morphos 3.9 install
    caver99
    Posts: 131 from 2012/6/14
    I installed 3.9 over weekend and wiped my 3.6 system but very strange that every folder is empty, I have done this twice no and yet morphos still works ok cant get anything to load and run apart from the actual os.
    I will have another go later with another download and burn.
    the system is a powermac g4 quicksilver 2002 with 2 x ide hdds an ati radeon 9250 which works in os x 10.4 and os 3.6
    I also have crystals to install like 3.6
    anyone else have oddities like this
    Powermac quicksilver Dual 1ghz Dual Boot Morph OS 3.7 and OS X 10.5.8
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »23.05.16 - 09:21
    Posts: 2581 from 2003/2/24
    My guess is that only your icons disappered/are not shown. You can check this by going to an "empty" folder and changing the right cycle from "Icon" to "All files".
    ???? Did you install an Chyrsalis pack designed for another MorphOS version ? That may very well f##ked up your system.
    Try a clean install.
  • »23.05.16 - 12:23
    caver99
    no I did a fresh install of 3.9 and even tried chrysalis 3.9.2 and both ere empty and that was with all files selected.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »24.05.16 - 13:39
    caver99
    redownloaded morphos 3.9 and did another fresh install and even went into the shell and did a dir of the c folder and completely empty really not sure what's going on here, everything still works as it should, I have even downloaded grunge and installed apps and games and all work.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »26.05.16 - 06:59
    "c" is supposed to be empty on a clean install, as MorphOS will install it's shell-commands in "MorphOS/c".
    Same is true for libs,devs,classes and so on.
  • »26.05.16 - 07:45
    caver99
    Ah ok thanks Kronos its been a while since I did a fresh install.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »27.05.16 - 04:55
