Mounter freezes system
    Elowan
    Posts: 214 from 2011/4/18
    hello,
    I want to report, that the "Mounter" tool freezes my system, as soon as I start to scan for devices.
    When hitting "ide.device", it produces a list (about 13 partitions - yes, that´s right and ok) but after that, it stops responding.
    Even worse, nothing else (except the mouse pointer) responds anymore...
    Any ideas where to dig / how to fix it?
    kind regards
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »01.03.16 - 10:58
    Elowan
    so no ideas what I can do to fix this? I already did "update installation" from CD again, but no success...
  • »02.03.16 - 06:16
    Posts: 2197 from 2003/2/24
    Mounter has never crashed here on any of the dozen machines I've used... does it crash if you start it when booted from the installation CD? Does it crash if you select any other than ide.device (if you have USB stick connected, for example)?
  • »02.03.16 - 06:29
    Elowan
    good point, I will try and report back!
  • »02.03.16 - 08:21
    Elowan
    Ok, I checked a few things and must do a little correction:
    The system does not freeze, I can still right-click and leave ambient/restart system*
    But the Mounter Window can not be closed or updated anymore, just moving around works.
    Now, when booting the live-cd, it´s the same issue, as soon as Mounter lists all partitions.
    When I plug in USB stick and click on that device, everythings allright and mounter still works.
    But when clicking the harddisk device, it freezes after producing the partition´s list...
    *edit again: not everytime, sometimes this is not possible anymore!
    [ Editiert durch Elowan 03.03.2016 - 08:39 ]
  • »02.03.16 - 15:46
    Maybe you should file a bug report (About MorphOS -> Support). And if you can get debug log saved if it reveals something about the crash. Must be some partition config causing problems...
    Does HDConfig show all partitions fine?
  • »03.03.16 - 15:03
    Elowan
    no, after installing some software and playing "Goobnies", the system decided to freeze forever.
    when I try to boot now, screnn stay white. when booting from cd, it says something about DH1 unfinished transaction and so on... I will make a new thread or give up
  • »03.03.16 - 17:07
    Elowan
    I did a re-install (completely wiped MOS partitions) and face the same problem, again.
    Maybe there is a limit in number of partitions (13) or it is because I got debian linux (yaboot) and OSX (bootstrap) installed next to MOS?
    The high partition count results in OSX making kind of "padding partitions 8MB" before and after every partition (exept after the last partition)
    I´ve basically made 6 partitions...
    [ Editiert durch Elowan 04.03.2016 - 11:47 ]
  • »04.03.16 - 08:28
    Elowan
    Oh - HDConfig seems to work fine...
    Maybe 1.9GB is too small for a MOS SFS "DH1" partition? (DHO is 55MB, 53MBfree)
    Maybe there´s a relation between this and that?
    I´d really like to sort it out!
    [ Editiert durch Elowan 04.03.2016 - 11:50 ]
  • »04.03.16 - 08:45
    1.9GB isn't too small for DH1. MorphOS itself fits just fine on it, and plenty of other stuff too.
    I have 12 partitions on my Pegaos1 machine (one FFS, one Ext2, one Linux swap, rest SFS), and Mounter works fine with it. So, either it's because you have one partition more, or some exotic partition/combination revealing some bug.
  • »04.03.16 - 09:15
    Elowan
    Hmmm, maybe something not compatible, with the drive itself?
    External Transfer Rate(Host Transfer Rate):150MB/s
    Density 8GB 8GB 16GB 32GB 64GB 128GB
    Space(MB/s) 33/15 40/26 58/30 110/40 112/60 115/70
    Channel 2CH 4CH 2CH 4CH 4CH 4CH
    ● Form factor: 2.5-inch (100mm x 69.8mm x 9.5mm)
    ● Interface standard: 44Pin IDE/PATA
    ● Input voltage: 5V (±5%)
    ● Commercial operating temperature range form 0 to +70℃
    ● Flash management algorithm: static and dynamic wear-leveling, bad block
    ● Supports dynamic power management and SMART (Self-Monitoring, Analysis and
    Reporting Technology),Trim
    ● ECC (Error Correction Code): BCH ECC 72bits in 1024Bytes
    ● Write endurance: >8years @ 100GB write/ day(32GB)
    ● Read endurance: unlimited
    ● Data retention: 10 years
    ● MTBF:1,000,000 Hours
    Specifications:
    Model CHN-25PATA01M-016
    General Form factor 2.5"
    Interface PATA/IDE
    Performance Capacity 16GB
    Sustained Read 58MB/S
    Sustained Write 30MB/S
    Random IOPS
    4KB Random Read IOPS
    4KB Random Write IOPS
    Average Access time 0.2ms
    Storage Media NAND Flash MLC- NAND Flash
    Power Consumption input Voltage 5V+/_5%
    Idle 0.5W
    Active 2.0W
    Reliability& Endurance Write endurance 80years@10GBytes write and erase per day at 32GB
    Read endurance unlimited
    Wear-Leveling Algorithm Dynamic and static wear-leveling
    Data Retention 10years at 25ºC
    MTBF 1,000,000hours
    ECC Supports BCH ECC 8bits or 15bits in 512 bytes
    Bad Block Management Auto Bad Block Management in system
    Environment Operating Temperature 0~70ºC
    Non-operating Temperature -40~85ºC
    Shock 2,000G(@0.3ms half sine wave)
    Vibration 20G(40-2000HZ)
    Ambient Humidity 5-95%
    Warranty 3years
    Available unit Available Available,NO EOL
    Testing Platform CPU:AMD Athlon 64×2 5200+ 2.7GHz,SDRAM:DDR2 800(PC6400) 2048 MB×1PCS, Mainboard:AMD RS780 (ATI Radeon HD 3200 Graphics)System:Microsoft Windows XP Professional SP2
    Testing Software HDBench3.4.0.3, IOMeter 2006.07.27
    Physical Dimensions & Weight Height(mm) 9.5+/_0.25
    Width(mm) 69.8+/_0.25
    Length(mm) 100.0+/_0.25
    Weight(g) 75±5
    ※The read and write speed is limited to this test platform.
  • »04.03.16 - 10:01
    Elowan
    Ok, I´ve files a bug report (mailed@support) - let´s see if we can find a solution!
    Cheers
  • »04.03.16 - 10:43
