Mucked up AHI Settings
    Zetec-s
    Posts: 198 from 2008/7/10
    In the process of trying to get the Amiga Version of Myst to run on my G5 I seem to have mucked up my AHI settings.
    I now have no sound within Ambient, although running videos on Wayfarer still provides audio.
    I believe this is because I ran the old AHI prefs app from the Myst CD-Rom at one point and this has changed my underlying settings. I did manage to change it back but I must have clicked used rather than save as its not working again now and now the AHI prefs app is refusing to option for me.
    Is there a particular file I just need to delete to get rid of my audio settings so I can start again?
  • »17.11.21 - 07:55
    Zetec-s
    Don't worry I found it!
    Deleted AHI.prefs in EnvArc and it seems to have fixed the issue.
  • »17.11.21 - 08:07
    Posts: 2206 from 2003/2/24
    Remember that you should also find old versions of the file from the .recycled directory in this kind of situations, for example from System:.recycled/ (assuming you have SFS).
  • »17.11.21 - 16:47
