After 3.10 install -> MPlayer getting out of sync
    Cego
    Posts: 738 from 2006/5/27
    hi there,
    i have a strange issue here. I have installed 3.10 on both of my MorphOS machines. Now all the videos i play in mplayer will get out of sync after 30-60 seconds. I tried two different mp4/h264 files and a DVD. Can somebody test this on his setup and give me some feedback? On my PowerBook at least, it worked fine with MorphOS 3.9
  • »26.04.18 - 09:15
    deka
    Posts: 136 from 2013/2/12
    I had this issue on older MOS revisions too. Not with every codec or resolution tough. (PowerBook A1138)
    Huckle went well for my son. :)
    [ Edited by deka 26.04.2018 - 14:33 ]
  • »26.04.18 - 10:32
    Cego
    well CPU usage is at 50-60% on my 1,2GHz iBook. I dont think the codec is too demanding for my hardware spec.
  • »26.04.18 - 10:57
    deka
    Just watching a presentation video a few days ago...
    As I remember, the playing was going well, then something happened and the the video part became jerky while the audio part was going fine further and they were out of sync.
    Sometimes MPlayer detects somehow that the sync is out and corrects it.
  • »26.04.18 - 11:34
    Posts: 1385 from 2010/1/6
    Try to give some delay with + or - keys! +/- 300ms should help in most cases.
  • »26.04.18 - 12:31
    zukow
    Posts: 657 from 2005/2/9
    Try to disable frameskip in pereferences.
  • »26.04.18 - 13:20
    connor
    Posts: 650 from 2007/7/29
    I always had this problem with MOS Mplayer, also when I used frameskip (or was it framedrop?) or jumped back and forth in the video. I always had to start videos from the beginning. So I just thought "MOS MPlayer can't do better".
  • »26.04.18 - 16:10
    Posts: 2217 from 2003/2/24
    Did you update your existing installation of MorphOS or did you do a complete re-install? Did your MPlayer installation change or did you re-install it?
    I've always been fine to play videos/movies on my main MorphOS setups, but last September when I was preparing my spare machine for an Amiga event with a plan to play Viva Amiga movie on it, I noticed that on that one particular setup MPlayer got out of sync after a while when you played a movie from the beginning. I paniced a bit because I didn't want to change my plans what machines I take with me and use to show the movie on a projector etc. I tried the same movie on several machines and my PB, IBook, and 1.5GHz mini did play it without sync issues, but my 1.42GHz mini got out of sync always. It wasn't because of framedrop option either and I finally ended up to copy my MPlayer directory/installation from my working setup to the problematic machine, and surprisingly that did help.
    So, I got it playing fine and it worked fine at the event. It must have been some config or MPlayer version issue, but I haven't remembered to get back into it with more tests, I was just reliefed that it started to work fine :) Maybe I should try to make more tests some day now...
    Anyway, are you sure you have the latest MPlayer in use? And maybe try to re-download and unpack it to some other location than your previous installation to avoid any config changes, and try that way?
    [ Edited by jPV 01.05.2018 - 17:24 ]
  • »01.05.18 - 12:23
