Ambient random background?
    r-tea
    Posts: 317 from 2005/3/27
    Hello guys!
    I wonder if the option "Change backround after:" is for changing ambient's background randomly.
    How to active it?
  • »28.02.17 - 16:38
    roschmyr
    Posts: 211 from 2003/2/20
    Select a directory with pictures and let the field File empty, after that the slider will be adjustable
  • »28.02.17 - 17:39
    Posts: 2206 from 2003/2/24
    Just remove the filename and it'll show random pictures from the defined drawer.
  • »28.02.17 - 17:40
    r-tea
    Thanks guys. I did as you said and it works.
    I really thought it's temporarily inactive in this version of MorphOS. Before I've posted this question I specified a drawer containing my wallpapers and then removed the picture filename from the File: textfield and the slider didn't get activated. That's why.
    Right after I've read your replies I clicked the File: field activated and hit Return on keyboard. And that was the key detail -> hit Return :-)
    Previously I just moved the focus elsewhere after removing the picture filename.. That should be enough to activate random background IMHO, but it isn't.
    Don't you think?
  • »01.03.17 - 16:24
