Having some keyboard issues
    Posts: 14 from 2019/5/15
    For some reason I can't get CTRL to work. So no CTRL+C or CTRL+D. The keyboard itself works fine with other operating systems. I also have no issues in MorphOS with any of the "regular" keys.
    There is 2 US keyboards in the settings and I tried them both. Anybody else having this issue or know of a workaround/fix?
    Thanks!
  • »22.05.19 - 19:14
    NewSense
    Posts: 1609 from 2012/11/9
    Can you reset/reboot your system using Control+LeftCommand+RightCommand?
    Just to know if the Control key is recognised at all that way.
  • »22.05.19 - 22:19
    I just tried it, doesn’t do anything
  • »23.05.19 - 01:55
    NewSense
    OK, so are you sure it works correctly as Copy (C) &/or Paste (V) functions on Windows?
    What make is the keyboard, and is it USB or Bluetooth? USB keyboards are usually quite cheap anyway, so it might be worth acquiring another one even if it's a used one, just to make sure it works OK at low cost.
    I have to say that of the few keyboards that I have used that are USB they all worked OK, though I usually use Apple A1016 Bluetooth keyboard(s) (via Mac OSX Dual Boot Bluetooth Pairing) and wired Apple A1048 keyboard(s), as they are quite cheap and can be taken apart and fixed if need be, so I can recommend them as they are quite robust.
  • »23.05.19 - 05:08
    It's a Corsair STRAFE USB Keyboard. And yes I am sure that it works in Windows and Linux. I am using this keyboard for my PC and my Raspberry PIs. It's a weird thing. I will keep digging into it. I could obviously use a different keyboard but my desk is already littered with Amigas and other stuff :-D
  • »24.05.19 - 13:54
    igracki
    Posts: 469 from 2003/2/24
    You could try to go into the USB settings of the keyboard an see if the keys are recognized there.
  • »24.05.19 - 17:11
    Posts: 2217 from 2003/2/24
    And yet another way to try to see if there's any input, is to try to configure IControl Hotkeys... select "Sample" for any function and then it should show immediately if you press the control key. Like shown here: Hotkeys.
  • »25.05.19 - 06:33
