sys:Applications_ext/e-uae/HardDisks/AOS31WHD
    Posts: 14 from 2017/7/1
    E-UAE 1.0.0
    When using RHLaunch, no matter which location I put in for hardfile, I always getting an error in the log:
    Error: directory 'sys:Applications_ext/e-uae/HardDisks/AOS31WHD' not found
    ROMs, Rom Key, etc are all inplace. Basically I am setting up a 3.1 environment with CWB.
    Any ideas?
  • »23.09.19 - 09:47
    Korni
    Posts: 473 from 2006/2/23
    This path is probably somehwere in config files (rhlaunch or e-uae itself). You can use Ambient search and search for text inside files. By default when no config to use is specified, e-uae uses .uaerc in its progdir:.
  • »23.09.19 - 11:10
    Directly editting the config file worked thank you!
    See my thread about active windows + mouse click = sends the to the background. Frustrating and cannot get this one figured out.
    -Craig
  • »23.09.19 - 16:00
