MorphOS's bugtracker
    Posts: 4 from 2019/5/18
    Hello,
    I have come across such a certain bug in MorphOS related to wireless networking module. I think it is called WPASupplicant or something like that.
    Does exist an official bugtracker where can I post the encountered problem and the suggested workaround?
    Thanks in avance.
  • »18.05.19 - 10:28
    AKiLL
    Posts: 93 from 2006/3/6
    Yes. You can use the bug report form provided in the About MorphOS menu - support tab section.
  • »18.05.19 - 10:41
    Thank you very much!
  • »18.05.19 - 11:10
