  • »17.06.22 - 17:21
    Intuition
    jacadcaps wrote:
    Does this stream play for you on iOS ?
    https://tv.nrk.no/direkte/nrk1
    No, sorry. :(
    Not even using one of their “Plus Servers” which fool Netflix and BBC iPlayer.
    [ Edited by Intuition 18.06.2022 - 02:01 ]
  • »17.06.22 - 22:00
