A look at the new MorphOS
    Tom01
    Posts: 187 from 2009/9/20
    > IMHO there is little practical point in comparing non-SIMD performance,
    > since the 970 *does* have Altivec.
    Most tasks can‘t be vectorized, so comparing CPUs by their non-SIMD performance does make sense.
    Tasks, which are calculating something can be vectorized.
    If a Program mostly consists of the User-Interface, then Vectorization makes no Sense.
  • »19.03.18 - 13:44
    Posts: 12569 from 2003/5/22
    > Tasks, which are calculating something can be vectorized. If a Program mostly
    Of course, 1+2 can be computed by the AltiVec unit. But vectorization is for SIMD use cases, which means the very same computation is applied to a sufficiently large number of elements. Too small a number may mean that the overhead exceeds the gain. And often, the bottleneck is not in the computation itself (but in I/O speed etc.). So I should better say that most tasks, even if vectorizable in theory, wouldn't benefit from vectorization in practice.
  • »19.03.18 - 14:23
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Acill wrote:
    Cant wait for this to be released! The beta on my X5000 was fantastic to use during Amiwest. I will be keeping my G5 as well for it I think, just much easier to boot into a single machine and not worry about corruption from the other OS reading the drives.
    How far away are we from release Paul?
  • »23.03.18 - 14:50
    DanicaTalos
    Posts: 460 from 2010/10/15
    A PM G5 PCI-e Version is better. A x5000 costs horrible! A PM G5 PCI-e costs ca. 150,- - 200,-.
    [ Editiert durch DanicaTalos 25.03.2018 - 17:15 ]
    iBook G4 - 14" -1,42 GHz - 32MB VRAM - 1,5GB RAM - 60GB mSata - MorphOS 3.20
  • »25.03.18 - 07:49
    Posts: 2581 from 2003/2/24
    I'd say about 20km, but that number may differ for you ;)
  • »25.03.18 - 08:32
    So now we know that MorphOS was traveling at about 2.5km/h !!
  • »25.03.18 - 16:44
