Energy.sbar suggestion / feature request
    Posts: 917 from 2004/1/24
    @MorphOS development team
    Would it be possible to expand the functionality of Energy.sbar so one could configure a custom alarm when the battery runs out of energy? The current "battery is low" warning at 4% is easily missed. Thanks in advance :-)
  • »19.10.16 - 17:07
    BatteMan
    Posts: 290 from 2003/2/24
    I use MagicBeacon for this. You can configure the notification as you wish.
    /me likes this commoditie very much !
  • »19.10.16 - 18:02
    Thanks, it's indeed a great program. I would still like it as an option in the .sbar though (instead of having to use a seperate program) ;-)
  • »20.10.16 - 17:06
    Posts: 1385 from 2010/1/6
    Good idea. You should write that to the programmer (Jacek Piszcek).
  • »21.10.16 - 06:55
    Posts: 3311 from 2003/3/5
    Uhm, OK? :)
  • »21.10.16 - 09:45
    jacadcaps wrote:
    Uhm, OK? :)
    Thanks :-D
  • »21.10.16 - 14:15
