Morphobia by Encore - New MorphOS demo from Decrunch 2020
    Posts: 655 from 2004/4/15
    Nice,
    can you give more information about what was fixed?
    Key input issues related to resolution sounds really
    strange to me.
  • »05.08.20 - 15:02
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    eliot wrote:
    Nice,
    strange to me.
    I submitted on morphos-storage.net version 1.1 of all demos (Morphoza, Morphilia, Morphobia). The stragne bug in Morphobia has been fixed. :) I added to all demos function which allows to disable looping end scroller. All demos uses the latest version of the engine. Files should be available soon. I also uploaded these files to Aminet but they also aren't visible yet.
  • »05.08.20 - 19:21
  • MDW
    MDW
    I have submitted all demos in version 1.1. Unfortunately I now see on morphos-storage.net:
    ENCORE_Morphilia_1.1.0.lha
    ENCORE_Morphobia_1.0.0.lha
    ENCORE_Morphoza_1.0.lha
    I don't know what I should do for update these files. :) Could we remove everything and I will upload all three demos again? :)
  • »06.08.20 - 10:24
    Posts: 2220 from 2003/2/24
    It looks like that you forgot to update the Version field in your readmes. Only Morphoza has "Version: 1.1", but others have "Version: 1.0" in the readme headers, even though they have more recent version in the actual text, but headers is what file repositories look at. At least when I look at files at Aminet...
    [ Edited by jPV 06.08.2020 - 17:07 ]
  • »06.08.20 - 12:03
  • MDW
    MDW
    Should I submit everything again? What do you think? :)
  • »06.08.20 - 12:07
    I guess that'd work... fix versions everywhere for sure and re-up...
  • »06.08.20 - 12:09
  • MDW
    MDW
    I see Morphoza and Morphilia has been updated to 1.1. I checked if everything is ok and uploaded again Morphobia 1.1.
    Admins of MorphosStorage will kill me. ;) ;)
  • »06.08.20 - 12:41
  • MDW
    MDW
    Ok, finally all Morphotrilogy in version 1.1 is on morphos-storage.net. Thanks, greetz (and sorry) for MorphosStorage admins. :)
  • »06.08.20 - 13:41
  • MDW
    MDW
    Cool_amigaN:
    I added to each demo function for disable looping of end scroller. If you wanted to create a playlist, please start launcher of each demo, select fullscreen or window, enable sound, disable looping of end scroller and save preferences.
    Next go to ENVARC: and edit preferences of each demo:
    encore_morphoza.epf
    encore_morphilia.epf
    encore_morphobia.epf
    They are simple text files standard (standard JSON format). Change value of key "launcher" from "true" to "false". It causes starting demos without the launcher.
    And create script like this:
    encore_morphoza/morphoza
    encore_morphilia/morphilia
    encore_morphobia/morphobia
    Save the script in drawer where are saved drawers of all demos.
    Now run the script. All demos should be started in specified order. I have checked - it works. :)
    You can specify longer playlist or use loop from AmigaDOS for create one big never-ending demo. ;) But you have to check how create loop in AmigaDOS because I forgot the syntax. :)
    Please don't forget disable screen blanker in system preferences. I disabled blankers in demos if they started in fullscreen but it doesn't work. :)
    [ Edited by MDW 06.08.2020 - 18:01 ]
  • »06.08.20 - 13:58
    Posts: 12557 from 2003/5/22
    >> It was my stupid bug. :) Fixed version 1.1 will be released today.
    > can you give more information about what was fixed? Key input
    > issues related to resolution sounds really strange to me.
    I guess it is this entry in the ReadMe's version history:
    "Fixed major bug in task priorities management which on some hardware caused keyboard handling problem"
  • »06.08.20 - 15:05
    Cool_amigaN
    Posts: 777 from 2011/11/30
    Hey MDW, fyi I am able to run all 3 demos simultaneously in window mode (640x360@ 24bit). Cpu reaches about 90% in full load, 75 fps steady on all three apart from minor scenes which may drop at 40-45 fps. But 95% of the time I get smooth playback in all three.
    Extremely nice performance!
    Last addition should be to loop the demo and make a list to play them continuously :P
  • »07.08.20 - 09:34
