PowerMac MOS boot problem
    beworld
    Posts: 683 from 2010/2/10
    hi all,
    I have sometimes a bug when i lauch my PowerMac G5 (2.7Ghz).
    MorphOS boot and before i see Amlbient, i have a window that appears "Log Server"
    In this window i show that :
    Name : Public Screen Manager"
    Category : unknown exception
    User :nobody
    when i click on this : i see "68k Exception in Task 0x200c3fc8 "Public Screen Manager"
    Information : Instrcution at address 0xb6680000, no further information available
    Stacktrace 68k : nothing...
    Stacktrace PPC and registers :
    http://www.warmup-asso.fr/test/1.jpg
    http://www.warmup-asso.fr/test/2.jpg
    I cant save log..... the disks arent available.
    My configuration :
    PowerMac G5 DP 2.7Ghz with 4 Gb RAM
    ATI 9800 PRO 256 Mo (R350)
    Monitor : LED 23" DVI 1920*1080
    This bub onlyu appears from time to time, after some reboot it works, i see Ambient.
    If you have an idea ? thanks
    My MOS ports
  • »19.11.16 - 14:15
    Posts: 1362 from 2004/2/8
    Does the CPU/GPU have sufficient cooling?
    Does the problem persist when booting from CD?
    Did you try turning Enhanced Display or Screenbar modules off?
  • »19.11.16 - 14:40
    igracki
    Posts: 471 from 2003/2/24
    Do you have yWeather.sbar installed?
    It may crash the PSM, if the network needs more time to come up or there are problems to open/load the sbar for the first time.
    Its (probably) because of a bug in ECX's library generation code (which I already fixed!).
    I can send you a test version if you want.
  • »19.11.16 - 16:38
    igracki
    <Double post deleted>
    [ Edited by igracki 19.11.2016 - 20:38 ]
  • »19.11.16 - 17:08
    beworld
    @koszer
    - yes, when MOS start normaly, it's working very well
    - i check that with new install
    - same, i test
    @igracki
    - yes ihave yWeather.... i disabled it and tell you the result
    thanks
    My MOS ports
  • »19.11.16 - 18:13
    NewSense
    Posts: 1618 from 2012/11/9
    I have a similar 'Public Screen Manager' exception when my MacMini starts up, and I too have yWeather installed/running from startup as a screenbar module, so is this likely to be an issue until v3.10 is released?
    It does not exhibit this same (PSM) exception every time my system boots, but I get it about 20% of the time when booting, and usually the next time it reboots this issue doesn't appear..
    [ Edited by NewSense 19.11.2016 - 20:10 ]
  • »19.11.16 - 19:09
    Posts: 1390 from 2010/1/6
    I've sometime the same (or similar) "Public Screen Manager" - problem on all MACs (PB, G5, Mini), but it always works after a second reboot. This occures since MOS3.9 and rarely also with naked MOS3.9 installation.........
    EFIKA with MOS3.9 (till yet) and PegasosII (MOS3.8) are not influenced....
  • »19.11.16 - 20:31
    beworld
    I have disabled YWeather and indeed this does not bug anymore.
    I keep testing.
    I am reassured, I am not the only one to have this worry.
    PS: google translate... grrrrr :-)
    [ Edité par beworld 20.11.2016 - 14:54 ]
    [ Edité par beworld 20.11.2016 - 14:55 ]
    My MOS ports
  • »20.11.16 - 12:52
    igracki
    Hi, I just uploaded v1.18 of yWeather.sbar with the fixed library generation code.
    Please, could you test this version and report if it fixes the boot problem?
  • »20.11.16 - 13:07
    beworld
    so... that fix my boot problem, thanks you !
    I reboot many many time and it's OKKKK for me
    My MOS ports
  • »20.11.16 - 14:57
    Interessting....I have never installed yWeather.sbar........
  • »20.11.16 - 18:06
    NewSense
    I've swapped over to v1.18, and I'll comment here if there are any issues in the future with yWeather v1.18, but so far it's running smoooothly, and thanks for hopefully fixing this issue so quickly. 8-D
    [ Edited by NewSense 21.11.2016 - 02:51 ]
  • »21.11.16 - 01:50
    beworld
    @igracki very thanks, my G5 work very well since your last version !
    My MOS ports
  • »23.11.16 - 19:02
    Posts: 1099 from 2004/9/23
    :) you have no idea :D
  • »23.11.16 - 19:27
    emeck
    Posts: 175 from 2014/7/15
    Hello igracki.
    This last week I had a little problem with yweather. During some days, I didn't have internet connection and when MorphOS booted, Ambient was kinda blocked: couldn't open any volumes, inserted usb disk didn't show nor dock icons worked.
    Short story is that if yweather.sbar is used when connected to wifi but with no internet access, it blocks Ambient. But if router is off or no pcmcia wifi card when booting, then yweather fails but doesn't block Ambient, which I think should be the same in the first case.
    I know is not a normal situation but thought it might be better to report.
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »18.12.16 - 09:51
