cdcd - when typing
    Posts: 14 from 2017/7/1
    Second one for today.
    When I type 'cd+{space}' into the shell it duplicates. Also with any 2 char entries.
    Thanks again.
  • »23.09.19 - 09:48
    Korni
    Posts: 473 from 2006/2/23
    What's your HW? Issue like this can happen when the keyboard isn't properly connected or is simply poorly designed which happens on low end keyboards. If you run MorphOS on a laptop and don't want to open it, then you can press the keyboard a bit harder around center area, also check with the other USB keyboard.
  • »23.09.19 - 11:03
    Thank you for the responses.
    Its a Mac Mini G4 with apple keyboard plugged through an apple monitor.
  • »23.09.19 - 14:46
    Posts: 2220 from 2003/2/24
    Would you have a PC keyboard to compare how that'd work? Anyway haven't seen anything like this with minis myself, but I don't like to use Mac keyboards...
    [ Edited by jPV 23.09.2019 - 21:04 ]
  • »23.09.19 - 16:02
    Posts: 1362 from 2004/2/8
    Have you tried tinkering with key repeat delay in system prefs?
  • »25.09.19 - 11:49
    Debaser
    Posts: 161 from 2005/7/12
    I had a series of issues with my mini g4 and using a keyboard from my old G4 450 Sawtooth with Morphos back in the day. The issues occurred regardless if plugged into the machine directly or via powered usb hub. But I chalked it up to being a fluke.
  • »26.09.19 - 00:43
    thank you both for responses.
    I tried the delay settings to no avail. Seems like its a keyboard issue. I will look for a replacement.
  • »27.09.19 - 09:21
