MorphOS Developer
Posts: 3274 from 2003/3/5
connor wrote:
I want to use Synergy but it does not work yet.
The MorphOS Synergy client and server come without a doc, but reading the original application's docs should be enough.
enter the client IP address and place it next to the server in the grid
view
You don't need to enter the client's IP in the server config. Instead you must enter the *name* of the client (which is MorphOS by default in the MorphOS' synergy client). It'd help you to enable logging in the server to see if the MorphOS' client even tries to connect.
As for the protocol version, both client and server advertise 1.6 protocol. Do note that Synergy application version (like the 1.7.3 pro you mentioned) isn't the same as protocol version.
