Ambient options
    sergius
    Posts: 47 from 2005/12/6
    When I use Ambient to copy files, windows are locked until the copy is finished.
    I remembrer a switch option to change into Ambient prefs to unlock use on interface during copies but dont remember where this option is.
    Can somebody help me please?
    Thanks for advence.
    [ Edited by sergius 17.09.2017 - 11:57 ]
  • »17.09.17 - 07:44
    Posts: 1390 from 2010/1/6
    Normal behavior is only locking the window from where you are copying....all others are normaly unlocked.
    Ambent hidden prefs can be found in Sys:prefs/ambient/Ambient.prefs. But I did'nt find any enties for your problem there......
  • »17.09.17 - 08:09
  • ASiegel
    Posts: 1397 from 2003/2/15
    @ sergius
    If, in fact, all Ambient windows are temporarily locked, you might have a dying disk. I experienced this symptom not too long ago myself.
  • »17.09.17 - 09:12
    Korni
    Posts: 473 from 2006/2/23
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7300&forum=3
    Where is Andreas Wolf when you need him??!!1
  • »17.09.17 - 12:05
    Posts: 1362 from 2004/2/8
    He doesn't have to be everywhere, sometimes he just sends his minion to do a lesser work :D
  • »17.09.17 - 12:08
    Posts: 12569 from 2003/5/22
    Seeing as I'm too late to the party let me just correct this one bit. As per the thread linked by Korni, the hidden prefs are in SYS:Prefs/Ambient/Advanced.conf :-)
  • »17.09.17 - 13:33
    sergius
    Thank you guys and specialy komi for his link.
  • »17.09.17 - 18:42
