Mod to mp3 with better sound?
    Yasu
    Posts: 1724 from 2012/3/22
    I wrote this blog a long time ago:
    https://morphosuser.wordpress.com/2014/09/21/turning-mods-to-mp3/
    Now I wonder if you can, with relative ease, change the sound from hard right and left to an "arch". That is, a little more easy to listen too with head phones.
    Any suggestions?
    My MorphOS blog
  • »01.03.16 - 14:23
    BSzili
    Posts: 569 from 2012/6/8
    What you are looking for is less stereo-separation. I have no idea if the ANR has an option to reduce that though.
  • »01.03.16 - 14:31
    Yasu
    It doesn't have to ANR. As long as it's not overly complicated. Further down the blog I use other programs instead.
    My MorphOS blog
  • »01.03.16 - 16:21
    Korni
    Posts: 473 from 2006/2/23
    uade can do this.
    -pan/-p value Sets panning value in the range of [0.00, 1.00] (mix channels)
  • »01.03.16 - 16:26
    BSzili
    Googling "wav stereo separation" landed me on this page:
    http://www.paula8364.com/post.php?id=000209032015220703
  • »01.03.16 - 16:36
    Yasu
    @Korni
    Thanks for the help. This made a difference :-) Is there a way in UADE to repeat the song a couple of times (as it would in a tracker) and also fade out in the end?
    My MorphOS blog
  • »01.03.16 - 19:34
    Yasu
    @Korni
    Also, thanks BSzili for digging that up for me :-)
    [ Edited by Yasu 01.03.2016 - 22:57 ]
    My MorphOS blog
  • »01.03.16 - 19:55
    Korni
    @Yasu
    If a song lacks ending then it should repeat itself (there is a timeout setting in uade and then it stops).
    -no-end/-ne The first song will be played indefinetely (probably)
    Also uade --help ;).
    sox can fade-in/out
  • »01.03.16 - 22:19
    Yasu
    @Korni
    It wasn't at all obvious and it took me some time to understand from the documentation what I was suppose to write (as there was no example code (at least in the "fade" part of the documentation) to show how you used it) but I got it in the end. Now I got everything I need. Thanks :-)
    My MorphOS blog
  • »03.03.16 - 09:44
