Scene demo made with Hollywood
    phoenixkonsole
    Posts: 140 from 2010/8/4
    We hope you like it
    Here we go : )
    Fabio has made some nice oldschool effects and Andreas was able to fix some Bugs on ARM linux.. So this baby helped mankind already : )
    We hope you like it
    youtube preview
    Get it here for AROS i386:
    AROS i386 version
    AmigaOS 4.x version:
    AmigaOS4.x version
    AmigaOS 3.x + RTG version:
    AmigaOS3.x version RTG only
    MorphOS version:
    MorphOS version
    Windows:
    Windows version
    OSX PPC:
    OSX PPC version
    OSX Intel:
    OSX intel version
    Excerpt from the readme:
    THANK YOU!
    This is a small gift to all IndieGO! project backers.
    Run the executable without arguments or use the following to
    adjust to your needs:
    FULLSCREEN SWITCH ( default = 1, ON )
    -fs 0 | 1
    HARDWARE GRAPHICS ( default = 0, OFF )
    usefull on Amiga-like systems to improve fps
    -hwgfx 0 | 1
    SHOW FPS ( default = 0, OFF )
    -fps 0 | 1
    WAIT VBL ( default = 0, OFF )
    -waitvbl 0 | 1
    TARGET FPS ( default =999 )
    -targetfps n
    DEMO RESOLUTION ( default = 800,600 )
    -demores w,h
    SCREEN RESOLUTION ( default = host )
    -screenres w,h | host
    ENABLE DEMORES TO SCREENRES SCALING ( default = 0, OFF )
    -scale 0 | 1
    *** WITH SCALING ENABLED ***
    SCALED SMOOTHING ( default = 0, OFF )
    -smoothing 0 | 1
    FIT TO SCREEN ( default = 1, ON )
    -fit 0 | 1
    KEEP ASPECT RATIO ( default = 1, ON )
    -aspect 0 | 1
    HAVE FUN!
    Allanon
    This demo has been made with Hollywood 6.1
    Web : www.hollywood-mal.com
    ::: CONTACTS :::
    Web : www.a-mc.biz
    Web : www.a-mc.biz/support
    eMail : hijoe@tin.it
    Twitter : @Allanon71
  • »17.08.16 - 15:24
    amiga4001
    Posts: 454 from 2006/11/16
    I have only fragments off sound in morphos version.
    Nice demo
  • »17.08.16 - 17:22
    Brumiga
    Posts: 270 from 2004/4/3
    @phoenixkonsole,
    Could you add a linux version, x86 32 bits and/or 64 bits of your demo please ?
    Brumiga
  • »17.08.16 - 18:22
    phoenixkonsole
    Maybe you can reduce the "internal" resolution to reduce cpu load..
    64bit is not possible yet (Andreas is working to support 64bit natively with Hollywood for the next release).
    32bit binaries made with hollywood don't work on 64bit Linux in most cases because they rely on older dependencies not offered by newer Linux branches...
    "Teufelskreis" : )
    But you can try it anyway (please check file permissions if needed and it could be that you need do make it executable)
    Linux i386 binary:
    https://www.indiego.rocks/file/downloadApp/732419c478ec182c246af659f6c7480a
    thankyou -demores 800,600 for example could work better..
    [ Edited by phoenixkonsole 18.08.2016 - 00:04 ]
  • »17.08.16 - 19:00
    Posts: 2206 from 2003/2/24
    The audio worked here with Mac mini and MorphOS. Nice demo and cool effort, but I'd rather see different kinds of effects in newer systems.. it doesn't feel and look right to me to see old hardware (copper etc) made effects done with software :) They're always smoother and cooler on real hw :)
  • »18.08.16 - 03:15
    phoenixkonsole
    It was too celebrate the good old times ; )
    If you like you can try this:
    http://indiego.rocks/file/downloadApp/af028fede4de2ade6d2eeb54403085f7
    Lossless vector animation player
    It includes a demo mode and benchmark mode:
    "vanplayer -demo 1" will execute the demo mode
    "vanplayer -benchmark 1" will execute the benchmark and writes the results to a file called benchmark.txt
    Of course you can also run a GUI player with "vanplayer" and load other VAN's (we will release some for testing)
    [ Edited by phoenixkonsole 25.08.2016 - 22:37 ]
  • »25.08.16 - 17:36
