Is there a Secure FTP download/upload program for MorphOS?
    NewSense
    Posts: 1618 from 2012/11/9
    I was trying to upload a file or two to a webpage but find that the server has been modified fairly recently to use TLS and does not allow anymore Ami Trade Centre - that I've used before, as it now returns the message "... cleartext sessions and weak ciphers are not accepted on this server.... Please reconnect using TLS security mechanisms." :-(
    I tried Transfer v2.5, but even though I selected SFTP as the connecting option I think the same issue exists for that utility as well.
    So, do we have a way (program/utility) of transferring files via TLS/Secure FTP, or have others used Transfer v2.5 successfully recently? :-?
    I have used Transfer v2.5 also in the past, and managed OK with it, but it is not connecting for me at the moment. :-(
    I know there is hURL - a Plugin for Hollywood v8+, but I don't know of any application/utility that has been authored to take advantage of its possibilities at the moment, unless someone else knows differently? :-?.
  • »30.09.19 - 04:11
    Posts: 3336 from 2003/3/5
    You'll find sftp in :Applications/RemoteShell/files or in the SDK.
    No idea why Transfer would not work for you though. Could be down to a bug and then it's likely fixed in the upcoming 3.12.
  • »30.09.19 - 04:21
    Posts: 2220 from 2003/2/24
    First of all, there are two different secure FTP protocols: FTPS and SFTP. Server asking for TLS indicates that it wants to use the FTPS protocol, which is just a extension over the traditional FTP protocol. SFTP is its own protocol which usually works over SSH.
    I think that Transfer only supports FTP and SFTP, but not FTPS, and that's why you can't get it to work if your server doesn't offer SFTP service and denies the unencrypted FTP.
    I have drafted a proof-of-concept FTP client with Hollywood, which can basically get file listings and transfer files over FTP, but doesn't do anything else at the moment. Next step would be trying to implement secure protocols, but unfortunately SFTP wasn't compiled to hURL after all, so that'd need to wait for an update, but I think that FTPS could be done already. The next step would be trying if I could get that work... I've been thinking that how much time I should put into this or is it useless, because we have Transfer, but if there's demand, maybe I could continue when I get over of my recent hurries.
  • »30.09.19 - 04:43
    NewSense
    I appreciate both of your responses, especially as you've replied so quickly, and thanks jacadcaps for the mention of the upcoming v3.12 release and that this issue is likely fixed with it.
    @ jPV - I thought you might be considering such a utility with Hollywood, and I'll let you know how much further I get, as I'll ensure the server port is still correct for the transfer to the hosted files, and take it from there, but Transfer did work before they migtaed to TLS, and maybe that's not properly enabled with the current version of Transfer v2.5, as it also worked with AmiTrade Centre, but neither are working / uploading / accessing the files at the moment.
  • »30.09.19 - 05:39
    Posts: 12568 from 2003/5/22
    As I understand jPV's reply, jacadcaps' reply was based on a misunderstanding, confusing SFTP and FTPS.
    As jPV said, current Transfer version does not support FTPS, just like ATC.
  • »30.09.19 - 10:14
    Well, yeah. Indeed Transfer only does plain old FTP and SFTP. There's no FTPS support.
  • »30.09.19 - 11:32
    NewSense
    After quite a long gap between my last update - it seems that it is FTPS that I need to use as the other options no longer work to access the data on the server. :-(
    So, for me, FTPS cannot be implemented soon enough for any utility, new or modified, for that type of data transfer to work through MorphOS, as I am having to use a Windows FTPS utility for now.
    Is FTPS likely to be implemented soon?
  • »08.01.20 - 23:03
    Just to let everyone know, I've now been making an FTPS client in Hollywood, and hopefully it'll be usable enough. It's going to be quite basic (no multiple connections), but still has some nice details.
  • »21.01.20 - 19:10
