Test mouse buttons/keys to start others startup-sequence
    Posts: 2224 from 2003/2/24
    That MouseTest doesn't work under MorphOS, because it seems to try to read values directly from CIA or something like that.
    But with a quick look to Aminet, I found this:
    http://mos.aminet.net/package/util/boot/IfQual11
    It seems to work under MorphOS and also supports middle mouse button etc too.
    Works for example like this:
    IfQual LBUT echo "lmb pressed"
    So, just replace that echo "lmb pressed" with a command to launch E-UAE and put it on S:user-startup for example.
  • »26.02.17 - 15:47
