    Posts: 1 from 2017/2/9
    Hi.
    I have bought PowerMac G4 comaptible with hardware requirements described on the Morph-OS team page. After that i downloaded the MorphOS3.9 iso file for the Apple computers. Burned the iso image with imgburn software and tried boot it up ...
    ... and , no chance boot it up.
    Ok. i heard on the #macosx IRC channel that the DVD drive in my PowerMac can be non-compatible with the CD-R media i have used. Problem is that i have no password to the PowerMac MacOS X system what instaled there and i cant check it.
    OK. Lest try the USB install version.
    i did all step by step as its described in the install manual. opened OF and used the command for booting up the boot.img with the morphos.iso.
    i did get this screen first
    second after that came this
    after this i started experimenting with the partitioning my USB to the 250MB, later to 500MB, but i did get ALLWAYS message "cant open the boot.img" as here https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11569&forum=3
    Thats my experience for now
  • »09.02.17 - 09:41
    Posts: 1354 from 2004/2/8
    Can you list the flash drive contents using OpenFirmware?
    As for OSX - there are certain ways to get rid of that password. Just use Google.
  • »09.02.17 - 09:48
