Downgrade to Morphos 3.x ? ISO files ?
  • ZB
    ZB
    Posts: 115 from 2008/9/29
    Hi, unfortunately I have to downgrade my Morphos 3.9 installation to bypass my audio problem described in another thread of yesterday... Powermac audio problem
    So anyone can send me old ISOs or a link where I can download any old version from 3.0 to 3.8 ?
    (I have tested only 3.0, so I would like to try 3.8 first and, if required, go down to 3.0 that surely work... but, obviously, every version will be highly appreciated).
    ZB
    [ Edited by ZB 30.12.2016 - 14:29 ]
    Morphing the Phoenix...
  • »30.12.16 - 12:24
    Korni
    Posts: 473 from 2006/2/23
    Mouse clicks are irrelevant. Does it happen when you boot from ISO? Try to play this mp3 from ram, also check another player like mplayer.
    [ Edited by Korni 30.12.2016 - 14:56 ]
  • »30.12.16 - 12:56
  • ZB
    ZB
    It happens always from cd or hd... and for all the audio... games, mp3s, all.
    [ Edited by ZB 30.12.2016 - 15:33 ]
  • »30.12.16 - 13:31
    Posts: 1385 from 2010/1/6
    You should post your problem to MorphOS-Developer. Maybe they can fix it......
  • »30.12.16 - 14:41
  • ZB
    ZB
    Thanks to all !
  • »30.12.16 - 14:47
  • ZB
    ZB
    How can I do this ?
    [ Edited by ZB 30.12.2016 - 17:00 ]
  • »30.12.16 - 14:58
    Posts: 3311 from 2003/3/5
    Don't install 3.0 just yet. You only need to copy the applei2s.audio from MorphOS/Devs/AHI. The file is likely still on your system partition in SYS:MorphOS_old.
  • »30.12.16 - 15:04
  • ZB
    ZB
    @ jacadcaps
    It works !
    Thanks !
  • »30.12.16 - 17:13
