Player MIDI ?
    cip060
    Posts: 152 from 2010/7/30
    A midi player that works on morphos?
    I can't get any players to work under morphos
    advice help?
  • »16.12.21 - 13:29
    MoerBoer
    Posts: 240 from 2019/10/15
    Try this one : https://www.morphos-storage.net/?id=1643102
    It even comes with a pre-build sf2 library to play midi files.
  • »16.12.21 - 17:02
    Posts: 919 from 2004/1/24
    After trying it, I would very much recommend not. Try this instead.
    edit: MoerBoer pointed out ANR crashes a lot for him, so here is a thread saying DAPlayer works fine.
    [ Edited by Stevo 16.12.2021 - 20:33 ]
  • »16.12.21 - 17:36
    Tcheko
    Posts: 544 from 2003/2/25
    You can try FrozenLiquid (here or there).
    You'll need to get a SoundFont (SF2) to make it works, they are easy to find. Usually, the bigger the better... Instruments are stored as samples. A huge quantity of RAM can be consumed if you pick a large soundfont.
    Usage:
    FrozenLiquid soundfont.sf2
    A Midi Cluster named against the soundfont filename is created.
    FrozenLiquid outputs by default to AHI 0 channel via Reggae framework.
    To play a Midi song, you have the PlayMidi command line.
    Usage:
    PlayMidi midisong.mid clustername
    Where
    - midisong.mid is the Midi file to play
    - clustername is the Midi Cluster to connect to (if soundfont filename is foo.sf2, clustername is foo.sf2)
    If you have some external hardware Midi Expander, just pick the its clustername to push Midi events to.
  • »17.12.21 - 06:30
    wicknix
    Posts: 18 from 2020/12/1
    WildMidi works great for me. Simply double clicking the .mid plays it, and CTRL+c stops it.
    (See screenshot) https://ibb.co/kyrYScD
    Link to download: https://www.morphos-storage.net/?id=1531933
    Cheers
    [ Edited by wicknix 18.12.2021 - 01:26 ]
  • »18.12.21 - 05:33
    Solo_Kazuki
    Posts: 194 from 2006/7/23
    AmiNetRadio can play MIDI with this player (plugin).
    Edit: Sorry, I missed that it was mentioned before.
    [ Edited by Solo_Kazuki 25.12.2021 - 07:06 ]
  • »25.12.21 - 05:03
