X86 Mac mini
    discreetfx
    Posts: 403 from 2003/7/26
    I’m replacing some network cables tomorrow to see if that’s the issue. That still wouldn’t explain why wireless didn’t work though unless that’s an experimental feature.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »17.10.20 - 21:14
    NewSense
    Posts: 1609 from 2012/11/9
    I can't say it's affected me specifically, but some users have mentioned in the past that selecting/using a specific channel, WiFi - Channel 6 may be best option for WiFi with MorphOS, that can make the difference between it working or not, so maybe that too could be an issue currently?
  • »17.10.20 - 22:02
    Posts: 81 from 2020/5/1
    NewSense: for 2.4 GHz wifi you should use channel 1, 6 or 11 to avoid overlapping channels. And use only 20 MHz (not 40 MHz) channel bandwidth.
  • »18.10.20 - 09:51
    discreetfx
    Issue solved and not MorphOS related. I'm not sure what ethernet gremlin was affecting my network but it went away when I replaced my two router/switches with one NetGear 24 port switch.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »19.10.20 - 23:40
    discreetfx
    What are the RAM requirements of Wayfarer? OWB launches fine but Wayfarer won't bring up any webpages. Snoopium shows it failing on every process it try's to open.
    Fixed, never-mind.
    [ Edited by discreetfx 19.10.2020 - 20:58 ]
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »19.10.20 - 23:47
  • ASiegel
    Posts: 1397 from 2003/2/15
    Glad you figured out the problem(s).
  • »20.10.20 - 00:04
