Recommend Terminal Comms for Null Modem to another Amiga
    macsociety
    Posts: 57 from 2010/1/18
    I want to use my MorphOS Mac Mini running 3.9 to receive incoming serial data from a serial connection. I already have a null modem rs232 to usb cable but not familiar with an easy to use comms package on MorphOS that I can leave running in the background grapping serial data from other systems.
    Any recommendations?
    Thanks
    TJ
    [ Edited by macsociety 22.03.2016 - 16:03 ]
  • »22.03.16 - 21:57
    asrael22
    Posts: 445 from 2014/6/11
    Term is pretty good. Version 4.8 I believe is the last one.
    It's 68k but does it's job well under MorphOS.
    It supports a lot of protocols, if you need it, like zmodem, etc.
    Manfred
  • »23.03.16 - 04:44
    asrael22
    That's the one I mean:
    http://aminet.net/package/comm/term/term-main
  • »23.03.16 - 06:10
    macsociety
    Thank you. Will check it out. Hope it knows to communicate via USB port on MorphOS Mac Mini.  ;-) TJ
  • »23.03.16 - 13:25
    asrael22
    I have used it already with an USB serial adapter. Works pretty well.
    Manfred
  • »23.03.16 - 14:38
    Posts: 2206 from 2003/2/24
    I wonder if the logtool program from the MorphOS SDK would work, if only thing you need is to monitor some serial messages?
  • »23.03.16 - 15:07
