Posts: 1400 from 2003/2/15
amifrog wrote:
You would need just a little app with html view that displays a little free widget, e.g.
https://widgets.tc2000.com/?from=fsc.
The website shows an error message if you try to create a widget.
The dashboard of earlier Mac OSX allowed to create those from Safari snippets, for example.
https://piyush2909.wordpress.com/2013/08/25/top-10-free-stock-widgets-for-website-and-blog/
I am afraid this list if woefully oudated.
The problem is that these widgets need to connect to an API and the free popular ones have been shut down since this blog post was published, which is why many older widgets no longer work.
Edit: TradingView seemed to have a widget that might be suitable but it does not work with Odyssey.
