Posts: 874 from 2007/4/9
Quote:ernsteiswuerfel wrote:
boot_wb schrieb:
Did you try the script above?
I've just updated it to make it simpler, and avoid a pitfall or two (script now runs from the ISO - no need to copy files; is now tolerant of the flash plugin; script tidied up). Links in previous posts above have been removed.
Many thanks for your script, works like a charm!
Thanks for testing. :)
www.hullchimneyservices.co.uk
Windows free since 2011!
