Behaviour of PowerBook after close lid
  • MDW
    MDW
    Posts: 497 from 2003/7/25
    Could someone explain me rules of MorphOS behaviour after close lid of PowerBookG4? In previous versions of MorphOS if I closed lid, PowerBook was turned off immediately. In MorphOS 3.12 if I close and open the lid, MorphOS still is opened and everything works. However yesterday I closed lid and open it after a few minutes - PowerBook was turned off.
    When does PowerBook with closed lid is turned off? Does kind of power (battery or charger) affect to rules of turning off?
    [ Edited by MDW 29.12.2019 - 14:02 ]
  • »29.12.19 - 11:57
    Posts: 3275 from 2003/3/5
    That was never the case. Only the backlight was turned off to avoid overheating the mobo. PowerBook is not really designed to operate with a lid closed. So if it switched off for you, it likely means it shut down due to overheat.
  • »29.12.19 - 14:40
  • MDW
    MDW
    So MorphOS does not trigger shut down hardware when lid is closed for several minutes?
    I checked it today. If I close lid when PowerBook is not connected to charger (uses only battery), MorphOS works. However after several minutes PowerBook is turned off. I will check the time and compare with sleep time in MorphOS Preferences.
  • »29.12.19 - 18:11
    Maybe it's just your battery then? :) I'm quite sure there's no shutdown trigger related to the lid state.
  • »05.01.20 - 19:06
    OffseT
    Posts: 23 from 2019/8/23
    FYI, I have this behavior too. It is the case since the first MorphOS version for PowerBook. After a few minutes, the PowerBook shut down and there is no noticable overheat (temperature is normal just before shutdown).
  • »05.01.20 - 20:45
    It would be helpful if you could list the exact models you have.
  • »07.01.20 - 05:03
    OffseT
    PowerBook G4 A1138 15“
  • »07.01.20 - 08:42
    emeck
    Posts: 175 from 2014/7/15
    Same model and behaviour here. About 6 minutes after closing lid PB went off. Battery was at 41% when closing lid and 39% when powered on later.
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »08.01.20 - 15:45
