Moderator
Posts: 462 from 2003/7/21
Happy to see you've solved. Not knowing about firmware updates I would have suggested to check the Wireless network name (SSID) and if it is the same as before either change it or delete the wireless.prefs because sometimes it seems to get confused if the same name applies to different setups... Not your case, but maybe it might help someone in the future!
Kind regards,
Andrea
