Audio Sync Problem Fullscreen Youtube
    Posts: 27 from 2019/10/6
    When I use the fullscreen script for Youtube in OWB, the audio is always out of sync - is this normal? Is there an option to adjust the timing of the audio or could I add an edit to the script?
    I'm using 3.12 on 1.67ghz Powerbook.
  • »10.10.19 - 17:55
    Posts: 1383 from 2010/1/6
    Useing too high resolution? (CPU near 100%?)
  • »10.10.19 - 18:32
    As far as I can tell, the fullscreen defaults to 360P? Either way that's the resolution I stick with. CPU use flucuates between videos and even 2 seconds buffering makes a difference - some videos play at 30% others 60% CPU. The media options in OWB make a difference but there is a significant quality drop.
  • »10.10.19 - 18:38
    Posts: 168 from 2004/11/18
    same thing for me on 720p or 1080p vids , normal because of the power needs... sure it can be better if we use the gpu to read the stream but it's something that will not happend before a long time.
    720p can be shown but if you want 1080p a strong G5 is needed.
  • »10.10.19 - 18:41
    360P is fine for me - the fact that it plays as low as 30% CPU shows there's a lot of headroom, so the audio sync isn't because of lack of power.
  • »10.10.19 - 18:46
