Jukebox
    Posts: 2217 from 2003/2/24
    There's now a tooltype to disable the framescanning/length calculation to speed up the loading of tracks: FRAMESCAN=NO
    You'll lose ability to seek in such tracks, but speeds up the loading massively if you have loots of broken mp3 files.
    Another new tooltype STREAMBUFFER=YES activates the experimental Reggae streambuffer class which reduces stuttering, but causes lag on track change and seeking.
  • »17.05.15 - 09:07
    DJBase
    Posts: 745 from 2003/4/6
    What I would like to see is support for internet radio streaming (.pls and .m3u) to make it perfect and minimal. Any chance?
    [ Edited by DJBase 21.04.2018 - 09:20 ]
  • »20.04.18 - 17:12
    dekanyz
    Posts: 94 from 2013/2/6
    DJBase wrote:
    What would like to see is support for internet radio streaming (.pls and .m3u) to make it perfect and minimal. Any chance?
    Mplayer is there for that.
  • »21.04.18 - 03:50
    Jeckel
    Posts: 133 from 2007/3/11
    Streaming support would be actually a nice add to Jukebox. MPlayer is a bit overkill for radio streaming.
    BTW, streaming works nicely with AmiNetRadio (both OGG and MP3 streams).
    [ Edited by Jeckel 21.04.2018 - 08:38 ]
  • »21.04.18 - 04:37
    Posts: 1385 from 2010/1/6
    Why not use AmitNetRadio for streaming?
  • »21.04.18 - 05:14
    BTW. Jukebox now caches track lengths to a database and that reduces loading time a lot for previously listened songs.
    And playlist can be defined in icons, and icons are created to playlists so that you can just launch any playlist directly from its own icon.
  • »21.04.18 - 07:22
    DJBase
    Found some problems while listening to large mp3 files (i.e. Podcasts) I do have some small delays/distortion every now and then but regular. I don't have these with DAPlayer or AmigaAmp. Any idea?
  • »21.04.18 - 15:45
  • ASiegel
    Posts: 1397 from 2003/2/15
    It should help if you could point to specific files (podcast episodes, etc.) so they can be tested by others.
  • »21.04.18 - 16:29
    DJBase
    Danke, someone pointed me to the tooltype STREAMBUFFER=YES mentioned above which seems to did the job, I can't hear any stuttering anymore.
    But, one more thing... what about including an id3tag editor?
  • »21.04.18 - 16:39
    igracki
    Posts: 469 from 2003/2/24
    I'm using CgmRadio v2.0 from krashan to play streams/internet radio.
    I used it to stream Radio Fritz, with the help of some scripts I can have the currently playing title displayed in the titlebar (with MagicBeacon).
  • »21.04.18 - 18:50
