Posts: 498 from 2003/7/25
jacadcaps wrote:
@MDW just to clarify: you *are* using WiFi, right? Does the Network preferences exhibit similar issue? (it's the same mcc).
I had two modules for WiFi:
1. WiFi (installed additionally)
2. Wireless (standard module from MorphOS)
If I enable WiFi module, system will crash after each MorphOS boot. Wireless module works great and doesn't cause crash. When I delete WiFi module the crash doesn't occur. It is not a problem because I don't need WiFi module. Standard Network module is better. I enabled WiFi module for a moment and just for test (I wanted see how it looks).
