Posts: 1362 from 2004/2/8
It is possible, but you'd need a proper template for printing (with no background). Like
this or
that. Then take it to your favourite printing house and print on a transparent sticker. And then try to cover the apple with this one.
But the simple boing woudn't make it, as the apple isn't an orange. If you'd like to cover it rather than just sticking a boing ball inside, you'd have to mask it with more material. Or you could make that apple black and still have the
glowing boingball inside. There are so many possibilities...
