DI.fm
    Posts: 2730 from 2003/2/24
    Maybe some of you remember the music streaming service (á la Shoutcast) called Digitally Imported from a couple of years ago?
    Just wanted to point out to those of you who does remember, and who (like myself) missed it, that a DI.fm exists now (maybe it has for some time, I don't know, it's new to me at least). I have no idea about whether it's connected at all to the old original one, but the contents and quality of the music is everything that the old DI was. :-)
    Probably won't work with Odyssey, but if you are into any kind of electronic music, you can check it out on other platforms (including dedicated phone apps). Free of charge with commercial breaks.
    https://www.di.fm/
  • »03.12.19 - 20:18
    Doffo
    Posts: 508 from 2010/10/14
    https://www.di.fm/
    Pretty cool. Thanks for the sharing.
    YUUUP!
  • »04.12.19 - 02:05
    Doffo
    From what I gathered, you would have to get the Premium in order to stream to 3rd party players. That would probably be the only way to get it to play under MorphOS. :)
    YUUUP!
  • »04.12.19 - 04:21
    Posts: 1385 from 2010/1/6
    https://www.di.fm/ works perfectly under OWB/MOS - thank you!
    Useing the URL shown in message-window, tracks are even downloadable......
    [ Editiert durch Amigaharry2 04.12.2019 - 09:06 ]
  • »04.12.19 - 07:01
    Doffo
    For whatever reason, nothing comes up on my end for showing the stations or anything. Its always blank.
    YUUUP!
  • »04.12.19 - 16:19
