I'm bidding for an A1103
    dethknave
    Posts: 31 from 2015/11/28
    Let us hope I know what I'm getting myself into.
    I've already qued up the repair site just in case.
    https://www.ifixit.com/Device/Mac_mini_(PowerPC)
    Sadly it only has 32Meg of vram on a radeon9200
    which looks like it's built into the mainboard
    M$ buys GitHub?
    'Bout time to panic
  • »12.05.17 - 22:33
    Posts: 2581 from 2003/2/24
    Unless it's really cheap or your planning on useing a rather small monitor I would advice waiting for a "silent upgrade" 1.5GHz Mini with 64MB to come up.
  • »13.05.17 - 03:01
    Posts: 56 from 2016/3/9
    Check the link in the thread I posted below this one. I think they still have a few. They're buy it now at $39.99 including free shipping but are taking offers. I got mine for $30 and got power supply and DVI to VGA adapter for each one.
  • »13.05.17 - 14:38
    *shrug*
    The 2nd 1.5GHz Mini that I bought around 2012 was 40Euro.
  • »13.05.17 - 14:43
    igracki
    Posts: 471 from 2003/2/24
    Yesterday I bought a PowerMac G5 2.3GHz with Radeon 9600/128MB and 5GB RAM for 31.50€!
  • »13.05.17 - 15:09
    Intuition
    Posts: 1116 from 2013/5/24
    Blimey. My 2.7GHz G5 was 250 in 2013 lol
    [ Edited by Intuition 13.05.2017 - 18:55 ]
  • »13.05.17 - 15:54
    Yeah, I paid $400 for my dual 2.7GHz G5 around the same time and could probably find one today for less than 1/2 that price. As for the 1.5GHz silent upgrade MacMini's on eBay, I offered the guy the same $30 and asked about the power supply, and they countered back with an offer of $34.95 and told me all the power supplies were gone. I didn't accept the counter offer yet, but might, if he still has any left. It's a great price for a 1.5GHz G4 MacMini.
    I always wished that the last version of the previous version Mac's would be supported, as I liked the look and convenience of the attached monitor (the Mac that looked like a lamp base with a monitor connected to the top of it), but I like bigger monitors now, so probably would tire of the novelty of it and end up using something like a G4 or G5 PowerMac with a 20-inch or larger monitor instead, for running MorphOS, like I do today.
    To the original poster of this thread: Don't buy the 32mb VRAM MacMini, as it will most likely end up disappointing you after a while, and you will wish you had waited for something better.
  • »13.05.17 - 17:01
    dethknave
    Well, I got it for 30usd with power brick and dvi adapter. If I can make it run deluxpaint and aladdn4d that would likely complete my use case scenario.
    But I may test it with an old Linux distribution for a while.
    M$ buys GitHub?
    'Bout time to panic
  • »13.05.17 - 18:54
    Posts: 12569 from 2003/5/22
    > [...] (the Mac that looked like a lamp base with a monitor connected to the top of it)
    The problem with all models of iMac G4 is the onboard Nvidia GPU.
    > I [...] probably would [...] end up using something like a G4 or G5 PowerMac with
    The last iMac G4 model came with a 20 inch screen.
  • »13.05.17 - 20:52
    If its a 1.5 GHz with 64 mb of vram, cool.
  • »13.05.17 - 21:21
    dethknave
    nah its a 1.42
    I will see how it compares to my A3K and my A1200 with
    deluxepaint and A4D
    Tis machine will be used to just doodle with mostly.
    Think Ill run the video out into a capture device on my
    A1289 -2314
    or maybe on my I7-4790 machine.
    M$ buys GitHub?
    'Bout time to panic
  • »13.05.17 - 23:15
    Posts: 2220 from 2003/2/24
    You can also test with MorphOS without registering first, but with 30mins periods...
    You probably can't get Deluxe Paint work without E-UAE, but try Personal Paint, it works quite fine and is in many ways better than DPaint too.
  • »14.05.17 - 05:24
    dethknave
    So during the Lubuntu 16.04 (ppc) liveCD boot process, I get a message about invalid ROM contents in Radeon. Then a lockup a few minutes into desktop navigation.
    However, this does NOT happen under MorphOS(demo). Only glitch I had under morphOS(demo) was the Work: icon had a garbled backdrop for a while. A few reboots and it's been fine.
    Lubuntu and MorphOS(demo) are like a thousand times faster than 10.5.8 lol
    M$ buys GitHub?
    'Bout time to panic
  • »20.05.17 - 18:49
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    The invalid ROM contents message only tells you that it's no x86 bios I suppose. The problem is that the Radeon r300 driver (which is for all r300-r500 cards) got some serious bugs on Big Endian Hardware.
    See Bug #101038 and #94877.
    Yep, even Linux without an GPU-accelerated desktop feels faster that 10.5.8. :-D
    MorphOS hardware support is the best!
    [ Editiert durch ernsteiswuerfel 21.05.2017 - 15:16 ]
  • »21.05.17 - 11:13
    That can happen sometimes if you're using a non-enhanced display mode and have certain effects turned on for icon texts, so it doesn't indicate any particular problem on your hardware or so.
  • »21.05.17 - 14:35
