Hello,
every program I open shows fails in snoopium; some many fails. But programs open and work without trouble. So I'm wondering if this is normal behaviour... The only problem I'm having is Odyssey taking too long to be functional after loading pages like several second before I can change tabs or click links or scroll down a page (the page being fully loaded and drivelamp showing heavy read activity). Odyssey also show lots of fails in snoopium.
For example, this is the output for minicalc:
[1] [MiniCalc] [OpenCat] [Aboutbox_mcc.catalog] [0] [Fail]
[2] [MiniCalc] [OpenCat] [MiniCalc.catalog] [0] [Fail]
[3] [MiniCalc] [OpenCat] [Aboutbox_mcc.catalog] [0] [Fail]
[4] [MiniCalc] [FindVar] [muidebug] [Local] [Fail]
[5] [MiniCalc] [Open] [Ram Disk:ENV/muidebug] [Read] [Fail]
[6] [MiniCalc] [GetVar] [muidebug] [Any] [Fail]
[7] [MiniCalc] [Lock] [env:mui/MINICALC.1.prefs] [Read] [Fail]
[8] [MiniCalc] [Open] [envarc:mui/MINICALC.1.cfg] [Read] [Fail]
[9] [MiniCalc] [Open] [env:mui/MINICALC.1.prefs] [Read] [Fail]
and for fixfonts:
[1] [FixFonts] [Lock] [System:Fonts/DGSansSerif.otag] [Read] [Fail]
[2] [FixFonts] [Lock] [System:Fonts/Fontconfig.otag] [Read] [Fail]
[3] [FixFonts] [Load] [System:Fonts/Fontconfig/font-82d599ba57ca7443.cache] [] [Fail]
[4] [FixFonts] [Load] [System:Fonts/Fontconfig/font-86e07f97eb6942af.cache] [] [Fail]
[5] [FixFonts] [Load] [System:Fonts/Fontconfig/font-a9dafeffe4520ea1.cache] [] [Fail]
[6] [FixFonts] [Load] [System:Fonts/Fontconfig/font-7f2f5d2e13126260.cache] [] [Fail]
[7] [FixFonts] [Load] [System:Fonts/Fontconfig/fonts.conf] [] [Fail]
[8] [FixFonts] [Load] [System:Fonts/Fontconfig/font-190b19e56c3cb0e6.cache] [] [Fail]
[9] [FixFonts] [Delete] [System:Fonts/Fontconfig.font] [] [Fail]
[10] [FixFonts] [Lock] [System:Fonts/_ttf.otag] [Read] [Fail]
[11] [FixFonts] [Load] [System:Fonts/_ttf/trebucit.ttf] [] [Fail]
[12] [FixFonts] [Load] [System:Fonts/_ttf/Verdanab.TTF] [] [Fail]
[13] [FixFonts] [Load] [System:Fonts/_ttf/Verdanai.TTF] [] [Fail]
[14] [FixFonts] [Load] [System:Fonts/_ttf/Verdanaz.TTF] [] [Fail]
and for fileimactrl:
[1] [FileImageCtrl] [OpenCat] [FileImageCtrl.catalog] [0] [Fail]
[2] [FileImageCtrl] [ToolType] [CX_POPUP] [] [Fail]
[3] [ramlib] [Open] [MOSSYS:DEVS/fileimage.device.elf] [Read] [Fail]
[4] [ramlib] [Open] [MOSSYS:DEVS/fileimage.device.elf] [Read] [Fail]
[5] [ramlib] [Load] [MOSSYS:DEVS/fileimage.device.elf] [] [Fail]
[6] [FileImageCtrl] [OpenCat] [Aboutbox_mcc.catalog] [0] [Fail]
[7] [FileImageCtrl] [FindVar] [muidebug] [Local] [Fail]
[8] [FileImageCtrl] [Open] [Ram Disk:ENV/muidebug] [Read] [Fail]
[9] [FileImageCtrl] [GetVar] [muidebug] [Any] [Fail]
[10] [FileImageCtrl] [Lock] [env:mui/FILEIMAGECTRL.prefs] [Read] [Fail]
[11] [ramlib] [Open] [MOSSYS:LIBS/mui/Title.mui.elf] [Read] [Fail]
[12] [ramlib] [Open] [MOSSYS:LIBS/mui/Title.mui.elf] [Read] [Fail]
[13] [ramlib] [Load] [MOSSYS:LIBS/mui/Title.mui.elf] [] [Fail]
[14] [ramlib] [Open] [MOSSYS:LIBS/mui/Title.mui] [Read] [Fail]
[15] [ramlib] [Open] [MOSSYS:LIBS/mui/Title.mui] [Read] [Fail]
[16] [ramlib] [Load] [MOSSYS:LIBS/mui/Title.mui] [] [Fail]
[17] [ramlib] [Open] [LIBS:mui/Title.mui.elf] [Read] [Fail]
[18] [ramlib] [Open] [LIBS:mui/Title.mui.elf] [Read] [Fail]
[19] [ramlib] [Load] [LIBS:mui/Title.mui.elf] [] [Fail]
[20] [ramlib] [Open] [System:Tools/mui/Title.mui.elf] [Read] [Fail]
[21] [ramlib] [Open] [System:Tools/mui/Title.mui.elf] [Read] [Fail]
[22] [ramlib] [Load] [System:Tools/mui/Title.mui.elf] [] [Fail]
[23] [FileImageCtrl] [Open] [env:mui/FILEIMAGECTRL.prefs] [Read] [Fail]
PowerBook 5.8 MorphOS 3.18
Mac Mini MorphOS 3.18
