Apple iBook G4/ .33 14-Inch Late 2004 - Questions
    Posts: 7 from 2022/1/11
    Hello,
    few days ago I was given this laptop.
    https://everymac.com/systems/apple/ibook/specs/ibook_g4_1.33_14.html
    I have some questions regarding MorphOS 3.15 and future 3.16
    1. After I installed 3.15 and Chrysalis pack, I cannot find option to tweak Touchpad settings anywhere (right click, scrolling etc)?
    2. Can I mirror MorphOS screen to external monitor using VGA out on this laptop, or use only external monitor as primary if I want it?
    3. What is optimum RAM size for normal usage of MOS (I am thinking of expanding this machine with extra RAM if needed)
    4. Will this machine be enough for 3.16 version of MorphOS?
    Thank you.
  • »03.02.22 - 11:15
    Posts: 12568 from 2003/5/22
    If your "normal usage" includes web browsing, I recommend maxing it out to 1.25 GiB.
  • »03.02.22 - 11:53
    OK, that is full possible ram capacity.
    What about other questions I asked? Thanks.
  • »03.02.22 - 11:57
    Posts: 1362 from 2004/2/8
    That's unlikely. People tried connecting external displays to miniVGA port of iBook and while it does work with OSX, you're out of luck when it comes to MorphOS. Real dual display is out of reach anyway, as the machine's got only 32 MB of VRAM. Mirroring should theoretically be posible, but many users failed in their attempts to achieve that.
  • »03.02.22 - 12:53
    Posts: 2580 from 2003/2/24
    1. the 1.33GHz 14" is the 2nd to last gen and DOES NOT have a USB based touchpad as the last gen (1.42GHz for the 14"). The older ADB based ones don't support gestures.
    Otherwise you would see a "Trackpad" section in Preferences.
    [ Edited by Kronos 03.02.2022 - 17:12 ]
  • »03.02.22 - 15:11
    Aaaaaaaaaaaaaaaaaaa.......
    I though I got machine which will justify buying the license of 79 EUR.
    I am out of luck it seems.
    Thanks everyone for the answers.
    I think cased version of Raspberry Pi4 is the way to go ahead. Some unified piece of hardware which will have affordable price and all MOS options available for all users, and ease life of developers.
    When such option will be available I will think again.
    [ Edited by Lokz 03.02.2022 - 20:46 ]
  • »03.02.22 - 18:45
    If you're looking for a good laptop for MorphOS then you should get a PowerBook, period.
    iBook is quite OK if you're looking for a small form factor (but you should get a 12 inch version then and preferably the latest one, A1133 at 1,33 GHz) or if you're determined to run some classic Warp3D games and demos using Goa3D. In every other case the PowerBook is just better. Higher screen res, two RAM slots, more VRAM, working DVI, PCMCIA, easier to open and service (try swapping the iBook harddrive and you will understand)... Not to mention it should run faster even at the same clock speed.
  • »03.02.22 - 19:30
    > PowerBook […] should run faster even at the same clock speed.
    …except maybe for Lame and MPlayer ;-)
  • »03.02.22 - 20:41
    Posts: 1390 from 2010/1/6
    This will take a long, long time - if it ever happens........
    None of amigan-systems are running native on raspberry (and will perhaps never).
  • »04.02.22 - 07:15
