Need some help with Ambient error
    Furvert
    Posts: 83 from 2004/4/20
    Title basically says it. Booting up the Pegasos II Ambient doesn't come up in the proper screen resolution. Anbient MUI and MUI setting all say the screen should be 1920x1080 Carbonix.
    Latest MorphOS version, and it was working just fine yesterday.
    Here is the thing though. I know this has to be a software issue. I have several programs set to 1920x1080 with MUI settings and those ALL come up in the proper resolution.
    I can't tell what screen it's showing in. They all come up the same for Ambient when I swap resolution or skins but it's NOT widescreen. Is there a hotkey or something I hit by mistake??
  • »09.06.20 - 16:11
    Furvert
    It had been doing this all day.
    Nothing I tried fixed it and now as if just to make today even more weird it fixes itself magically.
    Wondering if this is a sign the drive being so old is at risk.
    Fortunately I was already working to replace it with a slightly larger drive
  • »10.06.20 - 01:15
